Question about Asko Washing Machines
ASKO washer model W600. Drum stopped spinning. Water starts to fill. When drum is moved manually it makes a strange sound (resists moving. doesn't turn smoothly). Machine clicks to "S" fault code
  • 1028 Answers
SOURCE: Kenmore 417.2942992 Spin Cycle Rattle
possible rear bearing gone
Posted on Jun 06, 2008
barkencoa
  • 3463 Answers
SOURCE: WFC 2260 - Machine Fills and empties, but drum doesn't rotate
You probably need to replace the brushes in the motor.
Remove rear panel, remove belt from drum, undo 2 screws securing motor, unplug lead to motor, lever motor back with a screw driver, keeping hold of it, and remove motor.
You will find the brushes located at the opposite end to the motor pulley.
Please leave a fixya rating for my proposed solution.
Thankyou.
Posted on Feb 04, 2009
SOURCE: Asko W600 won't spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
The clutch may be worn. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Mar 21, 2009
Macmarkus
  • 2605 Answers
SOURCE: washer fills and drains, but the drum does not run
Joe, Thanks for the prompt reply. OK, it sounds like one of two possible culprits, 1) the belt has broke or spun off. 2) the brushes in the motor are worn...although the initial symptom of this is typically manifest in "no spin" so I'd lean towards a broken or spun off belt. You'll need to remove the rear panel for a visual inspection to confirm or dismiss either possibilities. Let me know what you find out. If the belt is off check for possible reasons "why" ? It can be a loose drive pulley, ( the large one, not the motor pulley ) or simply an unbalanced load on the previous wash, just a heads up since you're looking around in there anyway. Of course the belt itself may be worn ( stretched ) or broke and thus at fault as well. Good luck, I'll watch your post. macmarkus :)
Posted on May 04, 2010
  • 57 Answers
SOURCE: The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
Posted on May 18, 2010
Set a cycle, it will go around and around until manually turn the off button.... Nothing working, fills up, but does not spin.
Sounds like your circuit board has a problem. go to www.repairclinic.com. Look up washing machines and enter your model number, then a list of parts show up, they have a trouble shooting column. They have videos and the parts you will need.
Mar 10, 2015 | Asko W600
I have a maytag LSE7806AEE that stopped after filling the washing machine with water. I have tried everything to get it started but it will not respond.
since you can get water going, power is ok. Once water is filled, it should start automatically. Sine the drum is not moving to wash the load, it is down to drum mechanism. BTW if you manually move the knob to spin what happens?
Aug 06, 2013 | Washing Machines
Asko w600 front load washer did not spin water out of clothes. I emptied the drain pump and now it fills with water but doesnt wash the clothes. The water drains out but nothing else. Help
Check to see if your model has a "out of balance" micro switch.
If it's tripped from you moving the unit around you may have to reset it manually. It will be mounted somewhere close to the outer perimeter of the tub. Can't say exactly where. Could be high or low.
Jul 11, 2012 | Asko W600
I have an Asko W600 front load washer that does not spin water out of clothes. It fills, washes, empties but does not spin- skips this part.
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the door lock-switch assembly. If the door lock-switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 15, 2011 | Asko W600
Drum will not spin
I am the new owner of a used Asko Cylinda 10504.
The last owner briefly demonstrated the washer starting a wash cycle and entering the agitation cycle of the wash before stopping and pumping the water out and spinning in a final end cycle. I bought it. I had the machine installed turned it on and cannot get it to go through the wash cycle. After starting at #1 it goes through a perpetual spin cycle of sorts--water and soap soaking the drum and laundry but not enough water to fill up half way or less. It stops at number 4 on the program knob sits on a red dot (next to the #4) and does nothing. I then manually move it to the next cycle and it repeats the spin cycle again until I have advanced the program to the end. No wash cycle no rinse cycle. Nothing. When it advances to the red dot I wait for at least 5 minutes before manually advancing the knob. The instructions say that I should get the water pumped out by turning the program knob to #7 or #9 but in both cases it just spins and does no empty or finish in the end spin cycle of several (9?) minutes. Nothing but banging and spinning. The water seems to get into the drum as well as the detergent but nothing else is happening.
No mater where I start the program it spins and sloshes soapy water, pumping almost nothing out.
Any suggestions short of putting it on the curb or paying a kings ransom to fly a tech out to look at it?
MY GUESS.
It seems that it is repeating the same brief cycle over and over. During the move to my house the electronics re set(??!?!?) and now need to be set to the normal mode after being re connected?
Can you help?
Blessings,
Douglas
May 20, 2009 | Asko Washing Machines
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Asko 10505 runs through was cycle in approx. 30 seconds, then wont drain. Simply stops. It doesnt matter which cycle I start with, the dial moves quickly to stop. It fill with water and spins. ANY HELP...
hi sir' start the wash machine empty and see if it happens when nothing is in it.
2. When machine is off, open the top grab the centerpiece inside the wash machine and pull and push it slowly, does it move? (For safety unplug the machine)
3. Make sure machine is 100% level (front to back, left to right)
The most common thing is bad drum bearing, which force the wash machine out of whack when in spin / wash. Which are common and the best thing is to call Maytag.
thank u .........................................please rate
__________________
Sep 11, 2008 | Asko Washing Machines
Washing Machines Logo
56 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
