Question about Dryers
LOOSE BELT - Dryers
  • Anonymous May 02, 2008
    took apart pully fell off
    Genius:
  • 1,073 Answers
Whats the model number
Posted on Apr 25, 2008
Belt tension troy bilt horse xp 46 lawn tractor
if you just replaced the bearings and now the belt is to loose tells me the belt wasn't put back on correctly. replacing the bearings don't have anything to do with the adjustment of the belt. double check to be sure is is on right Lisa. something isn't right. the tension should come from a spring loaded arm that when engaged it will apply a certain amount of pressure to turn the blades. if disengaged it will seam loose but that is ok. it has to be loose to let the belt slip on the pulleys.
Jun 26, 2016 | Troy Garden
Belt tension troy bit horse XpressMusic 46" tractor
the belt has to be loose in the disengaged position Lisa. it will tighten up in the engaged position.
Loose fan belt
It can be worn out fan belt or the fan is got dried up and needs lubrication.Inspect fan belt.
Check the help link mentioned below:----
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Dec 09, 2012 | 2007 Chevrolet Kalos 1.2
Serpentine belt loose on pontiac se grand am
The belt has an automatic tensioner pulley and no other adjustment is needed or provided for. If the belt is to loose you either have the wrong belt installed or the automatic tensioner is defective.
Jun 07, 2012 | Cars & Trucks
Power steering went out last nite and battery light came on serpoentine belt is loose
You'll need to replace the belt tensioner as it is probably weak and not keeping the correct tension on the belt.
Apr 02, 2011 | 2002 Ford Escort
Getting a 'squealing' noise from the engine all the time. What is the cause likely to be??
Depending on the model it could be a belt alignment problem, loose belt or bad bearing in a pulley. If the squeal gets louder if you spray water in the area of the pulley it is most likely a loose belt. I would start by looking at the belt itself first then spray WD-40 in the bearing area of the Idler pulley and tensioning pulley. If the WD-40 works the problem is a bad bearing. Otherwise it is again, most likely, a loose belt. As a final check you can spray belt dressing on the belt and if the squeal goes away then it is your belt being loose. This could be caused by a belt being stretched over time or a tensioner not working correctly due to a weak spring, if equipped with spring loaded tensioner. If it doesn't have a spring loaded tensioner then you may just need to tighten the belt by adjusting it.
Oct 12, 2010 | Chrysler Voyager Cars & Trucks
The gears are turning but the belt is not is my belt bad
if motor is turning and motor pulley and the belt isn't moving it could be broke belt but does the belt look loose or is it loose make sure it has tension on the belt
Sep 07, 2009 | Amana Washing Machines
Beater Bar Belt loose and bar won't turn
Provided that the motor isn't loose, the belt should fit tightly. If you had reassembled the beater bar back in the vacuum improperly, the belt would be tighter, rather than looser. If you are sure that the motor isn't loose and the beater bar was reinstalled correctly, then either tha belt slipped back off the motor shaft, or they sold you the wrong replacement belt.
Jul 18, 2009 | Hoover U6630-900 WindTunnel Bagless...
BELT TO THE BRUSH SEEMS TOO LOOSE EVEN WHEN REPLACED
Hoover U6437-900 U6439-900 Upright
LOOSE BELT. THE BELT IS STILL LOOSE EVEN AFTER REPLACING
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The reason it seems like the belt is too big is probable correct, you may have the wrong size belt for your vacuum, use genuine belts – your particular model is a self propelled model and takes two (2) belts and they should stretch on very tightly and snug and it is smart to use the genuine belt package for the model that you have and we Recommended the belt change for flat belt(s) are 4 to 6 months for better cleaning
They should be tight on the belt pulleys in order to do the best cleaning – use genuine belts
http://www.hoover.com
Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 03, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Dryers Logo
83 people viewed this question
Top Dryers Experts
