Question about Averatec Sotec 3120X, 3120V hard drive caddy (SOTEC3120X3120VHARDDRIVE) Drive Case
Laptop wont stay on
I turn on my laptop and it turns off before the winows xp loading page pops up and when i plug in the charger the green light on the charger keeps on blinking. and normaly it doesnt blink.is it something to do with the battery?? i also had it on the bed on standby all night does that have anything to do with the problem??
    Sergeant:
  • 191 Answers
Ok. first insert the power cable and remove the battery and try starting the computer. If it still goes off when windows is loading then its a virus and reinstalling the windows would be the solution but if it continues to windows then its from the battery.
Posted on Aug 02, 2010
Why wont my Gateway NV53A36u turn on ?
if your charger is ok then it will be a problem with the dc jack (where your charger plugs in to) or your actual motherboard.
Jul 29, 2012 | Acer Gateway NV53A36u
When the battery is fullly charged will the light on the charger go off or turn a different color other than green
i've seen so many of these batteries where when you plug in the charger the light stays green, theres three possible reasons for this
1. Charger is not putting out enough volts. check the charger with a multimeter and make sure that its putting out at least 13.8 volts
2. the battery connectors uner the blue plastic housing have come disconnected. you'll have to pop off on side of the battery and reconnect then
3. dead battery. replace the battery
Jan 08, 2011 | Peg Perego 12v Battery
When I plug it in to charge the red and amber lights stay lit and the green flashes and if i move the joystick everything is backwards push forward goes backwards left is right. b4 when it was plugged in...
sounds like a charger inhibit problem. Whenever you charge your chair the charger inhibit shuts down the chair so it can't be moved while charging. If you are getting this then that function is not working. Lets try this if you know of someone who has a chair or scooter with an off-board charger see if you can borrow it. Plug the off-board charger into the charger port located under the front of the joystick (don't have the on-board charger plugged in) and then turn the charger on. turn the chair's power on and you hopefully will see the lights blinking again indicating a charger plugged in (charger inhibit) the lights on the charger should be red and yellow (yellow turning green when fully charged) If you still get the problem with the off-board charger then your problem is in the controller or power module and this requires a new one. If Medicare paid for your chair you can call Repair Xpress @ 1-877-81-3733 or Roadrunner Mobility @ 1-800-467-2668 to have them fix it for you and bill Medicare for most of the repair costs. Hope this helps you
Oct 31, 2010 | Invacare Pronto M51 Power Wheelchair
Charger model FY 4101 green light stay lite all the time, and hoveround battery is still dead
When the green light stays on regardless of dead battery, this means the battery is defective. The battery must present a load to the charger, which causes the charger voltage to drop, turning the charger on. When the battery is defective, it will not load the charger, and the charger voltage stays at full charge value. This of course, causes the green light to be switched on.
Sep 16, 2010 | Electronics - Others
Laptop wont charge
Remove the battery and try again. If it solved the problem the battery is shorted and must be replaced. Look at the plug in the back of the laptop for the power. Is it lose? if it is lose you have a short from it touching contactd together and it must be replaced. If neither of these work try using a loner power supply to see if it is that. The D600 has lots of Power problems on of witch is the Motherboard itself. Hope this helps you out.
Jun 06, 2010 | Dell Latitude D600 Notebook
The battery wont stay charged .when you plug it in to charge the green light comes on ,when fully charged the red light is on,when you turn it on no power
If the charger is automatically giving you a green light when you plug in the charger, the batteries are most likely damaged and will no longer take a charge. This can happen when the power chair is stored and the batteries are not charged for a while. The green light on the charger indicates the battery is full, but instead of being full of power, its full of crud. Try to replace the batteries and see if that will solve the problem.
Mar 30, 2010 | NRS Hoveround MPV 5 - Used Power...
Wont turn on
my pc no reconoce the driver the usb vx6000
Jun 10, 2008 | LG C2000 Cellular Phone
Computers & Internet Logo
76 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
