Question about OKI Office Equipment & Supplies
OKI C5150 TONER SENSOR ERROR: I have replaced the Toner Cartridge 2 times and it keeps giving me the message of TONER SENSOR ERROR
SOURCE: Oki C3530 MFP
Con el cartucho instalado en su posición, tiramos de él para arriba y sacamos todo el alojamiento del mismo. En la parte derecha del mismo hay un cuadradito con una ventanilla de plástico que debe estar totalmente liberada. El problema es que ésta a veces se queda medio tapada y el sensor no detecta el cartucho. Levantar ese plástico hacia arriba todo lo que se pueda ( con algo que tenga punta, un boli por ejemplo) y volver a poner todo el alojamiento en su sitio. Suele funcionar a la primera, y si no, apagar y encender de nuevo la impresora.
Posted on Sep 17, 2008
  • 97 Answers
SOURCE: toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Posted on Dec 07, 2008
SOURCE: OKI C3400 printer keeps saying
Okay, I had the same problem with my C3300. I phoned the people i purchased from and this is what fixed it for me:
looking directly at the printer:
-open printer
-remove drum in question (the drum is what houses the toner cartridge) in my printer it is black.
-look on the right side of the drum & there is a little (approx 5mm x 5mm) hole that has a little panel that opens- push this up to open it.
-replace drum close the top and try printing.
I had to do this 2 times before it worked, but it worked.
Posted on Apr 16, 2009
  • 95 Answers
SOURCE: toner sensor problem k toner 543
Try reseating the toner cartridge, it might not be in good. Reseat the whole drum unit (the part the toner fits into).
Posted on May 03, 2009
LizBux820
SOURCE: Have an OKI Printing Solution
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Posted on May 26, 2009
Have an error message on my oki B4600 that I cant get to reset
you should have an RFID chip in the toner try replacing the RFID chip for the toner
Jun 09, 2014 | OKI B4600 Laser Printer
Toner sensor error
Hi
This error comes up when the printer detects that the toner of particular color is missing. This indicated that the indicated color toner is missing from the printer(eg-- C = Cyan, Y = Yellow, M = Magenta, K = Black).
C5150 may face a toner sensor error after installing used sets of toner cartridges and sometimes even after installing new toner cartridges as well. This error can be bypassed. This can be disabled by following these steps---
1. Turn machine on while pushing and holding the (+/-), menu buttons at same time.
2. Menu window will show OKI USER.
3. Scroll to Engine Dialog Mode is indicated Push Enter button.
4. Diagnostic Mode xx xx xx S Mode is indicated.
5. ( = 2 ) . Press (- or +) button until “ENGINE - PARAMETER SET =2” is displayed.
6. Push Enter button.
7. TONER SENSOR - ENABLE is displayed.
8. Push Enter button.
9. Press (- / +) TONER SENSOR = DISABLE is displayed.
10. Press ON LINE CANCEL buttons at same time.
11. (*) is displayed.
12. Restart the Printer.
Daniel Scott
Jun 22, 2010 | OKI C5150n Led Printer
A message keeps flashing up 231 fatal error. Can you let me know what I need to do. 0116 240 3430 Dorothy
231 fatal error is telling you that the data from the chip on the toner cartridge is invalid or cannot be read.
This may happen for one of the following reasons:
1)The printer is unable to read the data on toner chip because of toner dust or dirt inside the printer.
Solution: Clean the printer inside, clean toner slot and drum.. See:Clean your laser printer.
2)Either the toner is not an original cartridge, it is refurbished or refilled, or the chip on the toner cartridge is defective.
Solution: replace the toner, or replace the Chip on toner cartridge.
3)The toner sensor in your OKI is defective.
Solution: Call the support number listed on the printer manual to arrange repair.
Jun 07, 2010 | OKI C5800Ldn Led Printer
I have attempted to install 3 different black toner cartridges in my OKI c3400. I keep getting an error: "Toner cartridge lock lever is improper, drum missing, or toner sensor error. OFFLINE." I first...
Mar 16, 2010 | OKI C3400n Laser Printer
Message on window: check toner cartridge 542: C toner sensor error
try a different toner first .... doesn't have to be a full one ... just a different toner box. had the same on a machine and it was only a bad toner cartridge. so the easiest thing to do is swap drum units with toner installed ...
if it turns out to be the cartridge you can have a look at the right side ... there is a hole in it and a white plunger moving there and gives the machine the current toner amount in the cart.
Oct 24, 2009 | OKI C5500n Printer
I have a C5150 laser printer that continues to give a toner sensor error after I have changed the black & yellow cartridges? All advice welcomed.
Remove the cartrdges and look to the top inside right of the printer. You should see 4 cut outs with sensors in that correcpond to the crtridges. Blow out these as there will be a bit of toner in there blocking the sensors. Happens quite a lot on these printers
Jul 07, 2009 | OKI C5100n Laser Printer
My Oki C3200 has the following error message 541:m Toner Sensor Error
There are several reasons for this message... we will start with the easiest to solve. Here is a link:
http://www.katun.com/downloads/oki-c5100tnrcartiis.pdf
Jun 03, 2009 | OKI C3200n Led Printer
Toner sensor problem k toner 543
May 03, 2009 | OKI C5150n Led Printer
-open printer
Jan 19, 2009 | OKI C5100n Laser Printer
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 10, 2007 | OKI C5150n Led Printer
123 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
