Question about Nikon Coolpix S50 Digital Camera
Nikon Coolpix S50 has screwey autofocus when I shoot close-up. I select my subject, center it within my frame, depress the shapsot button half-way in order to initiate the autofocus function... The camera then begins to slide between out-of-focus, to in-focus, then keeps on going to out of focus again, and then slides "back" to an out of focus position! I understand that it is "looking" for the sharpest image as it does this--- but what it consistently selects is NOT the sharpest image! Ideas?
  • Kirby Aug 03, 2010
    I have a better understanding of how the camera focuses, but my problem has not been solved. The advice, "Have your camera serviced," is not helpful because *I* am the person who services the camera: I bought it used and non-functioning, and have already opened it up twice, disassembled it and reassembled it back to working order twice (it originally came with a "Lens Cover Error"). If there is something about the innards that needs to be looked at, then *I* am the person who is going to look. But I would like some direction before I begin, if I can get it. That is why I am here at FixYa.
  • 4,472 Answers
First off what do you mean by screwey autofocus? And how close up is close up? Have you tried changing the AF assist settings?
k Autofocus
Autofocus may not perform as expected in the following situations:
• Subject is very dark
• Objects of sharply differing brightness are included in the scene (e.g., the sun is behind the
subject and is in deep shadow)
• No contrast between the subject and surroundings (e.g., when the subject is standing in
front of a white wall, wearing a white shirt)
• Several objects are at different distances from the camera (e.g., the subject is inside a cage)
• Subject is moving rapidly
In the situations noted above, try pressing the shutter-release button halfway to refocus several
times, or use focus lock (c 99).
l AF-assist Illuminator and Flash
If the subject is poorly lit, the AF-assist illuminator may light by pressing the shutter-release
button halfway, or the flash may fire by pressing the shutter-release button all the way down.
Posted on Aug 03, 2010
    Genius:
  • 1,040 Answers
while shooting close up set ur cam on macro mode. Cam have focus range. focus range means the object distance from the lens
cam has focus range. For ur model on normal mode the focus range is 30 centimeter . anything placed between 0 to 30 cm will not be focussed and also close up range have focus i.e. 4 cm , anything placed between 0 to 4 cm will not be focussed....
by follwoing above rules, if u get the same problem, then there is a focussing problem in ur cam, get it serviced....
Hope this has helped you... Thanks....
I have a Nikon Coolpix P500. I have to depress the shutter release button several time to get it to snap a picture. The indicator light shows a fully charged battery.
Did you change (unnoticed perhaps) anything to the settings?
Be aware your camera needs a little time to focus. And when conditions are bad, like little contrast in the subject or bad light conditions, the camera needs more time to focus.
Please try to shoot in automatic mode. Then when you have a subject press the shutter release button half way. Look if you framed correct and then press fully. This way every time the camera should click.
Jan 30, 2014 | Nikon COOLPIX Cameras
The Auto focus in my D90 does not work
Does it shoot in manual focus? In which autofocus mode(s) does it not shoot? Are you trying to focus too close, or on a subject with insufficient contrast?
Apr 09, 2013 | Nikon D90 Digital Camera with 18-105mm...
I have a brand new nikon coolpix s3000. it's on full-time auto focus. Any ideas?
You can change this in the menu while in shooting mode. This is from page 48 of the manual:
Choose how the camera focuses.
A (auto) M d (Shooting menu) M I Autofocus mode
A Single AF (default setting)
The camera focuses when the shutter-release button is pressed halfway.
B Full-time AF
The camera focuses continuously until the shutter-release button is pressed down
halfway. Use with moving subjects. The sound of lens drive movement will be heard
while the camera focuses.
Sep 28, 2010 | Nikon Coolpix S3000 Digital Camera
How do i use the burst mode on my nikon d3000? Thank you.
Press the Info button to bring up the Information display. Press the <i> button to place the cursor in the information display. Highlight the current release mode and press OK. Select the Continuous mode and press OK.
This lets you shoot at up to about three frames a second, depending on the shutter speed, noise reduction settings, and autofocus settings. You cannot use this with the flash.
The camera will shoot pictures as long as you hold down the shutter release button (until the buffer and/or memory card fills up). As you shoot, the viewfinder will show rNN where NN is the approximate number of further pictures you can shoot until the buffer fills up. In JPEG mode you should be able to take a hundred pictures before the buffer fills. The number will be smaller in RAW.
In AF-S and AF-A, the camera will not shoot the next picture until focus is acquired, so when shooting moving subjects or panning the camera, you may not get full speed. Even in AF-C, the camera may "hiccup" occasionally.
Mar 15, 2010 | Nikon D5000 Digital Camera
NIKON D70S IS SHOWING r09 ON TOP LCD FRAME COUNTER AUTOFOCUS IS SPINNING BACKWARDS THEN FOWARDS BUT WONT SETTLE AND SHOOT,HOWEVER WORKS IN MANUAL FOCUS MODE HELP PLEASE.
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed
Regards
Smilemaker.
Jul 20, 2008 | Nikon Cameras
Slight blur shooting variety of subjects
It is just a possibility but you may have overrode the auto focus. If you accidentally move the focussing ring it disables the auto focus.
Mar 17, 2008 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
What am I doing wrong?
This depends on which Autofocus system that particular model uses.  Then manual should tell what is happening there- there is usually a more comprehensive manual on the supplied CD.
Failing that speak to the user support of you particular model
Oct 25, 2007 | GE E1040 Digital Camera
Nikon Coolpix 5700 Autofocus
you need to fix the flash or get an external flash
Oct 19, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix S50 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
