posted by gregpm on Apr 25, 2008
i'm having problems with the heater of my edgestar, when i get it running for a few minutes it quits and i get an e5 error message
the airconditioner seems to be working though.
Solution #1
posted on May 06, 2008
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
There are 3 possibilities beginning with the most likely problem
1) If your heater heats up for a few minutes and then quits, chances are there is a blockage in the air flow, check for dust and grime blocking the air intake coarse filter , airgun blow to clear accumulated dust and otherwise clean the coarse filter .
2) If the heater fan blows but there is no warm air, the heating element needs renewal ( this happens very rarely)
3)If the fan stalls and the heater heats up and the thermostat kicks in, then this will be not be a DIY job. This is least likely as you said the air cooler works.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for EdgeStar 12,000 BTU Portable Air
Email this problem
Email this problem
Can you Help with these Air Conditioners problems?
EdgeStar 12,000 BTU Portable Air Conditioner...
water leaking
water leaking
I have an edgestar 13,000 BTU... Answer This...
portable air conditioner 10000
I am looking for a dependable... Answer This...
Repair Service
Find Air Conditioner Repairman Near You:
