Question about Mtd Garden
Hi sit down mower a MTD 13BA508N600 (2003) clutch removal problem
Hi
My sit down mower a MTD 13BA508N600 (2003) model requires the PTO clutch changing which engages the cutting blades I've purchased a replacement clutch however I cannot remove the main locking bolt as the whole PTO clutch spins how do I stop the whole component spining to allow me to remove the bolt.
Many Thanks
Tony
boscia
  • 163 Answers
SOURCE: tractor?troy bilt/mtd 2002
the electric clutch that operates the blades needs replaced
Posted on Nov 30, 2008
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 95 Answers
SOURCE: prob with PTO on craftsman mower 917.273372
There is a idler pivot plate on the mower that must be cleaned and lubricated regularly, from the left side of the mower deck if you look in the middle of the mower deck while someone engages the mower(with the engine off) you will see the pulley try and move,there is a 3/8 bolt that comes up through a bushing that this pivots on, soak that area with wd-40 and see if that improves the movement. Be sure not to get any wd-40 on the belt or pulleys. Always try and keep that area clean and lubed.
Posted on Jul 30, 2009
  • 95 Answers
SOURCE: Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Posted on Jul 31, 2009
huffman49
  • 235 Answers
SOURCE: Riding mower stalls when PTO is engaged.
check the kill switch and the wire it could be that a small piece of the covering came off and is grounding to the deck or frame there by killing the engine the jerkink of the mower maybe whats causing the wire to come into contact with metal..good luck
Posted on Apr 03, 2010
How do i change the drive belt on my L 130 ?
Remove the mower deck first.
Remove the electric PTO clutch assy.
Disconnect the clutch spring as to remove the tension on the drive belt.
From there it a simple matter of removing the belt from the pulleys. Depending the belt retainers you need to them too.
Aug 02, 2014 | Mtd Drive Belt 42"
I need part no. for manufacture date 2005 cub cadet lt 1045 modle ps-sv600 0009 pto clutch
I have a 2005 Cub Cadet LT1042, Spec. No. PS-SV590-0003, but my parts manual also lists part numbers for the LT1045. The clutch part no. given for your model is 717-04174.
Hope this is helpful.
Paul
May 10, 2013 | Oregon Scientific Electric PTO Clutch for...
Does the electric pto clutch on a model 1024 have oil inside of it
Hi, the pto should be dry, the oil would have come from the engine somewhere. Most likely the main crankshaft seal. Regards Phil.
Jul 05, 2012 | Oregon Scientific Electric PTO Clutch for...
I have a rzt 54 cub cadet, when i engage the pto it cuts breifly then the mower shuts down PLEASE HELP
A battery going bad may be your culprit. I found out just the other day that your mower can keep running but when the battery gets too weak, the pto clutch disengages and shuts down,
Apr 29, 2012 | Oregon Scientific Electric PTO Clutch for...
How to remove pto clutch on cub cadet model 2186
unplug it remove the center bolt and remove the bolt that stops the clutch from rotating
Apr 23, 2012 | Oregon Scientific Electric PTO Clutch for...
MOWER blades WILL NOT SHUTOFF
sounds like a electro clutch engage type system
maybe your electro-clutch engage switch is faulty or a wire is connected the wrong way
was the clutch replaced recenlty and was is compatiable ?
or maybe you have a faulty clutch to test try
remove plug lead from plug
disconnect wires @pto clutch and apply 12 volt directly to clutch then remove voltage - if clutch engages then disengages the clutch is good it should click on then off if it does then its a switch fault
replace pto switch
cheers paul
hope its helps
Aug 08, 2010 | Oregon Scientific Electric PTO Clutch for...
Require replacement clutch for MTD RH 135\105 B
Hi I am Kelly and welcome to FixYa. I am having difficulty crossing your model number. Do you know what year you purchased the mower?
I have found a close match at this site using model year 1995
http://www.jackssmallengines.com/help.cfm
You need to choose these drop down window options in the order listed on the site:
"Search for Model"
MTD
MTD GOLD
13-Lawn Tractors
1995 Models (There are 3 of them... so I would bet you will have to find the closest match to your model)
After all of the above FINALLY the model diagrams will come up.
There is another drop down menu just above the Zoom + or - buttons for the sub assemblies.
I am thinking this is what you were looking for but... if not please check your model number again and I will continue to assist you.
Thanks for choosing FixYa.
Kelly
Jul 21, 2010 | Mtd LAWN MOWER PART # 642-04032 TINE...
How do i get the upper pulley above the pto clutch
I've yet to remove these in one piece...even when I smeared anti-seize all over it. You can try a 3 jaw puller, but you'll most likely end up just bending the pulley. The pulleys are about 25 dollars locally in my area. Honestly, i just air chisel them off, and buy new every time i change drive belts.
Jun 09, 2010 | Oregon Scientific Electric PTO Clutch for...
Deck belt does not engage blades on riding tractor
Be sure the belt is the correct size and is routed correctly.
If you are not sure, you can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need the model & serial numbers.
Apr 18, 2009 | Oregon Scientific Electric PTO Clutch for...
Garden Logo
43 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
