Question about Nintendo DSi Black Console
My dsi internet acces keeps sayin 051099 whaen i try and connect it
    Problem Solver:
  • 5 Answers
This is from the Nintendo Customer Service Website:
Error Code: 051099
This error code can occur for two different reasons:
  • You are trying to agree to the User Agreement of the Nintendo DSi or Nintendo DSi XL, but are receiving error code 51099. This can occur if the Nintendo DSi or Nintendo DSi XL tries to connect to Nintendo's servers to download the User Agreement, but there is no existing Internet connection setup on the system. To connect your Nintendo DSi or Nintendo DSi XL to the Internet, please click here.
  • You are trying to play a Nintendo DS game online with a Nintendo DSi or Nintendo DSi XL, but your home Internet is set to WPA security. Please read the following:
There appears to be a compatibility issue with the security settings on your router:
Are you using WPA security?
    No, I am using WEP security
If you are using a Nintendo DSi or Nintendo DSi XL, you will be able to connect online and use many online features with WPA security. However, you will not be able to play original Nintendo DS games that are Wi-Fi compatible, as they are only programmed to work with WEP security. In order to play these games online, you will need to do the following (If you are not receiving this error when attempting to connect games online, click here):
  • Change your wireless security to WEP or temporarily disable wireless security if you wish to connect to the Nintendo Wi-Fi Connection.
  • If you are unable to log into your router or do not know how, you can check our router look-up page (link) to see if it is listed. If your model number is not listed, check any similar models from the same manufacturer for default information. If you are still unable to log into your router, please refer to the router manufacturer or the company that provided it.
  • Make sure your router is not on our list of incompatible routers. If it is, we recommended using a router that is compatible or co nnecting from a hotspot location.
  • The wireless security settings are typically found under sections labeled 'Wireless', 'Basic Wireless' or 'Wireless Security'.
  • Change the security mode to WEP, and chose your encryption type. The 64-bit encryption type typically uses a 10 character key while the 128-bit encryption type uses a 26 character key. Hexadecimal keys consist of letters A-F and 0-9, whereas ASCII keys have no limitations and are case sensitive. Be sure to use the key that is listed in 'key slot 1' and make sure you are not using a 'passphrase'. For specific information about changing your security type please see your router's manual or contact the manufacturer.
  • Important Note: it is recommended that any changes made to the router are performed from a computer that is wired via Ethernet cable to the router. In addition, any changes made to wireless security must also be adjusted on other wireless devices in the home that use the router (e.g. laptops, other game systems, etc). For instructions on how to change these devices, refer to the user manuals for these devices or contact the manufacturer.
  • Establish a connection in connection files 1-3 on the Nintendo DSi or Nintendo DSi XL. Make sure you are putting the WEP key into the Nintendo DSi exactly as it appears on your router page.
If the error persists while using WEP (or if you are receiving this error with other Wi-Fi features), follow these steps:
  • Keep trying, as there may be a temporary network issue. If the problem persists, or has been consistent over a period of time, move on to the next step.
  • Configure the Nintendo DSi or Nintendo DSi XL manually
      Please note: if your router is set to broadcast the network but the Nintendo DSi or Nintendo DSi XL is not finding the access point then a manual setup will not resolve the error. There may be another problem, such as interference, or a basic setting in your router that is causing compatibility issues. Be sure that your router is set to 'Enable SSID broadcast' or 'Enable Wireless broadcast'. If you prefer to keep your network name hidden, verify the correct spelling and case of your router's SSID.
  • Check your router on our router listings page to see if there are any special notes for your router
  • Try changing the channel on your router to 1 or 11. Ensure there are no other wireless devices in the area causing interference. Make sure you are within range of the router.
  • Important Note: it is recommended that any changes made to the router are performed from a computer that is wired via Ethernet cable to the router. Also, any changes made to wireless security must also be adjusted on other wireless devices in the home that use the router (e.g., laptops, other game systems, etc). For instructions on how to change these devices, refer to the user manuals for these devices or contact the manufacturer.
  • Try adjusting the Transmission rate of your router to 1 or 2, and the basic rates of your router to 1-2 mbps.
  • Ensure that your wireless mode is set to a b/g mixed mode, and not an 'n only' mode.
  • Check to see if you have MAC filtering enabled. If you do, be sure that the Nintendo DSi or Nintendo DSi XL system's MAC address is in the 'allowed' list.
  • Try temporarily disabling your router's firewall.
  • Try temporarily disabling your router's wireless security.
  • Important Note: Please be reminded, that any changes made to wireless security must also be adjusted on other wireless devices in the home that use the router (i.e. laptops, other game systems, etc). For instructions on how to change these devices, refer to the user manuals for these devices or contact the manufacturer.
  • Check to see if your router has the latest firmware. Verify this by visiting the support sections of the manufacturer's website, as they often have more current versions than what your router may automatically find. Please follow all manufacturer guidelines for the correct method of updating your router's firmware.
  • If the problem is still persisting try power cycling your router. Unplug the power cable from the router hardware and keep it powered down for 30 seconds to a minute. Plug the power cord back in and wait for the router to finish re-initializing. Test the connection again.
If after trying the steps above you are still receiving this error code, please call 1-800-255-3700 for further assistance.
Posted on Aug 02, 2010
How do you get inernet with it saying error code 051099
Most likely this issue has resulted from incorrect information entered into the wifi set up. Try creating a new connection and input all the correct information. Most likely this will resolve the issue.
Jul 01, 2014 | Nintendo DSi XL Burgundy
No access point in range error code 051099-1
  1. Create a new connection:
  2. Trying to play online multiplayer with Nintendo DSi
  • Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon.
  • Scroll over to the third page, and select "Internet."
  • Now choose "Connection Settings."
  • Click on "None" for "Connection 1."
  • Click on "Search for an Access Point."
  • The Nintendo DSi will search for any wireless networks within range
  • What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
for more help visit https://cbrtechsolutions.net
Dec 16, 2011 | Nintendo DSi XL Burgundy
I can't get my nintendo dsi to connect to the internet keeps coming up with error code 051099 - 1
There's some kind of incompatibility between your hubs settings such as the name or security settings that is incompatible with the dsi.
have a look at this website and let me know if you've solved the problem
http://www.nintendo.com/consumer/systems/dsi/en_na/usb/index.jsp
Nov 12, 2011 | Nintendo DSi Black Console
Trying to connect to the internet with a dsi error code 051099
This is a ode which usually indicates no connection to the router. Go through the internet setup process and see if your router is listed when the DSi searches for routers.
Feb 20, 2011 | Nintendo Video Game Consoles & Games
I cannot connect to the internet keeps saying error code 051099
Welcome to Fixya. For you to be able to connect your Dsi to the internet wirelessly just follow this link. This link will redirect you to my guide on how to connect your Dsi and how to access the router to obtain the information needed.
If you think this is helpful. Rate me and my tip so that I can help others. And dont forget to say thanks.
Thanks for using Fixya.
Feb 05, 2011 | Nintendo DSi Matte Blue Console
Error code 051099"1 nintendo dsi.trying to get
Error Code: 051099Was this information helpful?
Unable to use your wireless signal
Likely cause: It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
How to fix: Try creating a new connection with your system. Nintendo DSi owners trying to play multiplayer games will want to be sure to read the "Trying to play online multiplayer with Nintendo DSi."
Here's a link:
http://www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp
DONT FORGET TO RATE THIS PLEASE
Jan 30, 2011 | Nintendo DSi Matte Blue Console
How do i get internet on my dsi
You have to setup your internet connection on your DSI before being able to go on the Internet and play online. Here is a step by step instructions how to setup your DSI internet connection:Wireless Connection:
  1. Turn on Dsi and click on the wrench button to go to system settings.
  2. Scroll until you see "Internet" and select it.
  3. Select "Connection Settings"
  4. Select "none" next to the Connection 1 button
  5. Select "Search for Access point"
  6. Select your preferred access point
  7. Test Connection
  8. Done!
Jan 16, 2011 | Nintendo DSi Red Console
Okay so im trying to use my dsi's internet and it says something (i forget what but thats not it)anyways i got to connection settings and put my password for the internet thing then i go to save and run...
if your using search for acess point it will find your own acess if you put manual setup it has 99% posibility that the error happens if it says no acces point in range move closer to your computer and it may work if it doesnt it means theres a problem with the telephone line so tell a fixer for the telephone line to help or tell your parents
Feb 04, 2010 | Nintendo DSi Black Console
Can not conect to internet
call 410-668-2342 and i will help u right now
Jan 26, 2010 | Nintendo DSi Black Console
Nintendo DSi Black Console Logo
1,094 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
