Question about RCA Video Cameras
RCA CMR300 the tape will not eject - RCA Video Cameras
4 Suggested Answers
ahhsoo69
  • 167 Answers
SOURCE: VCR does not eject tape correctly
hello. it's sound's like that the idler cam wheel that turn's the tape has a problem. it could be that .the wheel if made of rubber is slipping. or it has a belt on the bottem of it that is ***** out. check those two thing's .and let mre know if it has a rubber wheel .? or teeath that turn a gear. and if the belt on the bottem of it is not tight on the two wheel's on the bottem of it. let me know.ok "good luck"
Posted on Jul 03, 2008
  • 121 Answers
SOURCE: TAPE WILL NOT EJECT
Try unplugging the player from electrical power for several minutes. Plug the player back in and try to eject the tape.
Posted on Feb 26, 2009
lpfaff1
  • 11573 Answers
SOURCE: where is the eject button on RCA universal remote for DVD?
If eject not clearly marked on your remote it probably does not have the function. You can replace the remote for one that does have the function cheaply. Check packaging to make sure compatible with your equipment.
Posted on Aug 26, 2016
Where is the eject button on RCA universal remote for DVD?
Universal remotes do not necessarily replicate all functions of an OEM remote. EJECT is commonly not one of them. You may have to eject right at your Magnavox combo.
Dec 17, 2015 | RCA Televison & Video
Why does my RCA VR667 not accept a tape and returns a eject or stop message?
A couple of reasons. First the carriage the tape sits in is damaged. Next the mechanism that moves the tape is damaged and can't except a tape. Lastly or perhaps due to the later, the mode switch is faulty or not in the right position. The mode switch tells the electronics which position the mechanism is in, be it play, fast forward or eject etc. If the switch is faulty and stuck in eject then it wont except a tape.
May 11, 2014 | RCA Televison & Video
Tape Eject Mechanism
How much did you pay for the Camera? Want to send it to a Repair shop, or try to fix it yourself? I have links to repair manuals and one to a repair shop in Florida. Post a reply if you want those links.
Feb 10, 2014 | RCA Video Cameras
MY RCA VCR - TIMER LIGHT ALWAYS FLASHES. WHEN i TRY TO RECORD OR TURN OFF VCR IT EJECTS TAPE.
If it plays a tape OK, then it could be that you have a timer set. In which case clear it! Or that you are using a blank tape where the slot at the back is open. If you are using a blank tape which is good and it still ejects the tape after setting the recording. Then it's likely the recording tab sensor - that detects the slot at the back of the tape - is either bent or broken.
Feb 22, 2013 | RCA Televison & Video
Vcr won't let go of the tape when ejected
The tape is not being taken up quickly enough by the reel spool & therefore leaving "slack" on the tape which catches when you eject it. The problem will be with the clutch mechanism which sits between the two tape spools on the deck mechanism. Either it will need a clean or to be replaced.
Jul 14, 2009 | RCA Televison & Video
TAPE WILL NOT EJECT
Feb 26, 2009 | RCA VR639HF VHS VCR
Entire front panel does not work, but responds to control.
have you pulled the plug from the wall for a few minutes?
also, some vcrs will eject the tape when the RECORD button is pressed on the remote, and a tape is inside that has the record tab REMOVED!
good luck
Feb 07, 2009 | RCA VR622HF VHS VCR
Tape keeps getting ejected
This unit requires the rubber parts to be replaced. The loading sequence is not completing properly. The VCR will eject the tape when the sequence fails as a safety measure to prevent damage to either the VCR or the tape.
Parts cost for this should not be more than $10.
Dan
Feb 03, 2009 | RCA VR639HF VHS VCR
VHS Tape stuck and won't eject
you going to have to open it up and remove the tape manually, either the belt drive is broken or gears are.
you going to have to get your hands dirty. :)
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Jun 25, 2008 | RCA DRC8335
RCA VCR ejecting problem
TRY REBOOT -- UNPLUG CORD -- REPLUG -- GOOD LUCK !
Oct 31, 2006 | RCA VR639HF VHS VCR
Video Cameras Logo
231 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
