Question about LG 42PX5D 42 in. Plasma HDTV
IR detector My IR detector is definitely bad. What do I do? Can I fix it myself?
    Genius:
  • 1,554 Answers
An infared detector is just a transistor that is covered with clear plastic.
matching the spec on it though is hit or miss.
first be sure it is not the ir trasmitter, take it to radio shack and see if their infared re-transmitter broadcaster sees it . or aim at a digital camera
or hold near a radio though that only hears the digital part.
radio shack has some iR transistors in stock usually .
basically you can just plug one in and it may work but you may have to know how to bias (balance ) the transistor to work correctly.
there are many places to scrounge a ir receiver transistor
old tvs , learning remotes, laptops , printers ,
you can inject the output signal of the remote into the ir circuit to see if it is working but you need to add a resistor and drop the voltage a bit.
hope that helps some.
Posted on Apr 26, 2008
FS-4DA coin sorter won't count pennies
The good news is that the unit is functioning, it's just counting pennies. I had the same problem with quarters and is a fairly easy fix. I won't get into any disassembly details, but you'll need to gain access to the infrared detectors (mounted to the motor assembly) and possibly the emitters (mounted to the front panel LCD display/push button board). Also, please be careful not the damage the wire harnesses when removing the top cover. Once apart, you can use your cell phone camera (which is sensitive to infrared) to see a purplish/white glow from a healthy emitter. Compare the penny emitter to the others and chances are it will have a lower output level and need replacing. If the penny emitter is strong, then check the detector with any infrared remote control( TV, cable box...) by pointing the IR remote control towards the penny detector and pushing any of its control buttons. This should make the penny amount count up, and fast too, as the remote sends out IR pulses while a button is being pushed. If this test doesn't increment the penny count, then the penny detector needs replacing. But before you do, try this remote control test on another known good detector to verify your findings. Please keep in mind that other malfunctions besides an emitter and detector could be the cause of your problem, but given the FS-4DA circuitry, the odds are extremely high that you have a bad emitter 1st, then a detector 2nd, as emitters are known to degrade over time and especially when continuously powered, as in the case of a switched 'ON' FS-4DA. FYI...IR emitters and detectors can be purchased from Radio Shack. Good luck and take care not to electrocute yourself when powering the unit with its cover removed.
Feb 21, 2014 | Royal Sovereign Fs 4DA Model Fs 4DA Coin...
Goes off only at night with NO warning cleaned & changed batt. 4 times so far !!!!
These types of smoke detectors are PHOTOELECTRIC, the way it works, there is a IR transmitter and a IR receiver placed in a dark chamber aligned at a 45degree angle, when smoke enters the chamber IR light bounces of the smoke and than generating an alarm, so in conclusion if there is a lot of DUST in the chamber it reflects the IR light just like smoke, than can generate an alarm, try blowing air in the smoke detector (gentely) if it does not work replace the smoke detector...
Feb 04, 2011 | System Sensor 2100rfadt Wireless Smoke...
Our Philips remote lost its signal to the TV. Dont have the instruction to look up code or how to progam it
dkellogg246, Try the philips website to see if u can download the instruction book or check with local repair shop to see if it even emits any infrared light out of the IR emitter diode!! How many times has it hit the hardwood floor? could be the battery contacts are in bad shape. I'm lucky I have what is known as a hand held IR scope to test output of remotes. But they cost 20 times more than a remote. Let me know what u find out. Kodak used to sell a "IR light sensitive card" detector that would glow pink when IR light hit it. But this "business card" size sheet of detector paper cost $40.00. Good luck! Hope this helped.
lmistyrel @aol.com
Sep 16, 2009 | GE Televison & Video
LG 47LC7DF LCD TV Remote Sensor not working
IR senor may not be bad. Try using a different remote (universal) and program to TV. If universal remote works and your doesn't, you may need to purchase a remote instead of IR board. If you confirmed that the IR board is bad then replacing the IR board will fix the remote issue. IR board is an easy fix. Just open the back cover out and it's located right in the middle toward the bottom of the TV.
Jun 22, 2009 | LG 47LC7DF 47 in. LCD HDTV
1934 model recieving
cthy_prry,
The IR detector is in your TV set. It is the device that picks up or captures the IR signal from your remote control and turns it into an electrical signal that the TV via a processor interprets as a function or command to have the TV perform in a certain way as turning on, channel up or down, volume up or down, etc.
IR means Infrared
I hope this answers your question.
Thank you,
Shuttle83
Aug 19, 2008 | Orion1934 19" TV
Soldering
HI: UNLESS YOU HAVE SOLDERED AROUND SEMI CONDUTORS BEFORE STAY CLEAR. HEAT SINKS ARE REQUIED AND CORRECT HEAT IS THE KEY, LEADS MAY BE OF NON COPPER AND THI WOULD REQUIRE HIGHER TEMP IRON. IF IT TINS EASLY THEN GIVE IT A SHOT. BEND LEADS HELPS
Apr 25, 2008 | Toshiba 32AF43 32" TV
BEL Radar Detector +
yes buy a direct wire kit this will fix your problem ccity sells them
Mar 20, 2008 | Vector 995 Radar Detector
Not receiving IR Commands from remote.
replace the IR sensor...I don't have a part number for it..but I have seen IR sensors grow either weak..or fail totally..also you'll want to verify that the remote is working...you can buy an infrared detector strip from radio shack for a couple bucks...all you do is push power on the remote continuously..and hold the detector strip up to the front of the remote..if you see a red flashing on the strip..the remote is transmitting..if not..the remote has low battery..or has taken a dirt nap.......
Jan 31, 2008 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Television
The IR detector may be bad ,
do you have another generic remote to test with.
or take your remote to radio shack and aim it at a IR transmitter
does it light up.
Jan 13, 2008 | LG 42PX5D 42 in. Plasma HDTV
TV does not respond to Remote
possible defective rf receiver led defective in the tv.
Nov 21, 2006 | Toshiba 32AF43 32" TV
LG 42PX5D 42 in. Plasma HDTV Logo
79 people viewed this question
Computer Repairing
Computer Repairing
