After putting the TV on, after one second or so, the screen turns black. The sound is stil to be heard. After unplugging the TV from the wall outlet, and waiting for about five minutes, sometimes the problem doesn't occur.
  • 11,361 Answers
Check the power supply voltages and the backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 03, 2010
  • 8,457 Answers
The 1 or 2 LCD inverter boards are dying,it 1 or 2 long boards in the tv,just not totally dead yet,that why unplug,replug sometimes getting picture back.Most of the time tv power on,only get a flickers of picture and dies only sound left right?Than the 1 or 2 LCD long boards in shape,inverter boards are dying,replaced these 1 or 2 Long LCD inverter boards,will solved tv picture problems.These 1 or 2 long LCD inverter boards help the LCD screen to get a backlight to produre a picture.Tries websites like Shopjimmy.com,Ebay.com to buy these 1 or 2 long LCD inverter boards for the replacement.
Posted on Aug 02, 2010
Maxent tv repair
time to replace the Tv unfortunately
Jan 29, 2018 | Televison & Video
My tv made a loud popping sound. Now the bottom right 1/4 o the screen is black with different colored lines on it
Check for any bursted electrolytic capacitors on its main power supply regulator board. The sound you heard might be to this burst. Take care, and unplug the TV from AC mains supply wall socket, before opening and checking this board. See examples of bulged [bursted] capacitor.
Jul 10, 2012 | Sharp AQUOS 52" Flat-Panel LCD HDTV
I have 60 inch mitsubishi hd DLP flat panel projection screen model is wb60735.i unplugged it from the wall then i plugged it back in the wall the next day.it came on but the screen was all black but still...
If you see absolutely nothing on the screen then you may have a problem with the Lamp unit. If you can see around the back of the TV look to see if there is a vented opening with a noise of a fan and a rather bright light. If you see there is no light then try a reset (hold power button for at least 10 seconds). Turn the TV back on and the green LED should flash for a bit. If you still have no picture or video of any type (completely black screen) and have sound only you probably have a bad lamp. These lamps are around $125 or so and can be bought on Amazon or other sites that sell these parts. It's fairly simple to replace but make sure that the tv is unplugged and securely re-install the access door. Hope this helped.
Feb 08, 2010 | Mitsubishi VS-60611 60" Rear Projection...
Screen goes black tv stays on. Turn off and on and TV's fine.
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Mar 20, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Vizio L32 hdtv10a..
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
Dec 15, 2008 | Vizio L37 Television
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Screen goes black and turns off
sounds like something is over heating.
i would check convergence ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sep 28, 2007 | Panasonic PT-47WXC43 47" Rear Projection...
Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Jan 18, 2006 | Toshiba TZ50V51 50" Rear Projection...
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
