Question about Hitachi Heating & Cooling
Hitachi Cooling/condensing unit RAS-5144C/RAC-5144CV not cooling, has been regassed worked at first sounds as though the compressor is not working
Speed boy
  • 76 Answers
SOURCE: York Mini-Split Not Cooling? : (
This can only be a gas problem.
the split units goes on on and off if a shortage of gas is involved, the chances that you would here it wont be that big for the fans would make too much noise.
get a repair man for a re gas and all is well.
Good luck.
Wouter.
Posted on Oct 22, 2008
  • 2692 Answers
SOURCE: Need a new remote for my Hitachi RAS-12UH Ductless Split
http://www.hitachi.com.au/productsearch.aspx?pId=62&
Posted on Jan 08, 2009
notsomot
  • 67 Answers
SOURCE: hitachi
I would really call your installers back mate.
If you have anything to measure air temp with I will take you though some tests.
But at this point I would say that your air con does not have any gas and the installers should come back. If they will not come back you should contact Hitachi warranty
Hope this helps
Posted on Jan 11, 2009
  • 534 Answers
SOURCE: Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Posted on Aug 04, 2009
Testimonial: "Yes, it's dual run capacitor problem. I used a stick to spin the fan blades and it starts to slowly spin and up to normal speed, so motor is good."
  • 14 Answers
SOURCE: trane split air conditioning -XIL 14 MODEL- no
shot of freon or loose signal wire between condenser and wall unit
Posted on Sep 03, 2009
Hitachi Refrigerator not working: cooling is not happening, freezer also stopped working please help
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 17, 2011 | Refrigerators
Hi, I have Hitachi model: RAS 63CHA4/RAC 63CHA4 The indoor unit looks working for the fan function, but not for the other function. The fan on the outdoor unit looks not working. What is the problem?
Is your compressor is working? If so, check motor to rotate manually. If hard to remove, replace bearings or motor. If easy to rotate, replace capacitor.
If your total out door is not working, check for power in out door unit. If not communication error between indoor and out door, provided you keep in right setting. If so, replace your indoor PCB.Helpful?
Jan 15, 2011 | Hitachi Heating & Cooling
My Hitachi indoor unit model RAS-26CHA1 is not giving out any cool air. The fan is working and have checked via manual. But manual does not have a trouble shooting section. Can you please assist me in...
To get cool keep temp setting 23 degree and mode in "cool" position. After compressor start, keep your hand on discharge pipe line (Smaller pipe), if it's warm your unit is starting cool. And also check with Amps meter for reading as per in name plate with the unit. If amps very less than specified, it's under gas leak.You have find out leak and arrest. Then charge gas.
Dec 28, 2010 | Hitachi Heating & Cooling
Hi my Hitachi Quadricool Win ac cooling does not
service and checked the gas you see ice is coming or not on cooling coil
Jun 12, 2010 | Hitachi RAS-09UH Air Conditioner
Blowing out warm air
Turn thermostat switch to 'cool' setting. It's a 'heat pump' and is in the heat mode.
Nov 05, 2009 | Coffee Makers & Espresso Machines
Hitachi
Hope this helps
Jan 05, 2009 | Hitachi Heating & Cooling
Hitachi Soleus split Not blowing cool air.
if the freon is 410a the pressure must be 100-120psi,if it is 22 the pressure must be 45-55psi.you unlucky because hitachi havent problems with compressors.is it inverter the unit?if it is you must check the outdoor pc board,if the 4valve clicking in the you must replaced it propably has stucked.
Jun 19, 2008 | Hitachi RAS-09UH Air Conditioner
Hitachi model number unknown !! (faded 0ff unit)
dirty unit and need for cleaning
clogged up expansion valve
defective fan motor
deffective air sensor
May 22, 2008 | Hitachi RAS-09UH Air Conditioner
Heating & Cooling Logo
530 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
