Question about Peg Perego Gaucho Rock'in
Hi - Rockin Gaucho wheel oxtogen connection keeps slipping - now warped so motor spins but wheel wont catch - any solutions?
4 Suggested Answers
SOURCE: how to replace wheels on gaucho silver edeition
ORDER FROM MAMA AND PAPAS IN HUDDERSFIELD £33 EACH -EASY TO FIT OR FROM USA SITE KIDS WHEELS.COM ,ONLY $38.95 PER PAIR PLUS SHIPPING -SELL LOTS OF OTHER PARTS TOO !!
Posted on Aug 10, 2009
  • 670 Answers
SOURCE: need new rear wheels for gaucho grande, do you
Not sure of a source from uk but this place will ship internationally. http://tigerimports.net/sunshop/
Posted on Dec 24, 2009
  • 190 Answers
SOURCE: I have older Gaucho Grande.
Tom,
The wheels are held on with a single nut which can be accessed by removing the small colored hub cap on each wheel. The small hub cap is pressed onto the wheel and can be removed by prying it off with a flat-tip screwdriver.
Hope this helps. If you need further assistance, just reply to this message.
Regards,
DIYpro
Posted on May 19, 2011
I have a peg perego gaucho grande and used the kids wheel overhaul kit two months ago and just today removed the pin for the high low function ... Now my gaucho does this choppy sound when in low spee
sounds like you have some broken teeth in one or both of your gear boxes, see which side the sound is coming from, and you can either open the gearbox and remove the broken teeth or just buy a replacement gearbox
Sep 13, 2014 | Peg Perego Gaucho Superpower
Relay clicking
probably got a bad motor, are both rear wheels spinning in all of the gears?
Aug 09, 2012 | Peg Perego Gaucho Rock'in
Peg perego gaucho rear wheel not spinning
you must have a bad motor, is it a 12 or 24 volt?
Jul 30, 2012 | Peg Perego Gaucho Rock'in
Belt keeps coming off
Hi There,
Most likely 1 of 3 problems.
1. The belt is stretched and so is just slipping off
Solution change the belt
2. THe brush roller has siezed bearings so brush cant turn properly so belt is slipping off the shaft.
Solution - check see if roller turns easily by hand if not change the bearings.
3. THe motor has twisted in its body due to cracked housing or worn rubber seats.
Solution- Depending on your skill and age of vacuum replace the housing or the vacuum.
If you need parts for your vacuum visit www.vacuumspot.com.au
May 13, 2012 | Oreck XL Ultra Bagged Upright Vacuum
The belt comes of when the machine goes into spin.
This is because the belt might have become lose.When in spin mode the motor rotates really fast which slips off from the wheel in which it is mounted.Please replace with the correct size of belt and this wont happen again.Check with the previous belt there will size number printed on it.Get the same size belt and fix it.
Thank You
Sep 03, 2010 | Whirlpool Washing Machines
Igniton wont turn cant start car any solutions
Is it just spinning round in the lock? if so push hard on it and keep moving the steering wheel side to side in the same direction os the wheels are faced, if turned outwards. its very common on the bmw's you will need to replace the ignition switch. keep trying though it does take a while but they do catch in the end unless its very very broke. my e36 done this for months before I had to change it.
Jan 13, 2010 | 2001 Lexus IS 300
How to replace wheels on gaucho silver edeition
Aug 06, 2009 | Peg Perego Gaucho Superpower
Gator lt wheel doesn't turn when in grass/ slips easily and need
only one wheel is driven in slow !
fast engages the other motor [2 wheels drive]
the wheels being plastic or poly wont grip & on the early gators as there is no speed controler in the system to prevent wheel spin!
only other way would be to add rubbr cleets to the wheels! or try changing to wheel barrow or scooter style pump up wheels
if you need more help just email me as i can help with modifaction process like more powerfull motor setup etc etc.
CHEERS Rob
Jul 19, 2009 | Peg Perego John Deere Gator HPX Ride on...
Very slow 2nd hand peg perego gaucho
I have the same issue. Called their customer service and they said it was a defect in the charging system. They are sending a upgrade kit for free, but when it's installed you can't charge the battery using the rear port anymore. No big deal. I'll report back when the fix is complete. 5-7 days until it gets here.
Apr 18, 2009 | Peg Perego Gaucho Superpower
My washer will fill up, but will not spin or rinse. The belt also keeps slipping off
it sounds like the bearing on the back of the drum have worn out and warped the belt wheel,does it make a loud noise in spin?let me know what you find-mike
Jul 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Peg Perego Gaucho Rock'in Logo
59 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Marvin
Marvin
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
