I am installing a LEXMARK wireless printer to my computer and cannot continue without my security key password on my router and don't konw where to find it.
    Genius:
  • 3,587 Answers
It's in control panel for that router....check website of router maker, and that will explain it.
do you have a manual on this printer?
also, see this for more assistance
Posted on Apr 25, 2008
Lexmark wireless printer won't connect with my router?
Lexmark provides a line of wireless printers and sometime printer won't print with wireless...so here is what you may have to do in order to get this fixed
1.make sure your wireless password is right
2. uninstall the printer software and reinstall it once again ( make sure you configure the router with wireless router) for more assistance contact with Lexmark Printer Tech Support
3. now type the right password and try to print it
i hope this may help you
Mar 05, 2012 | Lexmark Office Equipment & Supplies
Want to connect wireless printer but i need WEP key so the printer can connect on same wireless connection
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Feb 07, 2011 | NetGear DG834G Router
What is a security key
WPA (Wi-Fi Protected Access) is an advancement over WEP (Wired Equivalent Privacy). While connecting to a home network, you are often asked to insert a WPA key or a password to which users often ask, "How Do I Find My Computer's WPA Key?" WPA stands for Wi-Fi Protected Access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over(Wired Equivalent Privacy) Wep is standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
How to find your computer's WPA key Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To Reset a modem/router, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long. For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Jan 20, 2011 | Buffalo Technology AirStation Nfiniti...
How do i connect to internet with ps3, wireless, what is a wpa key?
WPA stands for Wi-Fi protected access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over WEP (Wired Equivalent Privacy) standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
You can correct this problem by entering the WPA Key into your PSP's Network Settings. But before you do that you need to know what your WPA Key is...
To reset a Linksys modem/router or Belkin one, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
For minimal security, you can choose 8 characters key, like "iN/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBDm+oMp$nrXj5XPVRTvVA5fpwGSGIRVz4RdQ7V3yl$P1NrT9Be".
Jan 02, 2011 | Video Game Consoles & Games
Cant get Internet Explorer on computermj
Greetings,
so you have a lenovo laptop, linksys wrt54g wireless router and a Lexmark wireless printer. And you wants to secure your wireless network. Just follow the instructions ---
SETTING UP WIRELESS SECURITY ON YOUR ROUTER--------
1> connect your lenovo with the WRT54G at port no. 1 it is very imp. to hardwire your computer, also check for the light status of the router to ensure that it is connected.
2> access the router setup from a web browser (may be using 192.168.1.1, the default address of your router, and admin as the password.). You can also go to kb.linksys.com if you need more help to access your router setup.
3> at the top click on wireless on the BLACK bar at the top.
4> under wireless click on wireless security on the blue bar.
5> select the security mode as WPA-PERSONAL (best encryption and supported by all devices).
6> select WPA ALGORITHUM as TKIP.
7> in WPA Shared Key type: "superman" or any thing else but it should be at least 8 characters long. and you should remember it as this will be your wireless password.
8> the Group Renewal key should be 3600.
9> Click on save settings at the bottom.
PERSONALIZING YOUR WIRELESS NETWORK NAME--------
1> Under Wireless, click on Basic wireless settings.
2> MODE: mixed
3> NAME: CHANGE IT eg NINJA, SPIDER etc
4> Channel: 11
5> SSID BROADCAST: ENABLED
NOW YOUR ROUTER IS CONFIGURED.
Now u jest need to connect your laptop and printer to this new secured wireless network using the security key and i am damn sure it will work.
Sep 12, 2010 | Computers & Internet
Lexmark wi fi printer need the wap code for the roter
If your wireless network is secured, the WPA or WEP security encryption key is a requirement to successfully connect the Lexmark printer to a wireless network. These keys (WPA or WEP), if you don't know it, can be obtained by accessing your wireless router through the computer. Your wireless router manufacturer or your internet service provider can better assist you in obtaining that info. Thanks.
Jul 26, 2010 | Lexmark Interpret S405 Wireless All-in-One...
Ip address wrong, showing 192.168.254.1
Solution Overview
This article explains how you can avoid having to run the Wireless Configuration Utility or Wireless Setup Assistant (Macintosh) after making changes to the router's security settings. The need to change these settings can arise if users forget their network key/passphrase or router web server password or if you have security concerns.
Printer response to security settings changes
The printer will respond with a flashing orange (pattlnk_6172008_1844-orgblksml.gif) Wi-Fi indicator light after the following actions are performed on the network or router/access point (AP):
  • -A change to the Service Set Identifier (SSID) or network name.
  • -A change to the security type (none, WEP, WPA, or WPA2 personal).
  • -A change to the security network key/passphrase.
  • -A hard reset of the router followed by entry of security values that are different from the original values.
  • -The printer is moved to a network (AP) that has different security values but already has installed drivers and created ports. NOTE: Port reconfiguration may be required in this case. Click here for instructions.
In order to rejoin (associate and authenticate) the wireless network (WLAN), the wireless client (printer) has to be reconfigured with the router's new SSID, security type, and network key. This requires connecting the USB configuration cable to the host computer and running the Wireless Configuration Utility or Wireless Setup Assistant to apply the new security settings on the printer's wireless network adapter.
Solution: Change the printer settings first
Change the security settings on the printer while it is still communicating on the network before making the changes on the router. Understand that this will cause a temporary change in the Wi-Fi indicator light from pattlnk_6172008_1952-tn_grnsolproof.jpg to pattlnk_6172008_1844-orgblksml.gif. After you have made equivalent changes on the router, the printer's Wi-Fi indicator light will return to pattlnk_6172008_1952-tn_grnsolproof.jpg.
Procedure: How to change security settings via the embedded web server
If you change your AP security settings frequently, this procedure is for you.
  1. Open your web browser application and enter the printer IP address into the web address field, i.e. http://ip_address.
  2. Click on Configuration.
  3. Click on Wireless.
  4. Enter the SSID, security type/encryption, and network key that will be used to configure the router.
  5. Click Submit.
Jan 16, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
Software
You can actually configure the wireless security without the CD. Just open a browser and type in the address bar 192.168.1.1.
It will prompt you for the router's username and password. Type in the router's password (if you changed it) if not, the default password is admin.
Go to Wireless>Wireless Security.
On this page you can change your wireless name or SSID and you can enable WEP or WPA/WPA2.
Make sure you that you enter the same wireless keys on your wireless computers as soon as you save the changes on your router because you will lose your connection if you do this on a wireless computer.
Jul 02, 2009 | Linksys Wireless-N WRT150N Router
Printing
You need: * A wireless-enabled computer. Many computers made over the last three years are already wireless capable, or they can operate wirelessly with adapters. * A wireless router. This will serve as your Wi-Fi access point, the hub of your network. * Broadband Internet access. While you can use your wireless router without any Internet access at all, or use dial-up, experts agree that there?s real value in accessing online content via DSL or cable and making it available to every computer in your house. The cost of doing so, like with the hardware, has dropped dramatically in the past several years. When you set up your network using the wireless router, you?ll need to identify that network on each of your wireless computers and during the installation process for your Lexmark wireless printers or all-in-one devices. You?ll be asked about your service set identifier (SSID), which is basically the name of your network. Don?t forget to consider the security of your network early in your decision process. * Common security types for networks include WEP, WPA and WPA2, and there is usually also an option for no security. At a minimum, you should look for WPA or WPA2 security and follow the manufacturer?s instructions to encrypt your signal and set your own password. A password isn't mandatory, but if you don't use one, it's far easier for others to access your network, and potentially your computer.
Sep 08, 2007 | Apple MacBook Pro Laptop Computer with...
k24674
jasbo
jasbo
