PC LINE SPEAKER - Pc Line PCL-201S
I have recently bought these for my Compaq computer but the sound is only coming out of one speaker - can you help?
    Genius:
  • 2,785 Answers
May be your other speaker is dead, plz try in another pc
Posted on Apr 25, 2008
Sound is distorted and echo's
check the speaker plug/outlets is usually if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is or a can of compressed air
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jul 29, 2012 | Compaq Presario CQ57-410US 15.6-Inch 320GB...
I have my Vizio hooked up to my computer. I have a sub-woofer and speakers. How do I get the speakers to work w/tv mode. They work when I am using computer mode. I have comcast cable and box.
Good day sir, Hi, you see, the TV produces its own sound, you need to feed this sound to your PC. here are options were you need to choose.
  1. You need a separate sub/speaker system for your TV. feed the sub/speaker with the sound line out from the TV. you also need an RCA to stereo baby plug adaptor for your sub/speaker.
  2. If you want to use your PC speakers, feed the line out of the TV sound to the line in of the PC, usually the line in is the blue port, you need an RCA to stereo baby plug. then activate the line in function from the mixer volume properties. This requires that you turn on your PC when in TV mode.
  3. Simply disconnect the sub/speaker baby plud input from the PC and connect it to the line out of your TV using an RCA to baby jack adaptor. (re connect again if you want it on your PC. this is very complicated)
  4. Does your sub has extra input? like aux, or cd, or tuner? feed the TV line out to one of these extra port. use the input selector switch from TV and PC. you need an RCA to stereo baby plug connector.
I forgot to ask, Does your TV has line out? if no, you are stuck with the built-in speakers.
Dec 16, 2009 | Vizio L37 Television
Wharfedale s20030 speakers broken?
First, check input power (electricity) of your speaker. You can see lamp indicator on speaker (usually LED lamp, Light Emitting Diode, green light or else) must be light ON.
Two, jack line out (usually green) on the speaker, you must touch that jack. Don't worry, you can't heart attack cause of it (for touching that jack, DC-Direct Current supply). If you hear some noise, sound of droning, buzzing, that is indicate of sound will be come out from that speaker.
Three, you play WinAmp software (or Windows Media Player, from Microsoft) and get in one of mp3 file, and load it into WinAmp player. Make sure if your mp3 file is normally sound.
Four, plug in your green jack (of speaker) to the line in of your sound card (refer to mainboard PC, if your soundcard get in ONBOARD or plug in PCI slot). Green jack line of speaker to socket green of sound card.
Five, now you can hear sound of your song....
Sep 06, 2009 | Computers & Internet
How to avoid sounds heard in speaker even after connecting headphone in compaq presario c700
Asalam u alikum,
Dear friend yours broblem have been solved if you do this steps.
1. first go to the start menu.
2. then select a control panel.
3. In control panel select option (sound,speech,audio devices) then select change the speaker setting, the sound and audio properties is opened, go to the speaker setting select advanced option in advanced option change the speaker setup and select stereo headphone and apply it.
I hope its solved yours problem.
Thanks
Oct 14, 2008 | Compaq Presario 700 470024-192 Notebook
Only right speaker working
disconnect all the cables and fix it again,then check the speaker sounds bychecking the sound settings in control pannel.
Aug 03, 2008 | HP JBL Platinum Computer Speakers
Compaq fp5315
Dear Sir/madam,
Check the speaker output cable will be correctly plugged to CPU or not?. i.e line in, line out etc...
thanks
good luck
Jul 29, 2008 | HP Compaq FP5315 15" LCD Monitor
Pc connection
yes,,,i think it will on run 2 speakers,,, get y cables
Jul 11, 2008 | Celestion S10 Subwoofer
Lost sound on an HP d530 after reinstalling WIN XP Pro
YOU MIGHT NEED TO TAKE OUT THE INTERNAL SPEAKER AND REINSTALL THE SOUND MAX AND YOU MIGHT GET IT WORKING
Jul 06, 2008 | HP Compaq Business d530 Small Form Factor...
Connect BX8A speaker to PC
Hello waddragon,
First, let's start with the BX8a. Those are powered speakers (built-in amplifier in each) so, you do not need a pre-amp. What you need to connect them to your computer is a 3.5mm to XLR cable OR a 3.5mm to 1/4" TRS cable, also known as 3.5mm to two 1/4" mono plugs (the back of the BX8a has inputs that accept either type). Cables are available at most any electronics stores. Make sure you buy a long enough cable to run from the back of the computer to where the speakers will be.
It sounds that you only have one BX8a which means you'll be listening to only one channel of the stereo output. In any case, make sure before connecting the speaker(s) to the computer that speaker power is off and volume control is at minimum. Connect the 3.5mm cable end to Line Out 1 jack of the X-Fi sound card and either the XLT or TRS ends to the speaker(s) input(s). Play some audio content on your computer, turn on speaker(s) and slowly increase volume to a safe level. Everything should work fine.
Let me know how it goes.
cancerags
Dec 28, 2007 | M-Audio Studiophile BX8a Speaker
Speaker problem
Hi, Assuming that the speaker is plug in to the PC and power is also applied to the speaker - If the PC sounds comes out of the headset but not on the speakers, then the speakers are defective. Being new/recently bought, your best course of action would be to bring the unit back for replacement or at least the speakers since trying to repair it would void the warranty. Please remember to bring proof of purchase, warranty card or whatever document(s) are required for this sort of complaint. Good luck and kind regards.
Aug 20, 2007 | HP P5302M Computer Speakers
279 people viewed this question
 Grubhead
Grubhead
