Question about Dymo LabelManager 300 Desktop Labelmaker Printer
Paper jam in the Dymo LetraTag Label maker. I have cleaned and taken the label tape out...it still will not print, states" paper jam with a triangle with an exclamation point inside...please help
  • 1602 Answers
SOURCE: Faint Printing
TRY PUTTING NEW BATTERIES IN THE DEVICE AND THE LETTING WILL GET DARKER SO YOU CAN SEE IT
ROD
Posted on Mar 13, 2009
SOURCE: changing ink?
I had the same problem. I just put in new batteries and it is printing fine. Are your batteries low?
Posted on Apr 29, 2009
  • 2976 Answers
SOURCE: How do I change the tape in my dymo QX50 label maker?
Where the cartridge has a hole in it, make sure the tape is IN the print head, not over or under it. Also, check the type & color of the tape. They have some strange combinations that are only visible under certain conditions.
Posted on May 23, 2009
SOURCE: How do I load the tape into this old dymo label
http://www.dymo.com/media/UserGuides/Hobbyist1895.pdf
Posted on Jun 24, 2009
SOURCE: Can I buy a new print roller for my DYMO LetraTag
You will need to contact Dymo at 1-800-640-6944 to inquire about the LetraTAG print roller as it is not available online. You can contact them Between Monday to Friday: 9am - 5:30 pm Eastern
Posted on Aug 07, 2010
Letratag showing tape jam. Have changed batteries and tape roll
there's a paper jam inside the mechanism of thermal label printer, if you can do open it, clean it also, just be careful to put it again.
Feb 12, 2011 | Dymo LetraTAG Thermal Label Printer
I have the dymo letratag. no letters come out on the paper. I can not find anywhere to put any ink.
LetraTag label makers are thermal printers, so they don't use ink - just batteries and LetraTAG tapes.
When the print starts to fade it's time to put new batteries in.
Jan 29, 2011 | Dymo LetraTAG Thermal Label Printer
Displays !!!!!!!!! when you say print
This means there is a paper jam. Clear the paper jam and i should work fine.
Jan 16, 2010 | Dymo LetraTAG Thermal Label Printer
Won't print tape jam Have taken the tape out and put back in also
For me, a bunch of the tape somehow got stuck in the roller... I had to use a tweezer to pull it all out.
Aug 24, 2009 | Dymo LetraTAG Thermal Label Printer
May 22, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Dymo Letra Tag
I have to assume you are pressing the print button. That being the case, either your batteries are weak or the tape is empty or jammed.
Aug 28, 2008 | Dymo LetraTAG Thermal Label Printer
Printing
I was having the exact same problem & had lost my user's manual (you can go on the Dymo.com website to download a replacement). The !!!!!!!!!! display means that there probably is a tape jam. Here's what the manual says:
*!!!!!!in the display indicates that the tape can not be transported *Press any key to return to normal display *Check if there is a tape jam. In that case, life out the cassette and carefully release jammed tape. Cut off excess tape and refit/replace the cassette *If there is no tape jam replace the batteries
Nov 05, 2007 | Dymo LetraTAG Thermal Label Printer
Letra Tag QX50 Error 1 message
Don`t close the back plane compleet, push print and pull on the tape, now it runs on mine. Close the back plane and everything is ok now, Good Luck!
Michel
Sep 20, 2006 | Dymo LetraTag QX50 Thermal Label Printer
Error 1
The user guide lists all the error codes and possible solutions. http://download.dymo.com/media/UserGuides/QX50US.pdf Error 1 indicates a tape jam or low battery. To resolve, try removing the cassette and clearing the tape or replacing the battery.
925 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
