Question about Refrigerators
This is a old problem with maytag refrigerator, coil icing over I have changed the t'stat heating element assy,coil still ice over All fans are working, i removed adaptive defrost board and found it to be burnted by some resistors and I replaced with the substitute board (#61005899) but whe i turn on my temperature control nothing happens compressor will not start, so I install old burnt board and compressor starts it just wont activate the defrost cycle but ill do it if i jump it out by jumping leads L1 & test can anyone help? Model MZD2766GEB
  • Refrigerators Master
  • 3,247 Answers
Looks like the adaptive defrost board is a problem. The question is whether you had the correct replacement part. Best to confirm if the part shown on this link is what you have.
Posted on Aug 02, 2010
Maytag mzd2665he side by side coils inside freezer have ice build up
The defrost relay may be the problem,it also coud be the defrost heating element,you will have to remove the back panel inside the freezer side and do a continuity check on heating element if that has continuity then element is good,then the relay which is located on the wiring loop to defrost element is probably bad.locate a replacemant part and replace relay and that should solve the ice on the coils.
Jun 20, 2011 | Maytag Refrigerators
Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Apr 18, 2010 | Maytag MFD2560HES Bottom Freezer French...
2 year old Kenmore side by side refrigerator is too warm
the freezer feeds the refridgerator with cold air,when you open the freezer door,do you hear the fan blowing,if not you need to change the evap fan motor,next take out the second from bottom food bin and touch back wall,if you feel snow or ice you have a defrost problem, you'll have to take off back wall,advance the timer till it clicks into defrost and see if the heater comes on,if so you have a bad timer,if not read out the t-stat and the heater,if there are plug in wires on t-stat unplug them and bypass the t-stat by plugging t-stat wire to heater if heater comes on change t-stat,leave the heater on to help you defrost the ice off of evap coil and use hair dryer to melt ice,hope that helps
Nov 02, 2009 | Kenmore Refrigerators
Have a freezer on bottom fridge that keeps freezing where the fan is
defrost not working check defrost t-stat, timer, or heating element.
find timer and rotate till compressor turns off; defrost should start and melt ice, if no melting then check defrost t-stat ( round disc located nead heating coil) if you remove it and jump around it will begin to heat normally. If so then do not leave it jumped!!!!!!!! Replace it and you're done!!!!!!
Oct 24, 2009 | GE Refrigerators
Frigidaire Refrig. Freezer is working fine but Refrig is not cooling. The unit is only 2 years old - Help
, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
Freezer is frosted in back Refrigerator is warm
The problem is the defrost system located behind the freezer back panel.
The defrost system (AKA evap. system) is composed by an heating coil, a fan , and a defrost thermostat, and its function is avoiding ice formation on coil.
When defrost system is defective the fridge wont cool down properly
In your fridge , either evaporator fan, thermostat or heating element is faulty, and the ice on coils is preventing the appliance from cooling down properly.
Mar 29, 2009 | Hotpoint HSS25GFP Side by Side...
My U-line under counter refigerator ice maker evap fan failed
Depends, for the newer models, you can change the evap fan motor thru the front, but if you have the older model, then you have to remove the freezer housing, ice maker assy then the cover to change the evap fan motor.
Nov 13, 2008 | U-Line COMBO29FF Origin Series...
Maytag S/S model # MSD2756GEB
di you see or hear the fan running fan might be stuck check that out no fan no circulating cold air you may have problem with the heating element what make frost free inside you should melt all the ice inside around the damper check if you see broken glass the little heating element if it not broken and listen for that important fan if it running check it uot thank for using fixya pierre
Feb 05, 2008 | Refrigerators
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
