Question about Garden
My generator doesn't idle, it serges continuasly. How do I adjust the govener and idel stop screw?
  • 8,404 Answers
Don't fiddle with it. Put a load on it and see what happens. If it still surges, put a bigger load on it. If it still surges, seek professional repair for this product. You can do more damage to both the generator and what ever you poser if you do fiddle with it.
Posted on Aug 02, 2010
My bike idels really high all the time ive played with the idel screw and it still does it could it be the jetting?
When you say you've "played with the idle screw", do you mean the idle MIXTURE screw, or the idle SPEED screw?
Also, it COULD be the throttle cable.
At idle, is there a LITTLE slack in the cable, so it's not pulling on the slide/butterfly crank?
Or, it could be cable routing, hanging up on something.
Finally, has the cable ever been lubed?
Jan 30, 2014 | Yamaha YZ 250 F Motorcycles
Hello, I installed my 10 kw #5871 guardian yesterday 2/24/11. The propane pressure was checked at all loads and never dropped. It is set at the manuals recommendation. At mid to full load it runs smooth...
I had to find out through a Generac Service Tech that the Idle screw needs to be turned down so it doesnt surge. I found this out after a surge blew $400 worth of electronics out in my home. I have a surge protector now I recommend you do the same. DG
Feb 25, 2011 | Guardian Electrical Supplies
Where is the idel adjustment for 1989 1200 sportster
the idle adjustment is the big screw on the side of your carb, usually in the middle or at the very end, there will be two screws, one is for your idle speed one is the air intake, it is usually the biggest screw that controls your idle :)
Aug 01, 2010 | Harley Davidson XL 1200 C Sportster Custom...
I have a 63 caddilac with a 390 and a 4GC how do i ajust the idle all i see is a fast idle ajustment and the idle air and fuel mixture screws
you will have to ajust the fast Idel down an then for the Idle air an fuel screws up till it Idels even. If it does not Idle even you have went to low on the fast idel. Only adjust the screws a quarter turn at a time till you get it to purrr like a kitten. I also have one of those an had the same problem.Luckily my father is a master mec. for caddys,ford,chevy,dodge,etc.He can pretty much listen to any car made ever imports an fix whatever is wrong. Hes 74 years old an thats all he has ever done is work an build old cars.
Jul 13, 2010 | Jada Toys 1963 Cadillac Series G2 1:18...
I can't get the idel set on the McCulloch Mac130 chain saw. It runs wide open. When you try to idle it dies out.
Try turning the L needle CW to stop (lightly), then back out CCW 1-3/4 turns. Turn the idle speed screw CW about 1 turn. Start the engine and let warm up. Set the idle speed screw so that the engine keeps running but doesn't pull the chain. Turn the L needle CW until the engine runs fairly smoothly, yet allows the engine to 'follow the throttle'. Make sure the H needle is adjusted at full speed for 4-stroking, but immediately 2-strokes when starting to cut wood. If the above idle mix (L) adjustment doesn't help, you will likely need to clean the idle jets within the carburetor. Hope this helps!
Mar 13, 2010 | Garden
I replaced the injecter and now it idels to fast the idel adjustment screw has no effect on it
disconnect the battery and plug it back in. sometimes it may take the vehicle a couple of runs for it to reteach itslef.
Feb 18, 2010 | 1997 Dodge Intrepid
Rough idle then stalls
Vacume leak or bad idle motor. With the car in park and running with the hood open listen for leaks moving your hand around the different hoses looking for a change in the sounds that you hear. The idel motor also makes the car idel up to 1500 RPM or so right at start-up then idel down, If it doesn;t the idel motor is likly. Check engine light is on when running? Test for codes, Follow code test charts don't skip any steps!.
Nov 02, 2009 | 1998 Chevrolet Malibu
Volts to high
in order to set voltage you have to adjust the govener idle screw , that is what helps regulate the voltage, the higher the motor revs, the higher the voltage, the lower, the lower the voltage. the govener arm is normally a gold color arm with a small rod connected on top of the block. it should have a screw with a nut, or just a screw. turn counter clockwise, then ck voltage output,repeat till desired voltage. i usually, set mine at about 124, because once you put a load on it, it will bring the voltage down some. hope this fixes your problem. let me know. troy
Sep 27, 2008 | Electrical Supplies
Garden Logo
74 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
