Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
Color doesn't line up
Yesterday, while I was watching TV, colors get seperated and doesn't line up. I try flash focus and can't get it togeher. Red, Green and Blue are all seperated like 3D movie.
  • 121 Answers
You need to replace both convergence ic's they are located on your D board mounted right on the 2 big heat sinks you should either need STK-392-560 or STK392-510's you can find which one on stamped on the side of your old ic's. you can go to this sight and get them at reasonable prices plus picture installation instructions and free online tech support if you need help. By doing the repair yourself you will save between 4-500.00 for about a 45min repair
http://servicemanuals.vstore.ca/
Posted on Apr 25, 2008
Red doesn't seem to be working properly, but doesn't appear to be a bad projector.
The red CRT tube is failing. They are rated at 3000 hrs of operation. Check the red CRT face to see if there is a lot of dirt on it or has a discoloration on the inside of the coolant chamber. These tubes are scarce and expensive. You may want to consider a new TV.
Apr 27, 2017 | Hitachi 46W500 46 in. TV/DVD Combo
Color not sharp
Display Panel faults:
Vertical (source) faults are usually within the actual panel (Lines/Bands down Picture)
Horizontal (gate) faults are unually within the actual panel (Bands/Lines across the screen)
Better take it to a service station to check it.
Jul 05, 2008 | Samsung PCJ534RF 53" Rear Projection...
Won't focus colors .. can see blue red green seperate ,, tried auto focus did not work
colors won't focus and I tried using auto focus. How do you correct the problem? How do you adjust the tubes?
Jan 06, 2011 | Sony KP-61HS30 TV
Convergence
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 06, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Horizontal color lines..
problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Jul 27, 2009 | Sony KP-51WS510 51" Rear Projection...
Color ghosts out of allignment
This is a convergence problem that can be as simple as poor connections on the pins of the convergence ICs or defective ICs. If you can solder and are comfortable working inside the set where there are potentially dangerous high voltages even when unplugged, you can fix this yourself.
Let me know if you wish to attempt the repair and I will post additional details and instructions.
Dan
May 05, 2009 | Televison & Video
Flash Focus does not focus the TV colors are seperated
if that doesn't work it will need new convergence IC's put in as well as a resistor or two
electech
Oct 29, 2008 | Sony KP-43T90 43" Rear Projection...
Strips of color coming up from bottom of tv
youll need to replace the stk ics inside the tv. they are easilly found by looking for two larg heat sinks. im pretty sure sony runs stk392-510. you will have to look at the ics to verify.
Apr 16, 2007 | Sony KP-53S75 53" Rear Projection...
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
114 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
