Question about Hotpoint Dryers
Grinding noise-- on and off.
Has grinding noise when in use. Particularly with heavy loads. Occurred in last month. Only use it maybe once a week.
    President:
  • 3,773 Answers
This is probably the front AND/OR rear bearings. The front bearing
is felt with slides and fits around the front of the tub.
The dryer has to be disassembled to get at either one.
See if the top panel has hinges in the back if so then all you have to do is raise the top panel to look at the front bearing.
If this was helpful please rate me.
Leo Ponder
imufo2@sbcglobal.net
Posted on Aug 02, 2010
Noise coming from one wheel - sort of a grinding noise but not consistemt
Can be three things
worn wheel bearings
stone in the brakes (most likely)
worn or incorrectly fitted pads
Jack the car up, spin and look.
Jul 10, 2016 | 2004 Hyundai Santa Fe
Have a 98 Jeep Grand Cherokee used cruise control last week made a grinding noise I turned it off truck went slow for a few now it will not accelerate past 50mph what could be wrong?
Nothing in the cruise control system to make a grinding noise. It is electronic or maybe with yours vacuum controlled. Or a little of both. This could just be coincidental. If it did die, it wouldn't keep you from going faster than fifty. Have the engine and transmission codes read.
Jun 13, 2016 | Jeep Cars & Trucks
Under heavy load, driver slips, makes grinding noise. How to fix?
Sounds like the gears are worn out. Not worth fixing. But if you buy a drill that uses the same battery pack, now you will have a spare battery and charger.
Jul 18, 2014 | Dewalt 18v Cordless 1/2" Adjustable Clutch...
Grinding noise when starting '98 Izuzu Rodeo
Upload video please then i might have a better idea
Jul 15, 2013 | Cars & Trucks
Grinding noise with heavy load
sounds like a problem with the bearings,have it checked out by a service engineer
Dec 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Got an OE error, now it will not finish rinse and spin, sounds like it is grinding in the spin cycle and the timer is stopped at 27 minutes remaining. What is wrong?
The problem is in the drain system as what error code OE stands for.The grinding noise is coming from the drain pump. Loose change, hair pins and the likes can get into the pump filter and sometimes into the pump impeller causing a grinding noise during the spin cycle because the pump works while the machine is spinning. The pump impeller may also be broken causing the grinding noise.
Disconnect power then open the filter door on the bottom left of the cabinet.
Remove the drain plug and drain the water out completely into a shallow basin or the likes. Once drained, lay a piece of towel under the filter then turn the filter knob counterclockwise and remove it. Clean the filter and reach in the pump impeller to check it if blocked or broken. If cleaning the filter does not solve the problem, you need to access the drain pump assembly and check the pump particularly the impeller thoroughly. Click on the link below for the detailed procedure in accessing the drain pump assembly.
LG Front-Load Washer Drain Pump Access
Dec 30, 2010 | LG WM2277H Front Load Washer
Washer suddenly stopped agitating and emitted a loud buzzing/grinding noise.Was able to get the water to drain but it won't do anything else except make the noise. I should probably mention that I had a...
A heavy load like a comforter and rugs should never be done in this type washer because it breaks the drive coupling. themobilian_537.jpgthemobilian_538.jpg
The good news is it is really easy to fix. I have a couple of videos here:
themobilian_539.jpgthemobilian_540.jpgthemobilian_541.jpgthemobilian_542.jpgthemobilian_543.jpgthemobilian_544.jpgthemobilian_545.jpgthemobilian_8.gif I have a manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 25, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
I have a long lasting grinding noise on heavy cycle
this is a cutting blade that helps cut up bigger debri that should have been washed off the dishes, you should not be able to see it if you are not taking the cover off,, where is the cover?? you might want to lacate this,, this might be your whole problem, it could be stuck under the dryer element, or lodged in undr the blade that throws the water around,, locate this and you might have found the problem
Oct 15, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Dryers Logo
66 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
