ASUS P5PE-VM Motherboard Logo
Posted on Aug 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am want ram pins detals - ASUS P5PE-VM Motherboard
Anonymous
Level 2:
  • Expert 319 Answers
  • Posted on Aug 02, 2010
Anonymous
Expert
Level 2:
Answers
319
Questions
0
Helped
80925
Points
915
Www.newegg.com/Product/Product.aspx?Item... - United States
2answers
Fuji drypix 5000 error 0238
fuji drypix 7000 error 0004
detal info e 271
MY AM2 6100 HAVE ONE LONG BEEP WHAT IS THIS MEAN????
The beep you hear is a BIOS Beep Code.
One long continuous beep indicates DRAM error.
Ram Memory problem.
Have you upgraded, or changed any Ram Memory module/s, lately?
(Ram memory module = ram memory 'stick')
No? Just happened out of the blue?
Computer unplugged from power, computer case open, FOLLOW Anti-Static Precautions.
Remove all ram memory modules from their slots.
Clean the gold plated contact pins on the bottom.
(Basic example of a DDR Sdram ram memory module.
It has 184 gold plated contact pins on the bottom. 92 on each side.
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
If you are using DDR2 Sdram, it has 240 gold plated contact pins on the bottom. 120 on each side.
The above example is just to show you the gold plated contact pins )
Handle the ram memory module by the BODY. The body is everywhere on the ram memory module, except the gold plated contact pins on the bottom.
The body is coated with a see-through protective plastic.
Refrain from touching the gold plated contact pins.
Use a pencil eraser to clean the contact pins. BOTH sides.
Rub the eraser up, and down on each contact pin. Doesn't take much to clean them.
Use air to remove the eraser dust. You can use a can of compressed air for computers, if available, or air pressure from your mouth will be sufficient.
If the can of air is available, use it on the ram memory slots, also.
Reinstall all ram memory modules. Make SURE they are well seated in their slots. The Locking 'ears' on the sides of the slot, will be engaged with the Side Notches, on the sides of the ram memory module.
[Note*
The Locks on the sides of the ram memory slot, do not FULLY engage all the way into the Side Notches, of the ram memory module. When the Locks are fully engaged, you will hear a click, as they go in ]
Perform this procedure, then post back in a Comment as to your findings.
Regards,
joecoolvette
I have problem with how to identify Ram type E.g DDR1,DDR2
DDR1 RAM: Has 180 pins, typically a double sided memory module. DDR2 RAM: Has 240 pins, only fits one way opposed to DDR3 RAM. DDR3 RAM: Has 240 pins, voltage is 1.6V and only fits one way.
2answers
I have a p4s533-mx motherboard with 1.7ghz intel processor, my system had 1gig pc3200 and 256mb pc400 at 400mhz ddr1 ram, now my system suddenly wont pick up the 1gig ram card, only beeps when powered up...
The RAM modules may not be compatible with each other.
Try using the same make RAM modules.
Try Installing the 1Gb RAM module without the 256Mb RAM module.
After the detaling my navigation stoped working
if you can see the reset button press it with a piece of wire located somewhwew around that area look for a small hole? reset look in manual?
1helpful
Ram cards ?
Yes, you will have to purchase the correct RAM modules.
Your 184 pin RAM is DDR. Here is a picture.
07eb2c5.jpg If you count the small copper contacts at the bottom on this side, there are 92. There are also 92 on the other side. (Total of 184) These are the "pins".
Go to www.crucial.com and run their scan program. It is safe. It will scan your system and then tell you how much RAM you have, how much your computer will hold, and what kind of RAM you need.
Thanks for using Fixya.
Dell Latitude D600 RAM
yes it will as long as you keep the speeds the same and the pin count on the ram the same
Duraband DBD VR01
Call manufacturer service/parts department for part numbers and ordering instructions
How to create program in delphi
i wants to create form for data input
with the condition
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
