Question about Goodman Heating & Cooling
Hi I have a CLT30-1A external air conditioner unit. Problem: both the fan and compressor do not turn. A low frequency hum sounds when power is applied. Trouble shooting steps I've tried; 1. contact switch works and supplies 220 VAC across contact to motors 2. removed each motor from the circuit at a time but neither motors function. I speculate the capacitor is not functioning and does not "start" either motors. What do you think?
  • charles895 Aug 02, 2010
    Thanks. There is no timer unit between the mains and contact switch unit. I figure it is the capacitor. Thanks so much.
    President:
  • 949 Answers
If your contactor is engaged, as it sounds like it is and you have 220 volts going out of it. Then the capacitor would be the device to look at next.
An ohm meter test on both sides of capacitor should show its condition. In your case I would guess the common terminal is bad (open).
There is another device added on to some units, this would be a time delay. Where it pauses up to 10 minutes before letting the compressor and fan start. This prevents short cycling. Carefully follow the wires to see if there is such a device between the contactor and main wires. If not then you are left with the capacitor again as the logical failed component.
Let me know if you have questions.
Phil
Posted on Aug 02, 2010
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
Unit runs for about 5 min the cuts off. whats the problem?
Hi!!
It could be many things, the most common are Low R22 refrigerant, bad fan motor, bad compressor. obstructed condenser coil, bad starting relay, bad capacitor. among other things.
To check fan motor, set unit to HI Fan Only setting and let it run for a while, check that fan did not loose speed and it is not getting too hot.
If fan is OK, then turn unit to HI Cool 60-65 degrees and see what happens. Hear if compressor kicked in or if just made a humming noise and stopped. if this happens, replace capacitor.
Keep me posted!! Rate this post!!
Aug 14, 2010 | Kenmore 72055 Air Conditioner
I have my dometic Rooftop ac unit. The heatstrip/fan run perfectly but when I turn on the ac...the fan runs good but when the compressor kicks on it just hums.
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
May 09, 2010 | Dometic Rooftop RV Air Conditioner
Fan does not run. Low power hum audible.
sounds like you have a bad run capicitor on your fan check if the cap is swolen and or any oil around the terminals thats usualy a tail tell sind thats its bad
Apr 08, 2010 | Dometic Rooftop RV Air Conditioner
Carrier Compressor Issues?
When you shut it off and back on it slugged the compressor if you turn it off and back on before the pressures equalize between the high and low sides it will slug the compressor and it will not run should let sit for five minutes or so before restarting. The humming is either the compressor making noise usually common for the compressor to make some noise or the fan motor bearings are getting bad on the outside unit. If the unit works normal probably not much you can do till it breaks if it is the compressor it is more economical to replace the whole unit if it is just the fan motor it is worth changing. You could take an amp draw on the fan motor and the compressor to see if the are within the limits on the name plate of the outside unit.
Jan 25, 2010 | Heating & Cooling
The fan is not turning on my outside air unit but it is still blowing hot air through the vents. There is also ice build up at the bottom of the unit. It is making a humming sound.
You will need to replace the outside fan,or condenser fan motor.
Shut unit down,before the compressor gets damaged.
Without the condensor fan the heat will not be blown to the outside air and the unit will not cool.
You may be low on freon too,have it checked.
Jan 19, 2010 | Samsung AW0603B Air Conditioner
My Unit hums but the compressor never seems to turn on.
usually the humming sound is the compressor.is the fan running? If the fan is not running get on the roof and stick a long screw driver through the holes in the cover and move the fan. it may be seezed.
Jul 16, 2009 | Dometic Rooftop RV Air Conditioner
PROBLEM WITH MY AIR CONDITIONER
Is the outside unit running? if so can you feel warmer than outside air blowing from outside fan? If not your system may have a leak and pressures low. You can also check the piping to and from the unit larger one should be cold small one should be warm
Jul 03, 2009 | Whirlwind FH-778 Air Conditioner
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
Heating & Cooling Logo
299 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
