Question about Brother HL 5140 Laser Printer
I get a speck of ink 3 3/4" apart, 1" in from the edge of the paper on both sides. They are not on the same horizontal line. Is this something on the drum. I have tried wiping the drum , but no change.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
This will happen after there was a jam and a paper was pulled out and it didn't go throught the laser to seal the ink. Now a spec of ink is somewhere on the printer. Open the back door of the printer and wipe it all over there (make sure the printer is unplugged.) Then turn the roller in the ink cartridge all the while wiping it. Clean the inside of the printer where the toner is. These are all the steps to clean the printer from the spec. If the spec is still there then the toner will have to be replaced.
Good luck!!
Posted on Aug 02, 2010
Why won't the printer print .5" margin on the side
1. The side guides of the paper tray are adjustable and should be snug to the edges of the paper. To loose and things can begin to shift.
2. Are you using letter sized paper or A4. Your print driver and word processing program need to know this.
3. The driver and processing program have margin adjustments within them. They are usually good by default but perhaps another user was in there and changed things.
4. Is the print job specked for the correct orientation....portrait or landscape and is the paper loaded the same.
Jul 25, 2014 | HP Office Equipment & Supplies
Brother hl5470 toning on side of sheet
most likely Toner problem. Check also if the Drum does not have any Toner material glued on it
Feb 07, 2014 | Brother International Brother HL 5470DW
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon 9950F has lines vertically
Although the problem sounds like a defective CCD, which is not repairable, I would strongly suggest you take the unit back apart and clean it again.
Why?
Because one single speck of dust on the mirrors will cause a vertical line like the one you speak of.
Here is a trick I use to clean the optics on copiers:
1) Get a low lint rag or shop towel NOT a paper towel, tissue, etc
2) Get a bottle of Windex. The stuff with ammonia works better on optics.
3) Spray the Windex on a corner of the rag. Make sure it is very damp.
4) Clean the mirrors/optics horizontally from side-to-side, making sure to get the corners.
5) Use the dry portion of your rag to soak up any residue. Once again, go side to side, not up and down.
6) Shine a flashlight on the optics and make sure there is not a single smudge or speck of dust. If there is, go back to step 4.
Also make sure to clean both sides of the glass.
Good luck! If my answer helped you, please rate me and comment. If not, please follow up with me. Thanks!
Aug 27, 2009 | Canon CanoScan 9950F Flatbed Scanner
My Pixma MP830 is printing horizontal lines of various width across the page when printing or when copying from a single sheet laid on the glass.
Hello sir; what you need is cleaning, you neeed to clean prnt head and ink cell, you open the top part let the ink carrier move to the center then UNPLUG the power cord ,now you can easy to clean ink cell.
Aug 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Printer is putting a 1/2 dark black line on the back of the pages
dear friend
looks like problem related with refilled cartridges
are you using refilled cartridges??
if yes then you have to check whether they are leaking or not,
if they are leaking, you have to maintain cleaning level
thats all you can do
thanks
Apr 10, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Xerox Copycentre C123 Creating a Ghost Image
First place an original on glass and make a copy -- mark #1. With that same original on the glass, move the exposure all the way light and make a copy -- mark #2. Again with the same original on the glass, move the exposure all the way dark and make a copy --- mark #3. Place #1 in the middle so the the copies read --- #2, #1, #3. The #2 should be the lightest and #3 being the darkest. If #2 is darker than #3 you have a developer problem and you need to call for service. If #1 and #2 are bad and #3 is a good copy your machine probably just needs a good cleaning, mainly the optics and charge units. If all 3 copies are still poor with the speckles, your are looking at the PCU ( photo conductive unit) also called the drum unit. You can order this unit online -- it is a customer replaceable item.
Jan 04, 2009 | Xerox CopyCentre C123 Black and White...
Canon image runner 3300
Most likely something on the glass. Even a small speck on the glass will cause a horizontal line across the sheet while using the top feeder. Otherwise it would be the drum unit or a scratched fixing film.
-jen
Oct 29, 2008 | Office Equipment & Supplies
New printer cartridge in Lexmark 8350; blue lines on pics and papers
In Lexmark printers the ink cartridges can get clogged sometimes. Re-cleaning the nozzles might help fix your problem. Make sure your ink cartridge is not getting empty.
Hope this helps.
Jul 29, 2008 | Lexmark X6170 All-In-One InkJet Printer
Copies print with horizontal lines
thin lines? spaced about 1.5 inches apart could be toner left on the drum, take the cartridge out turn it over and retract the shutter, manually turn the drum using your thumbs on the edges of the drum, do you see thin lines on the drum? sometimes something sticky gets on the drum attracting toner and then it transfers to the paper during the copy process
Dec 20, 2007 | Office Equipment & Supplies
Brother HL 5140 Laser Printer Logo
37 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
