I have a ricoh aficio 2045 the machine keeps displaying to turn the power switch of and on and call for service, when trying to print also trhe mechanical wrench turns on the display. whats causing this and how do i reset or repair this error.. Thanks
  • yan dikshteyn Aug 02, 2010
    ill try that thanks
  • 821 Answers
Hello,it could be as a result of the four things below,
1.• Fusing thermistor defective or out of
position
2.• Power supply board defective
3. • Loose connectors
4.also try to check the toner and ad more to it if not on gauge.
if the power switch control board is defective you will have to replace it,and also check the connectors if they are in order.
wish you good luck,
take care.
Posted on Aug 02, 2010
I have an sc 326 error code in my ricoh aficio 2045 copier
kindly change the developer unit and clear the error.
the machine will respond
thank you and all the best
May 20, 2012 | Ricoh Aficio 2045e 2035e Copier...
Ricoh Aficio SP C811DN Printer. after printing 9 pages it will stop and displays CS367 error code saying 'Functional problem turn power switch off then on. Can you tell me what that means and how fix...
SC367 is a toner density error having to do with yellow. If you've tried turning the machine off (with the power switch on the lower left side) and turning it back on and that doesn't help, your next move should be to replace the yellow photoconductor unit (PCU).
Thanks for using FixYa!
Feb 08, 2011 | Ricoh Aficio SP C811DN-DL Printer
I need to know the part number for the toner replacement bottle for the Ricoh Aficio 2045 PCL 6
Ricoh Aficio 2045 copier/printers take the Ricoh Type 3110D Toner Cartridge. Go with OEM toner on these machines. The generic version tends to make them run dirty.
Sep 09, 2010 | Office Equipment & Supplies
I have a ricoh aficio 2045, the machine keeps displaying to turn the power switch of and on and call for service. whats causing this and how do i reset or repair this error.. Thanks
It may seem that the unit is connected to a power outlet that is not suited to it, although for the life of me I cannot imagine anyone selling you a product not suited to your regions' power network. Try cold starting the machine.: Unplug from the outlet and leave it be for 30 seconds. Then get the power back on and see if the problem persists. As for the power supply, check on the back where the power cord goes into the machine. It should have a stamped area on the cover stating what voltage it should operate on. Make sure it corresponds to the grid voltage in your country. If you're not sure check here:
http://www.kropla.com/electric2.htm
If you had been using the unit before the above is of course irrelevant and you could reject this solution and request help again.
Aug 02, 2010 | Ricoh Aficio 2035 Copier
Ricoh 2045 erro sc546; a cada 30 copias, o que faco, nem o codigo 107 adianta ,mais
Change the thermistors in the fusor (2).
1. Press the Clear Mode key.
2. Use the keypad to enter .107..
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
Turn off and on the copier to reset the code.
Mar 06, 2010 | Ricoh Aficio 450 Copier
RIcoh Aficio 2045,turn off fax delivery report
download the manual from the www.ricoh-usa.com web site for the fax advanced features.
Refer to page50, from the pdf numbering.
Or at page147, from the document it self numbering.
Here is a link for quick find:http://www.ricoh-usa.com/downloads/manuals/bw/aficio2035/manuals/FaxAdvancedFeatures_PartII.pdf
Jan 21, 2010 | Office Equipment & Supplies
My ricoh aficio mp3010 keeps comming up with error sc 548 any body now wat to do. please help me
You need acces service progpam:
1. Press the clear modes key.
2. Enter 1-0-7.
3. Press the clear/stop key for more than 3 seconds untill the service program menu appears om the touch pamel display.
4. Enter in the service menu.
5. Turn OFF the power switch,unpluged cords,wait 10 sec,plugged cords then turn ON power switch.
Aug 02, 2009 | Ricoh Aficio 450 Copier
Erro code SC541
Fuser error.
Fix problem (Fuse, lamp, or thermistor), then reset code by entering service mode and powering off/on machine
May 11, 2009 | Ricoh Aficio 450 Copier
14 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
