Question about Dishwashers
When I turn on machine to start a new wash, it commences cycle and then stops after about 2mins. It would appear it is not taking in water!! Anyone got any ideas what the problem is??
    Problem Solver:
  • 13 Answers
Check the inlet hose and check inlet filter
Posted on Aug 04, 2010
Hello. my Lavamat 74500 update does not start the wash cycle. everythig is on, door locks but nothing happens.
sounds like a water fill problem to me, normally at start of cycle door locked, program set, start water solenoid opens and fills machine with water, once water reaches set level heater will come on and wash program will commence,
so if you have a restriction in the water supply/ water tap not turned on correctly, on blockage in water solenoid valve water flow to machine will be restricted causing a long delay before machine starts, things to try
1. make sure hose connection water valve is fully open
2.open soap draw to see / if you can hear water flowing into machine,
3 if its very slow you have a restriction in water supply
could be a twist in water supply hose, causing a restriction
all above is if machine is taking to long to fill with water,
good luck .
Oct 05, 2016 | Washing Machines
How do I fix washing machine to finish emptying during rinse and spin cycle?
Long shot, but does it fill the same as when new? I would check the atmospheric switch which is a hollow tube that runs down the inside of the drum(not in the wash cage) when the water fills, It pushes air up to stop the fill. It may have gotten clogged. Or partially clogged.
Mar 28, 2016 | Fisher and Paykel Washing Machines
Manual zanussi essential 1400
You have a bad Drain Pump! It needs replacing. Unplug the machine first, Drain all the water out.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Jan 19, 2014 | Washing Machines
Washing machine sticking in middle of rinse and spin part of cycle
If your machine is stopping at the rise cycle, then you have a faulty cold water inlet valve/solenoid.
To verify this, turn off your hot water tap and only leave the cold water on. Put your machine on a cold water cycle. If the machine does not fill up, it means the valve/solenoide needs to be replaced.
Also note if you had water left in the tank prior to rise cycle commencing, then the drain pump is blocked.
Ash
Sep 11, 2011 | Hotpoint Washing Machines
Simpson eziloader 5.5kg washing machine When i turn it on and select a program the machine clicks and the light flashes three times and then turns off the cycle (the cycle does not commence).
1.Turn off machine 2.unplug from power 3.leave unplugged for 5-10 mins 4.open door (if has water in drain via pump/lint filter (botton right flap). 5.empty contents(if wet turn drum by hand( may be unbalanced) close door) 6. turn on power 7. select colours 40 cycle 8. press start button 9.wait a moment ( chip reset ) 10.hopefully machine will fill with water and let complete cycle
Jan 11, 2011 | Washing Machines
I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
My GE Profile Washing Machine Keeps Stopping
Repair requires replacement of the transmission / break assembly. Unless you are really attached to this machine, it's time for a new machine. Average life of a washer is about 11 years doing 8 loads per week. Look into the front load machines, which use about 1/4 the water and spin about twice as fast, and are gentle on fabrics while cleaning very well. Please don't bother rating this, as non FixYa ratings drop my rating, and I'm sure you don't want to shoot the messenger.
Oct 14, 2008 | GE WBSE2090A Top Load Washer
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
