DVDs will not record on my Tosiba RD-XS32SB DVD recorder.
  • 138 Answers
Have you tried other DVD+r -r media ? how about a rewritable DVD, erase it first then write.
Posted on May 07, 2008
DVD unit says, disc is empty, with all DVDs inserted. DVDs are correct region and correct type, and they playback fine in other DVD units. I have already reset the unit per the Toshiba tech support site. I...
First, insert the DVD into the recorder.
Then, try double-click on OPEN/CLOSE button on the remote control. You have to make it very quick - two quick clicks on the same button. If done correctly, you will first see OPEN, then CLOSE in the right corner of the screen.
When done successfully, the unit will recognize the DVD again (if the burner has not failed totally.)
I tried that with RD-XS55 (it has the same DVD-RAM drive as RD-XS35.) It is not perfect solution, but it might help temporarily. In my situation, it bring my dvd drive back to "life," so I do not need to do double-click all the time.
Let's face it, your burner is dying whether you like it or not. And new replacement would cost you around $200.
Nov 06, 2009 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
I need a user manual for a Toshiba RD XS 25 DVD Recorder
Go to tesc.toshiba.co.uk select "customer access" on bottom left, then select what model, etc and there you go.
Mar 12, 2009 | Toshiba RD-XS25 DVD Recorder/HDD Recorder
Hi, I have a toshiba RD-XS52 that requires a firmware update before HDMI will work with newer model TV. Have tried to download and run update link provided by tosiba with 10 pouched discs. Any thoughts?
I tried the firmware found on Toshiba Canada website, it doesn't work. I believe the US version of RD-XS52 firmware is not upgradeable. The site said the firmware is for RD-XS52SC. You guys got it to work?
Jan 19, 2009 | Toshiba RD-XS52 DVD Recorder
Toshiba dvr will load some dvds & not others
My machine has also done this since it was new. I was just about to bring it in for repair when I thought I would try one more thing. I turned on the recorder. I put in the movie that would not play and let it load (of course it would not load). I pushed the on/off button on the recorder and held it down until the "wait" message came up on the display. After the message disappeared I turned the recorder back on. To my surprise the movie loaded and played. I tried all the other movies I had trouble with and they also played. I hope this helps. I saved my self over 200 dollars in repair bills. I was quite surprised at the lack of help from toshiba.
Dec 06, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
I am unable to find dvd disks that will record to my two toshiba dvds RD-XS32 OR RD-XV45 CAN YOU HELP
RD-XS32
DVD-R
DVD-Rw
http://www.videohelp.com/dvdplayers?DVDname=RD-XS32&Search=Search&dvdportable=&dvdchanger=&dvdtv=&chipset=&orderby=Name&hits=50
RD-XV45
DVD-R
DVD-RW
The link tells you about the first player. It says that this player is really picky with discs but people have had success with 4x vertabrim DVD-R discs. The link also has some information on a firmware upgrade to improve the DVD-R/RW selection of discs which the player accepts. Coudn't find much on the second player though other than a french manual which told me what it accepts which i've put above. Hope this helps.
Aug 19, 2008 | Toshiba Televison & Video
Toshiba dvd recorder #rd-xs35
The full manual can be downloaded from http://www.tacp.toshiba.com/dvr/product.asp?model=RD-XS35
The cable box hook-up is on page 22. There are two ways: 8bc47e0.jpg
Oct 25, 2007 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
HDD Corrupt
I have the XS35 and the HDD drive is curropt. Can I do the following?
1. Download the Toshiba firmware update:
http://www.tacp.toshiba.com/customersupport/model_firmware.asp?model=rd-xs34
2. Burn the ISO to a CD-R disc. ImgBurn is an excellent free burner for this.
http://www.imgburn.com/
3. Insert the CD in your unit. It will auto-install the firmware. Follow onscreen instructions. Takes about 10 minutes total.
After the update, my existing HDD shows are playable again, and I can record and playback from the HDD. I bet it would be a good idea to periodically backup your shows on DVDs, and regularly reformat the HDD.
Mike
michaelz@resourceinternational.com
Oct 18, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Toshiba tech support for this one. If it is not accepting the cleaner disk - you have to wonder if something is already intere or do you mean will not rune the disk? Inwhich case it is a drive failure and needs replacement[of drive if available] or whole machine. Contact Toshiba first though it may be a known issue.
Jul 05, 2007 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
