Question about Harman Multimedia HS 300 System
How to hook up my hs 300 to my (DVR)digital video recorder? Is "S" connection the best?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Harman Multi... Master
  • 924 Answers
Without specifically looking up your unit, here is the following order with the best quality at the end. Composite video(yellow connector), S Video, Component Video and HDMI. For more information, please visit my website at audioserviceclinic.com. Thank you.
Posted on Dec 09, 2013
How do i hook up my H.264 4ch DVR to my computer directly my router has upnp enabled
If you want to hook up the PC to play media, I suggest you install software called Plex for free (plex.tv). The Roku has the Plex app so you can play through the Roku or most smart TVs, Amazon Fire, or directly via an HDMI cable from your PC to the TV. It will automatically sort your media once you go through the setup and it is probably the best variant of the KODI/XBMC media systems out there for all platforms.
If you want to record from your DVR to your PC, that gets more complicated. The HDMI cord usually has certain protocols that keep you from recording copyrighted programs DMAC (Digital Media Access Control) so you'll need a video input card that has RCA inputs for red/green/blue or a yellow video input and either a red/white RCA input for sound or an SPDIF Infrared (IR) sound cable and use the software that comes with the tuner card.
Jan 15, 2018 | Swann Communications dvr-9000 DVD Recorder
How do i hook-up my vcr to my cable dvr to record saved shows
In order to record from VCR to DVR You need to connect "VCR audio/video output RCA jacks " to" DVR 's Audio / Video Input RCA jacks.. ..
use either "RCA analog (red/white+ yellow ) " or "optic " cable.(any standard optical cable )..if exist .optic is the best way to connect it..Remember your VCR 's "OUT" goes into" IN "of DVR ..
pls also remember,wherever you connect your VCR on your DVR ,you should switch the source selector accordingly to correspond to the connection on the back...
Now you can record anything on DVR which played in VCR ..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Motorola Televison & Video
Need to determine wiring connections from camera to dvr for Samsung SSC DVR
Hi
Thanks for using FixYa. Please see the link to hook up DVR with camera---
Hookup Camera with DVR
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 16, 2010 | Samsung SSC DVR Digital Video Recorder...
I need to know how to hook up my vcr to my dvr to record something off of it onto a vhs tape. directv said i need to contact the maker of the vcr & guess what RCA doesn't help with that. but i...
Ok. You connect the vcr to the televison first. Take an rca cable and connect it to the video out of the vcr then connect the other end to the av input on your television. Then take another set of RCA cables and connect them to the RCA av input on your vcr and connect the other end to the output on your dvr.
Now hopefully your tv has another RCA input you can hook directly to the dvr with another set of RCA cables to another one of the dvrs outputs. If not then don't worry about that.
Now make sure the tv is switched over to the av video RCA input the vcr is connected to and turn the vcr on. The vcr should be in input and when it is you will see the picture from your dvr and you will change channels with your dvr remote. You can now record using the vcr remote.
Jun 14, 2010 | RCA VR546 S-VHS VCR
What do i need to connect my canon zr500 camcorder to my pc?
IF, your camcorder has FIREWIRE, than you can use that, and suitable DVR software. IF not, then I always recommend that, one use a TV/Video "Capture" card or USB "Dongle", either way, you simply connect that up, via, the AV, leads, usually S-VHS, or Composite, Or Component, or Firewire, Use a DVR, and basically, "Play" the "Video" and "Record" on the PC, with Digital Video Recorder, DVR, and save as a "Digital Format" then you can do whatever you wish, after recording. You can get propretory software from the manufacturers website, and download, drivers, and software to do as you wish. I recommend a program called Dscaler, it is the BEST DVR there is.
Apr 28, 2010 | Canon ZR500 Mini DV Digital Camcorder
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Apr 05, 2009 | Sharp Televison & Video
Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
Mar 10, 2009 | Mitsubishi HS-U560 VHS VCR
Motorola VIP1216 DVR and Sony VRD-MC5 Connections for Recording?
I have the same problem currently. I have successfully recorded to the Sony CM5 in the past from my DVR, but no longer can. I have Comcast and wonder if they have changed the DVR firmware and blocked output. Also some broadcasts have something in the signal to stop recording. I got half of my program done, and can't record the rest on DVD. I will try to DVR local news, then record to the Sony, to see if it's a signal issue or something with the Sony. I haven't tried to record from a VCR.
Feb 12, 2009 | Sony VRD-MC5 DVD Recorder
Hard To Set Up
I don't really understand the question, but you can connect with any of the connections on the back. You can use a coax (cable type connection), the RCA jacks (yellow, red, white), s-video (black cable and red and white for sound), composite video (red, blue, green and red and white or digital for sound). The DVD will still record no matter how you hook it to the tv as long as it is connected to the SAT or cable correctly.
Dec 10, 2007 | Sony RDR-GX355
How Do I hook up my Sanyo DVW -7000 To my Dishnetwork Box to record?
Connect the "Out to TV"video and audio on the DVR box to the "Video in and Audio In" on the VCR ...unless it's a single screw type connector on the DVR then hook THAT to the "In from ANT/cable" on the VCR
Sep 08, 2007 | Sanyo DVW-7000 DVD Player/VCR
Harman Multimedia HS 300 System Logo
Top Harman Multimedia Audio Players & Recorders Experts
Steve
berggei
Are you a Harman Multimedia Audio Player and Recorder Expert? Answer questions, earn points and help others
