Question about Dishwashers
When trying to start the dishwasher, pressing the Normal wash button, the dishwasher gives a huge clunk and then it trips the circuit breaker. Upon resetting the breaker, I tried the next button over, which is Soak and Wash, and it seems to go thru the cycle fine. Another time I tried the Normal button, but put the left dial on Rinse and it started up, but it would clunk periodically and it seemed to have a 'hot' smell. I'm worried to use it - what could this be? Is there anything else I can try?
  • susanmerc Aug 02, 2010
    It is a 30 year old dishwasher, so guess I will need to replace it. Thank you.
    Brigadier General:
  • 3,513 Answers
Hi
This is a very dangerous situation you must remove from the wall supply and desist from using, such a fault could easily make the casing "Live" and anyone touching it may be killed. You need to discover why this is happening.
When the MCB (miniature circuit breaker) is re set the dishwasher works again so does seems to be a permanent fault !
The MCB is designed to isolate the current when there is an electrical fault, the smell of burning should give a hint that this was not a randon trigger event but a potentially serious and dangerous event. By turning it back on again and using the machine is a risk.
Also check this link…
http://www.repairclinic.com/Dishwasher-Troubleshooting#Itsnoisy
http://www.apwagner.ca/index.php?main_page=page&id=1057
http://home.howstuffworks.com/dishwasher.htm/printable
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 02, 2010
My GE Quiet Power 1 is constantly beeping when you press Normal wash, and then just flashing when you press Start/Reset.
Try cutting power to it at breaker box and see if electronics will reset. If not, sounds like a control board problem
Nov 11, 2017 | GE Dishwashers
Power is to the dishwasher put it wont turn on
hello first check yor breaker make sure not tripped.
next check for lights in your panel.
perform a normal wash if no luck
next perform a service diagnostics cycle.
note sercice diags. works on Maytag MDB7600 series.
press the following keys in less than 6 secs.
HeatedDry > Normal > HeatedDry > Normal
to advance machine cycles press Start/Resume key.
blessings,
e.
May 22, 2014 | Maytag Dishwasher
Viking dishwasher VUD040 keeps tripping the circuit breaker during drying cycle
Are you sure the breaker is big enough to carry the Amps needed to start the drying cycle. You know that due to inductance it takes almost twice as many amps to start a motor as it does to run it.Find out how many Watts it uses and divide it by 120VAC and it will give the maximum amps it will draw. See if the breaker is high enough amp for it. A 25 Amp breaker should be efficient. I hope this helps you and if I can help you in anyway in the future let me know.
Mar 12, 2014 | Viking Dishwashers
My maytag quiet series 200 wont do anything when I press the start button. there are no lights. I have tried tripping the circuits?
Mine would not start, and could not set any options. I read online to try resetting by pressing Heated Wash, then Heated Dry, then repeat both. I did it and my machine cleared and worked fine. Give it a try!
Dec 13, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
GE Dishwasher GLD4200L00BB not running
Did you ever get a solution to your problem. I have had the same model for 5 years and today it did exactly what you described. Please help.
Feb 14, 2010 | GE Dishwashers
Dishwasher won't turn on, lock light comes on when I try to start
my husband found the solution on line when he googled the problem. He read that the drain could have been blocked, or it said press the drain button. That did the trick, and now I have clean dishes! He didn't have to pay anyone to solve the problem which was nice.
Dec 03, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Kenmore elite dishwasher 665 15962990
Hold down the "HEATED DRY" button for 4 seconds to unlock.
Try to press these botton in sequence,Heated Wash, Heated Dry, Heated Wash, Heated Dry.release your hand, the unit will go into diagnostic mode. that is all leds will ON for a few seconds,and start normal operations.
If that does not work, you might need to check the electronic control board if the ribbon is seated properly.
Finally solution, is to change the electronic control board.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dose not finnish washing and starts bleeping and start light keep flahing. water is hot by have not dryed
Neighbor had a similar problem with a GE dishwasher except it wouldn't start and kept beeping when door was closed. So the door was left closed, and while it was beeping, turned off the circuit breaker that fed power to it. Waited about 30 seconds, turned circuit breaker back on, bleeping had stopped, dishwasher was reset. Normal and heated dry were already selected, (since I had tried pressing those two before all this to force a reset), then pressed start and it ran again. Hope this might help you.
Jul 25, 2008 | Whirlpool Dishwashers
Bosch 5315 dishwasher
A fuse may have blown or a circuit breaker tripped. Replace fuse or reset circuit breaker at your fuse box/breaker box windman
Jan 30, 2006 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
21 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
