Question about Kodak EasyShare Printer Dock Series 3
My series 3 Kodak printer is not working, I used to use this before on my machine (Vista), but I did an online update and since then it doesnt work, the desktop icon has disappeared and I can no-longer scan, I tried through the start up programs and everything, so I uninstalled it and tried re-installing it and now it gets to ... rolling back... and then there is an error message stating that it was interruped start again, but it does this everytime, I also tried the driver online and still no joy! help :)
SOURCE: Kodak 5100 won't print with Windows 7.
I've had the same problem for some time, but recently found a fix. Those sneaky folks at Kodak updated their Vista driver for the ESP series, and it works with Windows 7 now. Oddly enough they haven't advertised this fact, but it works none-the-less. Now, you're going to have to uninstall the Kodak Home Center, the driver and anything else associated with Kodak. You need to manually go through the Program Folder and delete anything Kodak. Make sure you set explorer to show hidden files/directories, and go to Program Data and delete any thing Kodak. Finally go to users appdata and delete anything Kodak in all the sub folders there. Then download and install the new May 1 drivers from the Kodak site:
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/13657/13660&product=EKN035329
Note: They are the Windows Vista drivers, but they do work on my Windows 7 machine.
You'll also notice that they've updated their installer program.
Hope this works for you, and if it does spread the word!
Posted on May 24, 2009
  • 60 Answers
SOURCE: Cannot communicate with printer error
error codes that you mentioned are not related to your issue you will get those are for front access door open and main paper tray empty.........the number of times you open the front access door and when ever the main paper tray is empty you will get that error.......you mentioned that HP printer worked......i would recommend to use a clear utility for HP and remove all the drivers and software for HP first as that might be conflicting with Kodak and make sure the version of the software for the home center(which includes drivers) is latest which is 3.4.......you can check for the version of the software by opening the home center and click on the question mark on the top right and then click on i which is on the right in the new pane that comes up and you will be able to see the software version in the right hand bottom corner on the small window that comes up.......if you have the latest version of the software then make sure you have the latest chipset drivers on your computer......for that you can contact your system manufacturer.......i suppose you have Dell...........if that also does not help then just tell me what all options you have under the Universal Serial Bus Controller.........also make sure if you have printer icon in the printers and faxes in case of XP and under printers in case its Vista.......if not then try and add a printer icon........if you already have a printer icon then try and right click on it and set it as default printer and then check if it works............let me know whats the result and was this helpful or not..............
Posted on Jul 16, 2009
  • 295 Answers
SOURCE: My scanner icon for my ESP 3 has disappeared. My
Kindly download trhe latest Kodak all in one home center software from www.kodak.com/go/aiodownloads .the scanning and printing drivers are embedded in the software itself.
Posted on Jan 16, 2010
  • 103 Answers
Plz download the latest printer drivers from www.kodak.com/go/aiodownloads
Posted on Jan 26, 2010
  • 103 Answers
SOURCE: Kodak ESP-3 printer causes internet to stop working
Try installing the latest software from www.kodak.com/go/aiodownloads
If still the same issue, call Kodak tech support......for some advance trouble shooting or may be printer will be replaced
Kodak easy share series 3 , only prints lower portion of picture.
Try reinstalling the printer driver. If that doesnt help, try a hard reset: Unplug the printer from AC power and PC, wait about 10 minutes and retry.
You can also do an alignment test. If none of this proves succesful, you either have a bad print head, or problem in the circuitry, which will need servicing.
Jun 24, 2008 | Kodak Office Equipment & Supplies
How can i install my kodak esp 3200 series without the software disc to my mac os x
Update your kodak esp3200 driver by using this tool driverupdate us. It is easy to use, and will update every needed driver on your PC/laptop/mac. best of luck
Jan 11, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Windows vista wont allow Kodak G600 printer to print pictures using easyshare program
Hi lomls3,
Are you using Kodak Easyshare ver8? If not, you may need to update the software in order for Vista to send the print jobs to the Kodak G600 printer.
Update the software to ver 8 first. Reboot the computer and retry printing.
Ver 8 can be downloaded here: http://www.opendrivers.com/driver/293165/kodak-digital-camera-kodak-easyshare-software-update-8.0-windows-2000-xp-vista-win7-free-download.html
Hope this helps.
Andrew
Apr 04, 2010 | Kodak Easyshare G600 (1633379) Dock /...
HI. My old computer broke. My neighbor gave me his Inspirion 530S but I can't seem to find a driver that works for the Kodak printer on this computer. I get messages like "Vista 64 bit isn's compatible"....
It is quite possible that if the printer is old (And Kodak would not be within the mainstream printer manufacturers for computers) it simply will not work with Vista.
Have you tried typing in the printer type (name) to Google and searching for a driver - example "Kodak ABC printer driver for Vista".
Alternatively maybe the support area of the Kodak website could help.
Finally, running a windows update may uncover a driver from Microsoft that solves your problem. I have often found hardware drivers by simply running windows update.
Sorry I couldn't be any more use....
antosarmy
Feb 27, 2010 | Kodak Office Equipment & Supplies
Jan 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
HP Printer Continually Drops Off Vista OS
Click on Start -> All Programs -> HP -> HP Update and run this utility. Last month, HP released an update that directly addresses this issue with the PhotoSmart series printers and computers using Vista. You should install any updates listed here, including the connectivity update.
Jul 26, 2009 | HP Photosmart C3180 All-In-One InkJet...
Mar 06, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Printer problem
Use the online tool on the Kodak Web site at www.kodak.com/go/aiotroubleshooting to resolve this problem. If a new printhead is necessary, you can order it online free of charge.
Oct 17, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Home Center will not open...Can't scan
I needed to reload my AiO Home Center software and no one seemed to have the correct procedure. Maybe if you remove & reinstall yours it will resolve your problem. This procedure worked for me on my XP-machine:
1. got to Control Panel/Printers&Faxes and delete the printer
2. go to your Hardware/Device Manager/Universal Serial Bus Controllers, right-click on USB Composite Device and select Uninstall
3. go to Control Panel/Add/Remove Software and remove the EasyShare software
4. disconnect the cables from the Printer
5. download from Kodak.com the program "install_aio.exe"; run the program
(I selected only AiO+EasyShare+Software Updater to load)
6. followed the prompts after the sw installed to reconnect the Printer cables
7. rebooted
WORKED for ME !
Jan 13, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EasyShare Printer Dock Series 3 Logo
59 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
