Question about Omron H3CA-A Multifunction Digital Timer
Using an OMROn H3CA timer on an oven. I need to
Using an OMROn H3CA timer on an oven. I need to turn the oven on for 3 hrs , off for 3 hrs, and keep repeating this cycle. What settings should I use?
A thru G, and time input and choice of S,M,H. Your answer is very appreciated. Ken
2 Suggested Answers
  • 5245 Answers
SOURCE: omron H3ca
Delay timers usually start with a push button, or momentary impulse of power. The delay begins when the impulse power ends.
H3CR-A is solid state multi-functional pin timer available in 8-pin and 11-pin models.
11 pin has six modes, and 8 pin has 4 modes
http://waterheatertimer.org/pdf/OMRON_H3CR-multi-function-analog-sell-sheet.pdf
How many pins do you have?
What exactly are you controlling with the timer?
And what function are you using?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Sep 05, 2012
How to connect an omron h3y timer into a circuit
I see your comment to ignore:
To protect timer, read following:
1) Max load on this timer is 5 amp at 240volts
http://waterheatertimer.org/pdf/Omron-H3YN0302.pdf
2) If load exceeds 5 amps, then use timer to control contactor.
Here is crude drawing showing basic wiring for pin timer controlling heavy amp load.
http://waterheatertimer.org/images/10-pin-wiring2-1000.jpg
3) If amp rating on incoming wires exceeds 5 amp, for example is circuit breaker feeding circuit is 20-30 amps etc, then protect wires to timer using busman in-line fuseholder with fast-acting 5 amp cartridge fuse.
Dec 03, 2012 | Omron Healthcare Omron H3y-4 5 Second...
How do I program the H5CX ASN timer to turn on 5 mins and off 25 mins in an endless cycle. I don't understand the term Output Mode so from that point the instructions become meaningless.
Omron:
https://www.ia.omron.com/support/
http://waterheatertimer.org/pdf/h5cx_sell-sheet-wiring.pdf
I believe you have 230Volt 50 Hz electric power.
Omron is rated 50-60 hz
US timers are rated 60 Hz.
Maximum load on Omron timer is 5amp at 230 volt
Timer should be connected to 2-pole contactor (relay) instead of directly connected to pump.
http://waterheatertimer.org/images/contactor-drawing.gif
Does Amazon sell percentage cycle timer in your country?
A cycle timer makes one full revolution each hour, or 4-hours, or 12 hours. Then percentage is set for 8% for 1 hour cycle.
Contact Intermatic and ask if they have 50 cycle percentage cycle timer, or ordinary cycle timer in 50 Hz.
Nov 22, 2012 | Omron H5CX A AC100-240 Multifunction...
Omron H3ca
Sep 04, 2012 | Omron H3CA-A Multifunction Digital Timer
I need a wiring diagram for an Omron H5CX-A timer
Wiring will appear on side of timer.
Test the timer with multimeter to see which terminals are connected. When timer has no power, then Com and NC terminals will have continuity.
H5CX-A Timer has 11 screw terminal connections and timer is rated 100V to 250Volt AC 50-60Hz.
Input is power IN > this is the 100V to 250Volts coming from breaker box or transformer. For example input terminals might be labeled A and B.
This will give power to timer, but remainder of screw terminals have no power.
To put power to relay terminals, jumper the power from Input terminal A to COM terminal.
For example Com terminals might be 7 and 9.
So jumper Hot wire from Terminal A to terminal 7.
This action will put hot on Com terminal 7, but also give power to the NC terminal.
For example the NC terminals might be 1 and 3.
So when timer is OFF, the NC terminal has power.
Then when timer turns ON, the NC terminal no longer has power, but the NO terminals are Hot.
NO terminals might be 4 and 6, and these terminals turn on-and-off when timer turns on--and-off
Open following link to help with Omron 11-pin wiring:
http://waterheatertimer.org/How-to-wire-pin-timers.html
Jun 14, 2012 | Omron Hardware & Accessories
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
I have a ge electric built in single oven which had a grease fire
Its possible that the wiring harness to the door switch got a little too hot and have shorted. What I would do before I call a technician is to unplug the oven or turn the power off to it for a few minutes and then plug it back in to reset the control board. If you still get the error, I would recommend calling a service professional.
Apr 03, 2009 | GE JTP20 Electric Single Oven
Chnage in programming profile
to solve the programming problem I down loaded instructions forhte timer and adjusted theprograms till I got the results i expected.
Jan 15, 2009 | HRS Omron 9.999sec-9999hrs 100-240vac...
Sharp Microwave R-520L stopped working
My parents had the same problem. It turned out that a switch went bad. When you take the case off, there are 3 switches where the door latches. The bottom switch went bad. It is an Omron D3V-16G-3C25 switch.
Nov 13, 2008 | Maytag MMC5000 Microwave Oven
Omron H3CA-A Multifunction Digital Timer Logo
Top Omron Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you an Omron Hardware and Accessory Expert? Answer questions, earn points and help others
