Question about Pool & Spa
We have refiled our lay z sap, after it dispaly shows 3 dashes
We have refiled our lay z spa (Bestway; 54075) after cleaning, it worked fine upto this time. When we switch it on the displays shows 22/23 degrees as normal then after a couple of seconds the dispaly shows 3 dashes and the heater light flashes red. From this point it will not do anything?
  • 990 Answers
You probally just need to break an air lock in the pipes. You can ether force water down the skimmer pipe or find your drain valve and open it for a minute or two till it runs just water and no air. This will get water to the pump and the heater. This should fix you up.
Posted on Aug 03, 2010
Bestway layzspa 54075 pump showing E02 error what is the problem and how do i fix
check to see if recirculation pump is ok if ok check heater element and temp sensor
May 29, 2017 | Pool & Spa
Cleaned the bestway chlorinater as per instructions but flow light blinks and turns red
Even if cleaned out, they stop working after 3-5 years anyways and must be replaced.
May 19, 2017 | Pool & Spa
Bestway Lay-Z-Spa
We sell the Bestway Lazy-Spa however we do not sell anything other than the replacement filter so I cannot tell you what is all included with that part number.
I would suggest you contact the store you purchased the spa from to determine the contents of the replacement item.
Rod
US Parts Center
Feb 12, 2014 | Pool & Spa
Lay-Z-Spa pump impeller replacement
In order to find the proper replacement you will need to provide someone with the following information.
  • amps
  • voltage
  • discharge size pipe
  • suction size pipe
Rod
US Parts Center
Jun 01, 2013 | Home
Lay z spa pump impeller replacement
Perhaps an inquiry of Lay Z Spa will yield an answer
Jun 01, 2013 | Home
My bestway lay z spa pump and heater unit has stopped working. Three lines flash on the LED panel and all the lights are flashing simultaneously. Non of the buttons work and I have tried re-setting the...
PDF Manual at the link below.
http://www.drinkstuff.com/products/pdf/lay-z-spa-owers-manual.pdf
All lights flashing indicate a fault with the pump.
This is a common fault with these units which the supplier blames on people not following the installation and maintenance instructions.
If you require any further assistance then please just ask.
Aug 01, 2011 | Kitchen Ranges
Lay z spa pump has E02 code which is water flow problem,have changed filter.flushed through ,set reset button but fault code still appears.
If this is an outdoor spa near trees, its almost a guarantee that the impeller is blocked with debris (pine needles can cause this in a hurry)
If the impeller is clean of debris and this is still happening, replace you pressure/flow switch.
Apr 27, 2011 | Pool & Spa
Bestway Lay Z Spa pump not working!
check recirculation pump and heater element
Oct 23, 2017 | Pool & Spa
Pool & Spa Logo
418 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
