Question about Compaq Presario CQ60-220US PC Laptop
Laptop powers on disk light flickers & does not start up. The fan is working.Blank screen, when connected to external screen still no output
  • 10,319 Answers
Upon turning the computer on keep hitting the F8 key and see if a repair screen appears. If not the hard drive is gone or the disply is at fault
Posted on Aug 02, 2010
How do i solve a problem with a Lenovo G555.
try connecting the laptop to an external screen if you can not get a picture then the motherboard is faulty
May 11, 2014 | Lenovo G555 Laptop
My laptop keeps flickering
First thing is to wiggle the lid and see if that affects it. If it does then the cable in the laptop that connects the bottom board to the display is bad. If it does not affect it, connect another monitor to the external connection to the laptop and see if it works. IF it does it might be the lights in the display that are going out or the power unit called the inverter that is in the lid
Jan 02, 2013 | Toshiba IBM 12P3878 THINKPAD T20 INTEL...
Connecting from laptop to tv wont work now. It was working fine previously
Check the display settings on your laptop to see if the external monitor output is disabled. There is usually a function key on the keyboard with a picture of a monitor on it which can be used to switch between internal & external monitors.
You may also need to try on another monitor/TV or change the HDMI lead.
Sep 27, 2012 | pcb Advent 5711 5431 Laptop M/b U41iix...
Blank screen
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 03, 2012 | Toshiba Satellite L505D-LS5010 Notebook
My samsung r519 wont turn on. when i press the on button i here the fan going, yet the screen stay's black and only the power light comes on. what could the problem be?
Does the fan stay running? if it does! it is probably a motherboard issue, if the fan is working correctly it should wind down, and if the hard drive is working "hard drive light will flicker" hook a external monitor to the video output on the back of your laptop if you see windows boots up then it would indicate laptop screen problem, but if the fan and the power light are the only activity then the motherboard is the problem.
Dec 22, 2010 | Computers & Internet
My MT3422 gateway will not boot up.
Sounds like an internal graphics problem then motherboard fault.
http://www.notebookforums.com/post2949935.html
Aug 03, 2009 | Gateway MT3422 RTL Notebook
Presario 700 has a blank screen. Started occasionally going to a blank screen, now it stay blank. Will replacing the hard drive correct this problem?
If the laptop appears to boot up and the hard disk is spinning and the hard disk LED is flashing then the hard disk is OK.
Then the fault could be a faulty video cable or connector or CCFL lamp or inverter.
Try reseating the video cable/connector that connects to the motherboard first.
If this doesn't work then to determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 16, 2009 | Compaq Presario 700 470024-192 Notebook
Ibm thinkpad t43 backlight inverter issue
Did you say the the video output flickers on and off when you connect an external monitor to the video output. If the inverter is faulty this would not affect the video output and the external monitor would not flicker but if the external monitor flickers it would point to a video card problem.
Jun 13, 2009 | IBM ThinkPad T43 Notebook
Boot problem on inspiron 1150
Try connecting it to an external monitor.
When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
If this works, then it means the laptop screen is bad.
If it doesn't, the most likely cause would be that the laptop video card went bad.
For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Compaq Presario CQ60-220US PC Laptop Logo
333 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
