Question about Acer Computers & Internet
My Aspire 5520-5043 began showing trouble to start: no power ligh
My Aspire 5520-5043 began showing trouble to charge. The ac adapter seems ok, but not always the green light on the notebook lights on (on the ac adapter is ok, the light lits...). Last days, no charge at all...
    Sergeant:
  • 191 Answers
Thats mean the charging system is faulty and sometimes there are breakages at the edge of the power cable where the pin is.try another power cable if it shows the same signal then the fault is on the laptop board.
Posted on Aug 02, 2010
Testimonial: "Thanks for the tip. I'm trying to figure out how to open the notebook - I found many videos on other models, but not on mine... Any links?"
  • untraceme
    untraceme Aug 05, 2010
    I suggest you take it to the tech department because opening of a notebook is a tricky thing if you are not careful you might destroy your keyboard.
AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
So your saying the charger will charge the battery, as long as the laptop is off...But when it is charged, you remove the ac adapter, start up the laptop, running on battery power alone, then hook the ac adapter to it, and the laptop cuts off..???
Apr 27, 2014 | Acer Aspire 8930G Laptop Charger...
I have acer aspire 5334. AC adapter plugged in but won't charge. Lights not showing on laptop and battery icon not showing its plugged in. Adapter rectangle box led light is on!! Is it charger, battery or...
You need to get the DC Power Jack Either Repaired or replaced...this is the "female" port where your AC Power cord plugs into.. To Repair the current DC Jack...First you'll need to look closely at the Positive posts to see that they are not broken.. If visibally ok.. then you can look at the Solder Connections.. they will need to first be Desoldered.. Cleaned, then Resoldered back in place.
Dec 10, 2012 | Computers & Internet
It just wont turn on i have checked the power lead and its ok its an acer aspire 5050 laptop
Hi. I would suggest you double check the ac adapter if the powercord is properly attach to it ot also you might want to try powerdraining or powercycling your computer. To do this you must turn off your laptop then remove the battery and unplug the ac adapter then press and hold the power button for 20 seconds while the battery and ac adapter is out, after that place back the battery and plugin the ac adapter and try turning on your laptop, if this doesnt work then try power draining it again and just use the ac adapter or just plug it in without the battery then try again turning it on. If it still has the power issue then try a known good ac adapter so that you could double check that it is not an ac adapter issue or a battery issue. If all that trouble shooting step doesnt work then you could also try calling acer tech support to help you on your issue if your machine or laptop is still under warranty they would help you fix it by sending that laptop to there depot without any charge. Hope this Helps
Jun 09, 2010 | Acer Aspire 5050-3242 Notebook
Acer Aspire 4730Z laptop
if ur charger is ok then u have need to change ur motherboard
May 02, 2010 | Acer Aspire 4730-4947 Notebook
Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
Sep 08, 2009 | Acer Aspire 4520-5582 Notebook
I HAVE A ASPIRE 5520 IT WONT START THE FAN STARTS AND THE DVD BUT IT JUST KEEPS ON LOPPING
I had the same problem but what you can do is...
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
  8. If its not the batery or AC adapter you might have to send it to Texas, just go to www.Acer.com
Jun 14, 2009 | Acer Aspire One PC Notebook
No signal prob...
some issue have to make sure
1) check battery charging indicate light on(yellow)
2) check AC adapter and DC jack connection if no bettery charging
3) check power on from battery or AC adapter that situation is same or not
4) take away HD DVD and change memory
5) plug extenal monitor
if no any thing show on the screen, you have to send to repair by the specialist.
Sep 27, 2008 | Acer Aspire 3100-1405 Notebook
The computer does not seem to be charging up
I am a Dell Certified System Engineer(DCSE)
try taking out tthe battery and then try powering the system only on ac adapter connected
if it doesn't power on only on the ac adapter make sure that the port on the system where you plug in the ac adapter for any kind of bent or broken pins
if the port is ok then get your ac adapter replaced.
Jun 10, 2008 | HP Compaq nx9020 Notebook
Computers & Internet Logo
99 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
