Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
What does a Ignition Lockout (red LED blinking 3 times) mean? Pilot light and main burner will not fire up.
    President:
  • 1,515 Answers
Hi, on most all heaters you will have a chart somewhere on this unit, a code chart that will tell you what it means. It had to try and fire 3 times before it locked the module out do to a open safety switch, flame roll out switch, or a open pressure switch. Look, as they paste them on a panel or somewhere on the unit. If you have no luck, please use my user name below and I will look into it more for you. Send me all of the information to this unit. Keep me posted.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Aug 03, 2010
  • Robert Horton
    Robert Horton Aug 04, 2010
    Thank you for the awesome rating. I am glad to be of help. Please use me again here at Fixya.com if needed.
    Shastalaker7
Electronic ignition clicks really fast wont light and finally shuts off What is the problem with our Duke E101GV
The ignition module is energized solely by the thermostat output. When the tstat satisfies, all power is removed from the module. The pilot and the main burners go out.
When the module trials for ignition, it must prove pilot flame and then turns on the main burner. If it doesn't sense the pilot for some reason, it also disables the pilot solenoid valve.
If the pilot comes on and stays on, but main burner doesn't come on, there's several possible problems:
  • Faulty ignition module
  • Faulty main burner solenoid valve
  • Faulty wiring between the module and valve
  • A gas blockage at the main burner
All this under the assumption that the main burner is correctly installed.
https://techtown.partstown.com/thread/1710-i-have-a-duke-e101g-convection-oven-that-is-not-firing-not-sure-what-the-problem-is-it-takes-a-long-time-to-get-to-temp-but-when-food-is-put-inside-it-seems-to-never-make-it-to-temp
Apr 20, 2018 | Cars & Trucks
I can get the pilot light to stay on but main gas burner won't fire up
If the pilot is lighting and the thermo couple is in the fire and turned red and the pilot still does not stary on change the thermo couple. They are available in any home improvment store.
Nov 04, 2014 | RTO Suburban Rv Water Heater Dsi Gas Valve...
Troubleshooting blink codes
There is actually a legend on the ignition control module that you see flashing. This is a very basic troubleshooting code, usually it blinks 3 times, meaning ignition lockout (heater tried to fire unsuccessfully 3 times)
Jul 16, 2014 | Lochinvar ENERGYRITE 150K BTU NATURAL GAS...
Indicator says Ignition lockout ?
turn off then turn back on that should clear it
May 26, 2014 | Jandy Laars Lt 400,000 Btu Heater
Ignition lockout code
what is the error code in display, did u reset the board by turning the power on/off
Jun 09, 2013 | Legacy Jandy Lrz250en Swimming Pool Spa...
Getting ignition lockout code
1-water flow ? gas related , is propane or natural gas ?
Raypak RP2100 Pool Heater
check gas pressure if too low this will happen
May 22, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Main Fan won't turn off even with thermostat removed. Burner not
There is a chart with the wiring diagram and othere charts that will tell you what the 6 blinks are for. That should tell you what is wrong and what part you need. Sounds to me like the board has an issue or the gas valve is locked out.
Jan 10, 2009 | Goodman GDS81155CNA Open Flame Mid-Size...
Heating & Cooling Logo
630 people viewed this question
Top Lite On Heating & Cooling Experts
1STHVACMAN
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
