Question about Acer Computers & Internet
I have an X241W monitor that after being turned on, has to warm up for about 10 minutes after being turned on, at which time I have to turn it back off and then back on again in order to see the "ACER" logo appear on the screen, which is part of the usual start up process. Any idea what is necessitating this involved start up process?
  • 319 Answers
Www.avsforum.com › ... › LCD Flat Panel Displays
Posted on Aug 02, 2010
My X241w until recently required about 10 or more power ups before it would stay on without shutting itself off. As I was getting ready to replace it I tried setting the resolution to 1980x1080 in...
It may have a lot of dying caps as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/ACER%20X241W/
More damage will be done if the caps get real bad.
The size of this monitor is big but I find the picture quality is not too good.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Mar 19, 2011 | Acer X241Wsd Monitor
Monitor needs a long warm up time before ready to use. computer turns it on but it blinks off. after about 10 to 15 minutes the monitor will stay on.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
http://www.badcaps.net
Apr 04, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
No Signal
yes start the computer then keep pressed the key F8 untill the display comes then hightlight the option last good known configuration and select the problem will be solved
Mar 06, 2010 | Acer 22" X223w LCD Monitor
I get "No Signal" shortly after the computer is turned.
there is a problem by the programming chip insifde of monitor. It can be faster fixed but only by an expert. If i've help you, please rate me! Thanks
Sep 15, 2009 | Acer AL1916W 19" LCD Monitor
Dim monitar with flickering screen
The problem can be caused by 1 of 2 things either your power supply is going out or the backlight bulbs are going out. The most likely cause is the power supply. If you are willing to do a little soldering you should be able to do the repair. If you go to our web site at: www.ccl-la.com/badcaps.htm We have a section on monitor repair. Look under the Samsung 930B it is the same as your monitor.
If you don't want to do it yourself we do offer a repair service, email me if you are in need of that.
I hope this helps.
Buddy
Aug 05, 2009 | Computers & Internet
It turns off after 10 minutes working
When you say it turns off, is the power light going out too?
If the power light is still lit when the screen blanks, it may be a faulty backlight inverter.
After 10 minutes elapse and the screen goes out, if you power it back on, do you get another 10 min, or does it last a much shorter time period, or not at all?
Your best bet is probably simply to buy a new monitor, and sell yours as "broken" on eBay, I'm sure someone out there capable of fixing it would be willing to pay pennies on the dollar to subsidize your replacement screen.
Jul 03, 2009 | Gateway FPD1965 19" Flat Panel LCD Monitor
No display
I think the problem is on the resolution, or you can change the video card, but if its happen to another computer..then u have to contact the ACER support center
May 27, 2009 | Acer Computers & Internet
Monitor comes up shows "acer" then says no signal and goes black
This Problem is Acer(s) Monitors. Though it is a nuisance one fix That has work for many is the Unplugging after it goes back to Good (viewable) screen.
I have hooked mine up to an inexpensive Power strip to make it easier for me and just turn off at time indicated above and Viola Simple is as Simple does :)
Apr 24, 2009 | Acer X241Wsd Monitor
Screen takes time to warm up
this issue is typical for capacitor failure internally in he Monitor, it can be fixed, it will require soldering internal components let me know what you want to do
Jan 26, 2009 | Gateway FPD2275W LCD Monitor
Sony hmd-a400 monitor
Next time you get it running, right click my computer>properties>hardware tab>device manager and look for your monitor on the 'Monitors' '+' sign and right click>delete. Also check 'Display adapter' see if the correct driver is displayed. Re- boot and let Windows re-install monitor driver(it should list it as 'Sony')
Nov 30, 2006 | Sony HMD A400/L (Blue, Silver) 19 in.CRT...
Computers & Internet Logo
196 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
