Question about HP Wireless Optical Mouse
Blinking red light on top of mouse. What does it mean?
  • 10,319 Answers
That is the light sensor that signals the usb pluging from the mouse's attachment so it can operate. When that light quits working replace the battery inside the mouse
Posted on Aug 02, 2010
Testimonial: "thanks for your help"
2 Suggested Answers
  • 27 Answers
SOURCE: why is the red button on top of the mouse
It sounds like your battery in your mouse may be low. I would suggest trying to put a new battery in it or charge it and see what it does from there! let me know if i can assist you more on your problem! thanx
Posted on Jun 08, 2009
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
Yellow blinking light
You need to change the battery.
Jan 16, 2014 | HP Wireless Optical Mouse
I own a Lenovo Mini Wireless Mouse (Model number N30). It has been working fine since the last 4 months I have owned it. However, I noticed today that the small light on the top of the mouse is blinking...
It's indeed the low batteries indicator. I have a Lenovo N30 myself.
I suggest you use a good pair of rechargeable AAA batteries.
They last longer than regular alkaline.
Best regards.
Source: Lenovo N30 User's Manual. Own experience.
Feb 17, 2011 | Lenovo Mini Wireless Laser N10 Mouse
The maning when the red light blink on the wall plug in for mices
I assume you meant, "The meaning".
When this light is blinking, this means the mouse is charging.
Nov 03, 2010 | HP Wireless Optical Mouse
My Logitech MX 1100 just stopped working out of the blue. The red battery light on top is blinking, so even though I've only been using this for a couple weeks (and the batteries were fairly fresh) I...
I had the same problem, brand new battery, the indicator light still blinking red. I finally got mad enough to shake the mouse kinda hard, and it worked. I then removed and replaced the old batteries in, it started blinking red again, but it worked after I gave it a couple of hard side by side shake. I do notice that there's something moving inside the mouse. It could be a connector that got loose. Hope this fixes your problem
Sep 25, 2010 | Logitech MX1100 LASER Mouse
The mouse keeps blinking red even though it is connected to the 1gb memory stick and the other part is connected to the mouse what does that mean please?
The mouse keeps blinking red even though it is connected to the 1 GB memory stick and the other part is connected to the mouse.
Sep 23, 2010 | Microsoft Wireless Mobile Memory Mouse...
Have a red light blinking on my cordless logitech mouse
mcdevito75 here, I have the same mouse and believe the red light at the bottom of the mouse means it's connected thru the keyboard to the computer.
Aug 09, 2010 | Logitech Cordless Mouse
I put in new batteries but no luck. No lights go ...
Answer:
With the buttons toward the top:
The top LEFT slider button is for power. Slide toward the outside for ON. Light on top of mouse turns green after about 1 second, and stays green for about 10 seconds (assuming the batteries are okay). When the batteries are failing, it blinks red.
The top Right PUSH button sends a connection signal to the PC. When pressed, the indicator light on the top flashes green and red, indicating the special connection signal.
This is the mouse side of the equation (good batteries, slider turned on, connection button pressed and released.).
NOW: the PC must have a working receiver, with drivers installed, and Bluetooth software installed. it sould detect the mouse. If it asks for a passkey, say none (mouse doesn't need passkey).
You should not need Microsoft Intellipoint. it doesn't have a configuration for this particular mouse model anyway.
Good Luck!
May 21, 2010 | Microsoft Bluetooth 5000 Mouse
Mouse optico doesnt work
dear,
The small notch in usb device socket under the mouse was malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
regards,
hope it will fix your problem
Jun 27, 2008 | Microsoft Wireless Notebook Optical Mouse...
HP Wireless Optical Mouse Logo
2,995 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
