Software problem when i install windows xp on my system with micro atx i810 motherboard the ethernet controller is not installed ,pls tell me how to solve this
Tengo una falsificación de sofware original windows xp. Que hago . Deseo un original gratis
Posted on Sep 13, 2008
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Check the device manager to see if it is showing there with an error - it could be either hardware or driver related. If hardware, obviously that is a different matter. But if it's a driver issue, it may be easiest to use a site that will scan your system and determine the updates needed. Three available sites: driveragent.com, drivers.com, and drivershq.com. You may find this more helpful. Thanks for rating FixYa!
Posted on Apr 26, 2008
    Master:
  • 441 Answers
Is the ethernet adapter on the mother board built-in? If not you need to get the drivers of that adapter. If its it, then use the mother boards cd to loacte the drivers of the ethernet adapter.
Posted on Apr 25, 2008
My computer starts on first attempt only
Hello the homepage is here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5KPLAM/#download
Try to renew the graphic driver by:
Select windows xp.
Open the vga folder and click on global for download.
Unzip the file before you install.
Uninstall the old driver before you install the new.
The fault could also be the power supply, or a ram module failing.
I recommend at least 2 gb ram, for a smooth running system.
You can add a graphic card in the pci-e socket on the mainboard for better performance instead useing the onboard graphic.
Just make sure the windows system is driver supported.
Good luck
Jan 09, 2013 | ASUS P5KPL-AM - Motherboard - micro ATX -...
I can't download it
Maybe this one can help.
Download this link : http://www.mediafire.com/?ohcq1uuf01su00k
Here's the Instruction :
1. install the software and run the program after installation.
2. if ask for Key registration, just enter this code : JCCQ-MAKC-KACK-6TSE-BN35
3.Tick "Scan" to begin (it will detect all drivers that needs to be update
4.click start to begin downloading (you can choose which driver you want to download)
5.click "Install" and it will automatically install on your pc.
This are the supported drivers :
* Sound card drivers
* Printer drivers
* Video card drivers
* Motherboard drivers
* Webcam drivers
* Wireless drivers
* Bluetooth drivers
* FireWire drivers
* Ethernet drivers
* Windows XP drivers
* Windows Vista drivers
* USB drivers
* Chipset drivers
* AC97 drivers
* DVD drivers
* Router drivers
All P4 motherboard supports and guarantee by this software.
Hope this solution helps....
Jun 14, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
The shop owner had forgotten to handover motherboard soft installation CD when we had purchased. could be possible to install software without CD through Internet.
From this official link you can download the drivers you need for your system. Select your operating system (Windows XP, Vista, Windows 7) and download the drivers for your Gigabyte motherboard. Double click on each one downloaded file (one at a time) in order to install the drivers.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer. Also tell me what operating system do you use, in order to give you more detailed steps.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Jan 02, 2011 | Gigabyte GA-M68MT-D3 AM3 NVIDIA GeForce...
After installing graphic driver for windows XP, the display setting becomes lowest(4 bit) and it cannot be changed.
This occurs when the incorrect video driver is installed or the standard VGA driver is installed.
You can confirm the type of video driver installed by click on Control Panel - Display - Settings tab - Advanced check the Adapter type.
If you have not the correct video driver then -
Normal 0
You can download the drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Please click on this link to their WEB support site : -
http://support.asus.com/download/download.aspx?SLanguage=en-us
Oct 10, 2010 | ASUS P5QPL-AM - Motherboard - micro ATX -...
Getting the foxconn 661gx7mj ethernet driver with windows 7
You can try the driver at the following link, if it doesn't work, you'll have to wait til foxconn designs a Windows 7 driver.
For now, buy a Windows 7 compatible ethernet card and install it
Nov 06, 2009 | Foxconn 661GX7MJ-H LGA775 Micro ATX...
How do I down load ethernet controller, PCI Device, SM Bus Controller, video Controller (VGA Compatible) & other devices driver
if you want to download from the same PC then you cant as the Ethernet driver will not be installed ..
if it is installed then you can download ....
check it in the
control panel>system(switch to classic view in case of XP)> hardware>device manager
in device manager go to network adapters there if the Ethernet driver is installed then you will be displayed there (if the driver is not installed then you will not see that network adapters also)
if it is not installed then you must download the Ethernet driver from some where else to your system from your manufacture(motherboard or chipset manufacture) website (if it is intel then http://downloadcenter.intel.com in this website you can search it & download)
if you have the Ethernet driver installed then you can download from your system only the other drivers from the manufacture website ....
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution as per your satisfaction
Jul 04, 2008 | ASUS P5PE-VM Motherboard
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
