Question about Home
Gainsborough energy 2000x Electric Shower. Electricity supply OK Water supply OK Hose and Shower head OK No hot water output Moving the control knobs has no effect other than switching off. Power & Reduce Temp neons illuminated
brainyass
  • 242 Answers
SOURCE: Gainsborough Shower Running Cold
It sounds like you have a faulty thermostat or broken heater element.
Posted on Oct 23, 2008
hessmar
  • 5 Answers
SOURCE: hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Posted on Dec 04, 2008
  • 4 Answers
SOURCE: No water coming out of shower
First you should check the screens st the ends of the hose to be sure they are not clogged. The shower head as well. Otherwise it could be the water control valve, solenoid or thermal cut off.
http://www.theshowerdoctor.com/shower-spares/gainsborough/energy-2000x.html
Posted on Mar 03, 2009
  • 9 Answers
SOURCE: Cold water only from single-arm shower faucet in master bathroom
Yes - This is an easy (though not widely known) diy fix! Remove the cover of the faucet handle (may pop off if crystal type or use a screwdriver to remove the screws) inside there is a scald guard safety mechanism - using a flathead screwdriver, turn the guard some the left. There should be a guide so that you do not turn the water up too hot. If there is not, you may need to consult a plumber or supplier in order to adjust the hot to a moderate temperature.
Hope this helps! ;)
Posted on Aug 28, 2009
  • 123 Answers
SOURCE: Remove and replace a hand held shower head hose in whirl pool
Hey Rick........the connectors are just large nuts at each end of the hose. If you remove one of the connectors there should be a a ring slipped around a grooved part of the hose with a plate. If you remove the clip the plate should slide off enabling you to remove the hose. Let me know if you need any more help.
Thx
Ken
Posted on Sep 01, 2009
Why is my Gainsborough 2000x shower not heating the water passing through?
I sounds as if the element has failed... if you isolate the power to the shower you could test the element with a multimeter..
Apr 18, 2017 | Gainsborough Home
One of my HG shower systems has increasingly lower volume. The shower head and supply hose are fine. what should I check next?
If you are using water in another part of the house most times the pressure at the bathroom shower will go low. For instance if some one in the kitchen draws water in the kitchen sink this will make the shower water even turn cooler because of low pressure. Flushing the toilet will also do the same.
Most houses are plumbed with half inch water pipe and would work a lot better if it was three quarter inch to give more water pressure.
Jan 12, 2015 | Hansgrohe Home
I have a gainsborough ps1600 shower. Water pressure has dropped. Doesn't help when head is removed. Can still adjust temperature but not speed/power
If the water pressure dropped at a sudden moment, it sounds more like an issue with the water pressure leading into your shower, and not a problem with the shower its self. Try seeing if other water sources in the same area of your shower have the same low water pressure issue.
Stained Glass Leaded Glass St Petersburg FL
Jul 12, 2014 | Home
Got a gainsborough shower no water is coming out when i switch it on and the low flow light in coming on
inside the shower unit theres water connection to unit ,turn the water and power supply off and check the water conn filter its on the connection comming into the shower its most prob blocked good luck
Feb 18, 2011 | Hardware & Accessories
Hi, Advice please, my shower when on hot comes normal out of the shower head but when water temperature normal it stream out of the bottom of the wall fitting, gainsborough shower 2 years old approx....
If you are taking about then neck of the shower head this is what you must do. its no need to turn the water off to the house or to the bathroom first you will need a pair of channel locks and some Teflon tape. first remove the shower head if you dont want to scar the nut on the shower head place cloth between the pliers and the fitting, once removed (very important) turn the channel locks upside down stick one side of the blue handle up in the neck of the shower and rotate to your left to loosen if you are having a leak leak there it should already be semi loose, once removed wrap the threads with the Teflon tape and re-insert making sure it is tight, then wrap the the outer end of the neck with Teflon tape and place the head back on.The reason it leaked is because the plumber who installed it did not tighten it up completly because he wanted it to look straight coming out of the wall and the additional water pressure causes it to leak wheras the hot water causes it to expand and seal
Jul 08, 2009 | Water Pik Wall Mount Shower Head
Mar 02, 2009 | Home
Oct 08, 2008 | Home
We have installed a rinnai water heater in the basement. Since it takes a little time before the hot water arrives in the kitchen or upstairs in the shower, we are wasting qite a bit of potable water every...
The only way to reduce water waste would be to have a plumber install smaller pipes coming from the water heater to each individual point of use. The normal way of plumbing a house uses a large pipe that has smaller pipes that go to each sink, tub, shower, etc. The larger the pipe, the more water is in it and the longer it will take to get hot water to where it is going. An electric tank won't save you from wasting any water unless you have a separate hot water circulation system installed. This would keep the hot water drawn out to the far ends of the plumbing system and allow the hot water to reach it's destination alot sooner. However, keeping a tank full of water hot is not economical and a circulation system basically turns your pipes into a radiator causing you to waste electricity. I know it may seem that you are wasting alot of water waiting for the hot water to get there, but in the long run you and the environment are coming out ahead due to the saved energy and efficiency of the Rinnai unit. Also just in case you were thinking of it, a circulating system is not compatible with a Rinnai water heater.
Jun 19, 2008 | Rinnai Heating & Cooling
Home Logo
123 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
