Question about Tomtom GO 300 GPS Receiver
Tomtom go 300 u24 u25 and B
Hi....having problems working out what component B is ?
Can u help?
Thank you
  • 3 more comments
  • star_pilot Apr 26, 2008
    Hello, as mentioned earlier it is positioned next to component number 523 b240 and may be a reverse polarity diode.
    It is black in colour, 2 connections either side and has the capital letter B in gold stamped on with a gold line at one end.Its located 1cm to the right of the power jack socket.
    I am looking for a part number if u can help.
    Also, if only one u24 or u25 is blown, do u have to change bpth?
    Your helpis appreciated.
    Hi sorry, I have accidentally clicked fixya.
    It iss located in the area of the board with the number 5.And is the second component down on the opposite the on/off switch.side of the circuit board.
    Hope this helps
    Hi, thanks for your comprehensive answer. Judging by what you have said its the idiot diode.
    Can I remove this and bridge the connection?
    Thanks for your help..will bother u no more.
    One last question....can the idiot diode be removed and bridged across?
    Will bother you no more.
  • pelican1952 Sep 02, 2008
    Hi where can i get a IN414N
i have been lloking for IN414N without any luck..
any other ref ?
thanks a mill
Posted on Jul 08, 2008
    Novelist:
  • 158 Answers
Sorry , we need more info on position of what you call 'B' ? Which component are you reffering to ? I don't know component "B" .
Posted on Apr 26, 2008
  • 1 more comment
  • Ken Roberts
    Ken Roberts Apr 26, 2008
    where is component B on the board ?
  • Ken Roberts
    OK , here is best info I have as I have NO components in that area that are marked ? so , I do not see any components marked 523 or b240 , also I have NO components with a letter B on it. Comeponets that are black and like a small brick with a line across one end are either a diode or an electrloytic capacitor. On tomtom go 300 the component between power in socket and battery socket is BLACK and is simply a straight through filter. ie bothe neutral and live go straight through it. I can tell you that this very rarely blows. Usually it is only U24 and U25. Check also the small diode on the switch side but directly oposite the switch next to the 2 large diodes. ie. it is near to the power socket SOLDER SIDE of board. This small doide is the 'idiot diode' , revers polarity protection. I might add that most GO 300 boards I have here have very few component ID's screen printed on the PCB , theres hardly anything at all only the IC 'U' numbers and test points. This is why I am puzzled by your reference to 523 and b240. The 2 IC's U24 and U 25 dont always blow both , sometimes only one. look for signs of a small eruption on the IC or a tiny crack . Any brown mark or burning under the chip is also a sign. If you remove the IC's and have all the tracks intact you are very very lucky. GOOD LUCK.
  • Ken Roberts
    Ken Roberts Apr 27, 2008
    OK , now i see . The 2 large diodes are marked B240 . ..... looking at the PCB with switches at the top and the 2 diodes B240 bottom left. To the left of those and very close is small ceramic capacitor and just above that is the diode. ( this diode is about same size as the small capacitor ). I have also found this diode blown on some boards. You can replace this with a easy to obtain IN414N . this is a standard diode with normal lead connections but is small enough to fit . DO NOT BRIDGE ACROSS it, because this is the reverse polarity diode, this will introduce a short circuit. TomTom might work with this diode removed ( no diode ) but I have never tried this .
Viper components stop working window 8
I believe you will find the information you need here: http://www.fixya.com/support/viper/computer_components
Dec 31, 2013 | HP Computers & Internet
- Clean the browser history and cache.
- Remove unwanted tool bars.
- Update the browser.
After performing that if your problem still exists then simply download and run the program Reginout by using its system cleaner feature. Thanks
Feezer shut down with hi-temp alarm
Sounds like a defrost problem. Water came from frozen evaporator that thawed after being unplugged. It will operate great until evaporator freezes over again because it's not defrosting. Defrost components are defrost timer or Board, defrost heater, and defrost thermostat. One or more of those components have most likely failed. Also be sure Freezer / evaporator fan is working.
Aug 29, 2017 | Refrigerators
Where is vertical ic in lg 500G studio work crt monitor
Hi, i need help here about LG Studiowork crt monitor (500g). Unlucky, my monitor dead suddenly when i do surfing internet.
So, I had to check and found that there is a defective component (explode).
I tried to google the serial component "YZ010G", but no details.
Please friends help me. thank you
Jan 17, 2013 | Computers & Internet
Hi There, I have a jvc compact component system...
I have the same probleme; What I can do?
Thank you for help.
May 20, 2010 | Audio Players & Recorders
How to repair Moultrie D-40 camera
The component you are referring to, on bottom of PCB, is ID'd on PCB as D19...The component itself has 3 fine lines on end toward top of camera, and S12 is printed on top. Looks to be black carbon.
Hope this helps..am better than a novice in electronics, but don't have tools to work surface mount devices.
Jan 22, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Hi, i'm a single mom and i'm having trouble with my 2003 gmc sierra truck. the problem is truck will not run after it has rained, truck runs fine on a dry day. do know what the problem is need help thank...
moisture problems, on a dry day start the truck and witha a water bottle or a hose start spraying different components , works better in a dark area, you may see a spark appear around the distributor, otherwise when you reach the problem area the truck will start to miss
Nov 27, 2009 | 2003 GMC Sierra 1500
Sony portable DVD DVPFX820 does not power up
    Surely it must be a power circuit problem.Some components has burnt or not working properly.Second step would be to find out which component not working and what would be the cause.
    Thanks
Nov 20, 2008 | Sony DVPFX810 Portable DVD Player
Samsung Max-DC950 Mini-Component
You need to go in menu or setup and select Region code. It's not matter where you bought your player. Select your country and it will work just fine.
Good luck.
Sep 09, 2008 | Audio Players & Recorders
DS 27425 sanyo
Hi there!
Your problem may be the same as "Mark P". Components may have been partially damaged during Lightning and failed after a while only or if caps get damaged they will overheat the circuit and cause other sensitive components to fail. I would start with primary and secondary supply and work your way through to all sections. If not familiar with TVs, refer to repair technician. Good Luck, JUS004
Sep 13, 2007 | Sanyo DS35510 35" TV
Tomtom GO 300 GPS Receiver Logo
812 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
