Question about HP OfficeJet 6310 All-in-One Printer (Printer/Scanner/Copier/Fax) w/USB Printer Cable , Retail
How to I check the ink levels on my printer? I have the hp officejet 6300. Help
    Sergeant:
  • 191 Answers
Follow these instructions
  • Open HP Solution Center.
    • Windows XP : On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista : On the Windows taskbar, click the Windows icon (How to I check the - c01364735.gif ), click All Programs , click HP , and then click HP Solution Center .
    • Windows 7 : Click the Windows icon (c01364735.gif ), click Programs , click HP , and then click HP Solution Center .
  • Click Settings , and then click Printer Toolbox .
  • Click the Device Services tab, and then click the Estimated Ink Levels tab.
    Posted on Aug 02, 2010
    5 Suggested Answers
    SOURCE: HP 5610 officejet all in one: how do i check my ink levels?
    Windows users: Turn on printer.....
    In the HP Solution Center, click Settings, point to
    Print Settings, and then click Printer Toolbox. Click the Estimated
    Ink Levels tab.
    Mac users:
    In the HP Image Zone, click the Devices tab. In the Select Devices area, click the icon for your HP All-in-one. In the Device Options
    area, click Settings, and then choose Maintain Printer. If prompted, select your HP All-in-one, and then click Utilities.
    Hope this works for you....Eye
    Posted on Feb 28, 2009
    ctau
    • 372 Answers
    SOURCE: how to check ink level on hp officejet 6210 all-in-one printer
  • Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  • The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • Posted on Mar 22, 2009
    • 146 Answers
    SOURCE: how do I check the ink level of my HP Officejet 6300 series?
    only wy to check levels is to install the software that is part of the printer it will give you ink levels as they go down
    Posted on Aug 14, 2009
    • 93 Answers
    SOURCE: how to check if the ink is ran out from hp
    If you have full installed HP program that came with Printer then you can find Ink Level using HPTool Box utility.
    another way is find out is that if your prints are comming light then its time to refill or buy new toner.
    Third way is to judge by Toner weight. if low weight means also there is low ink.
    Posted on Mar 20, 2010
    Hp officejet 4620 does not print with starter cartridge
    If printer is in warranty, demand for replacement.
    1. Check ink levels in printer..if levels are showing, take out all ink cartridges refill them.
    If levels are zero, go for new cartridges.
    2. If ink level are showing in printer & physically cartridges having ink, then problem with print head, try to clean the clogged nozzles.
    Nov 16, 2014 | HP Officejet 4620 e-All-in-One Printer,...
    How do i check my ink levels on hp officejet 4215 printer
    ideally diagnostics should return the info about ink levels.
    but in case they dont you can try below
    1. Hp Solution Center > Settings > print settings > printer toolbox > Estimated Ink level
    2. go to control panel->printers->go to priinter properties it should show ink levels
    Apr 11, 2012 | HP Officejet 4215 All-in-One Color Photo...
    How to check ink levels in a HP officejet J4580 printer
    Checking ink levels
    1. open HP solution center on the computer desktop screen
    2. click on settings on the bottom
    3. click printer toolbox
    4. click the estimated ink levels tab
    or
    1. on the printer control panel,push the wrench button
    2. press the right arrow to go to print report
    3. push OK
    4. select self test
    5. push OK
    It will print a page with color bars signifying correct ink levels.If a color bar is blank it means it's empty or depleted and needs to be replaced
    Jul 21, 2011 | HP OfficeJet J4580 All-In-One Laser...
    How to check ink levels for HP6500A Plus Printer
    Normally there are 2 different ways to check ink level on any HP printer
    First one is :
    IF your printer is HP Officejet 6500 Wireless AIO,
    Press Setup button ( ranch like symbol ) on printer front panel
    Use Arrow key ( left or right arrow ) till you find Tools option - Press OK
    User Arrow key to find Ink Level or Ink Gauge - Press OK.
    It should display the ink level.
    If it does not display ink level through this method, it could be for many reasons like printer is not aligned or one of the cartridge is not recognized etc.
    2nd method is from PC
    Click on Settings
    Click on Printer tool box
    Click on Ink level
    Regards,
    Ron
    * Please rate this solution with Thumbs up and Testimony to help us improve providing support
    Apr 20, 2011 | HP Officejet 6500 Wireless All-in-One...
    HP officejet Pro 8500. Replaced black/yellow cartridge and still get message "replace ink cartridge" thanks Tim 865-654-1702
    Here are some steps can help you.
    Use only New Original HP ink
    Restart the printer
    Rreseat the ink cartridges
    Update the firmware, download it from the link, make sure that you choose the correct operating system, and follow the on-screen instruction.
    Check the ink levels, click Start , click All Programs, click HP ,click HP Solution Center, click Settings , click Printer Settings , click Printer Toolbox, Click the Estimated Ink Levels tab, note which cartridge is low on or out of ink
    Restart the printer.
    I hope this will be able to help you resolve the issue.
    Thank you for choosing Fixya.
    Mar 16, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
    How to reset the ink level of my hp officejet 6500
    Checking ink levelsUse one of the following methods to check the ink levels. Method one: Check the ink levels from the HP All-in-One The ink level is displayed on the main screen of the control panel display. Locate the two icons that represent the print cartridges. The icon on the left is for the color cartridge and the icon on the right is for the black cartridge.
    • The exclamation mark (! ) symbol indicates a low ink level.
    • The question mark (? ) symbol indicates the product cannot determine the status of the print cartridge. This might be because the cartridge is refilled.
    Figure 1: Ink levels on the control panel displayc01362755.gif 1 - Exclamation mark indicates low ink in the color cartridge 2 - Ink level in the black cartridge is OK Method two: Check the ink levels from the computer using the HP ToolboxFollow these steps to check the estimated ink levels using HP Toolbox.
    1. Make sure the product is on and connected to the computer.
    2. Open HP Solution Center .
      • Windows XP: On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
      • Windows Vista: On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center .
      • Windows 2000: On the Windows taskbar, click Start , click Programs , point to HP , and then click HP Solution Center .
    3. Click Settings .
    4. Point to Print Settings , and then click Printer Toolbox . Printer Toolbox opens.
    5. Check the ink levels displayed on the Estimated Ink Levels tab.
    Figure 2: Estimated ink levelsc00670267.gif
    Jun 02, 2010 | HP Officejet 6500 Wireless All-in-One...
    How do I check the ink level of my HP Officejet 6300 series?
    Aug 14, 2009 | HP OfficeJet 6310 All-in-One Printer...
    How to check ink level on hp officejet 6210 all-in-one printer
  • Mar 22, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    Ink level monitoring on officejet 6310
    Yes. Never refill or buy refilled ink carts.
    Jan 31, 2009 | HP Officejet 6310 All-In-One InkJet...
    Ink Levels tab.
    Mac users:
    Jan 02, 2009 | HP Officejet 5610 All-In-One InkJet...
    Open Questions:
    See all HP OfficeJet 6310 All-in-One Printer Questions
    810 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
