Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Ice chute door
Thanks for your help.
The make is Maytag
Model # msd2353kew
Is there a site I can go to for detailed instructions on how to replaces the solenoid?
Thanks again
    Scholar:
  • 150 Answers
Yeah its called "fixya" the solenoid is part #whi67006000 available for 11 dollars and change @ appliance parts depot. to change the solenoid you pop the trim around the dispenser area off with a putty knife and then remove the cover behind to access the solenoid. you might check for voltage to it like I mentioned before you order parts. it isn't hard. as far as a numbered step by step procedure I don't know look around but what I have given you should work for you good luck
Posted on Apr 25, 2008
THE ICE MAKER PRODUCES LOTS OF ICE HOWEVER WHEN I PUSH TO DISPENSE ,ICE COMES DOWN THE SHOOT BUT DOOR WILL NOT OPEN TO RELEASE.tHE WATER FEATURE WORKS FINE ON THE FRIDGE .i HAVE REPLACED THE DOOR SEAL BUT...
There is a small motor on the outside of the freezer that you can see if you look up inside the door opening for the water and ice. It may be a silver color and is not very big. On a Whirlpool it is between the ice chute and the water outlet. Also, sometimes the ice chute door freezes shut.
Mar 25, 2015 | Maytag Refrigerators
Frost builds up on the chute betwen the icemaker and the door dispenser unit.
I need you to confirm your model number. Is MZD2665HE correct? The problem is very likely a broken 12565502 Dispenser Door Spring or more providing you have the correct model number. There may be a kit if the model number is different.Thanks, John Tripp Appliance 911
Jan 31, 2014 | Maytag MZD2665HE Side by Side Refrigerator
Underside of ice bin freezes up built up with frosty ice, dispenses no ice. numerous times we have defrosted with blow dryer, removed, cleaned bin, replaced; cleaned out ice that was built up in lower part...
W10224328 Dispenser Door Spring
The chute door is the reason your ice bin is freezing up and also the chute door being open draws warm moist air inside your freezer compartment causing massive amounts of frost and keeps the compressor runing all the time between defrost. You really n eed to get the chute door fixed. What is the correct model number? For the model KSRX25FT dispenser parts click HERE The chute door spring may be broken but you will not know untill you open the dispenser housing. I'm here should you post the correct model number or have questions, Sea Breeze
Oct 17, 2013 | KitchenAid Architect ® Series II KSRX25FT
My refrigerator won't dispense ice cubes or crushed ice or water at the front door, I was wondering if it could be the Touch pad control panel on the front of the refrigerator. If it is can you give...
The front touch pad board /panel which you are referring is called dispenser board.To access the dispenser board assembly, click this link below:---
http://howtobyme.blogspot.com/2011/06/ge-side-by-side-refrigerator-will-not.html ------------ The dispenser board removal procedure is mentioned at the last on the link instructions.-------- -------------- But the engineer at your place has pointed you to right direction.The main control board is most probably the cause of problem.One more important thing.There are many other users too facing same problem with there ge side by side refrigerators.This problem occurs in many ge model refrigerators. There was service letter released by Ge for this problem.Click this link, to read the letter:--- http://howtobyme.blogspot.com/2011/07/ge-side-by-side-refrigerator-wont.html -----------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 28, 2011 | Refrigerators
Our frig ice cube door chute keeps slaming and the lights are going crazy on the push button board. model MFI2568AES SER 10967637JR
Your control board is bad. Unplug refrigerator and replace it, follow instructions on board to reprogram and you should be good. It's on the back outside of refrigerator under panel. Or, call a repairman to do it for 400.00 plus. Hope this helps,
Oct 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Door dhute not opening to let ice fall
on the right hand side of the door chute there is a little metal barrel that needs to be attached to the end of the arm that holds the ice door. this is attached to the spring that opens and closes the door chute.
Apr 16, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice chute door on maytag refrigerator
the door is opened by a solenoid. it is bad or it is not getting voltage due to bad control or wiring
Apr 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Shorted control board dispenser
Look and see if the door for the ice chute is closing all the way. This model is bad about that door breaking. If it doesn't shut properly then warm air getting in will cause this condensation. Will also cause ice in bucket to melt and water can leak onto these parts. If it isn't obviously hanging open then shine a flash light from the inside down the chute and see if any light comes thru to the outside. Maytag has a chute door kit that you can find on appliancepartspros.com. Their part # is AP3140440. Let me know if this helps or we need to go further.
Oct 09, 2007 | Refrigerators
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
