Question about Toshiba 32AF43 32" TV
Soldering Regarding your solution below - can I do this myself? How?? Best Solution posted on Jan 12, 2008 Terryfic Rank: Guru Rating: 87%, 1131 votes Correction...solder bad connects on IR DETECTOR LED = Infra-red detector light-emitting diode...located on front edge of circuit board...if soldering
  • 3 Answers
HI: UNLESS YOU HAVE SOLDERED AROUND SEMI CONDUTORS BEFORE STAY CLEAR. HEAT SINKS ARE REQUIED AND CORRECT HEAT IS THE KEY, LEADS MAY BE OF NON COPPER AND THI WOULD REQUIRE HIGHER TEMP IRON. IF IT TINS EASLY THEN GIVE IT A SHOT. BEND LEADS HELPS
Posted on Jun 21, 2008
Hello; I have a Model 32A33 Toshiba TV with the following problem: 1. The TV was changing channels without pressing NO buttons. A student tried to fix the situation changing switches SA07 (Power On/off...
All you need to do now is to buy a new tact switch and replace all of them to resolve the issue. I'm not sure how it looks like the one installed in your unit but you may click this link to buy online. Watch the video below for more info regarding soldering and desoldering the parts on the board.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 09, 2011 | Toshiba 32A33 32" TV
Help unlock child lock on tv.
The solution is so simple!
Press the POWER (RED) button and the TV/AV button simultaneously - hey presto! the child lock will switch off and you will have your TV back working properly.
May 29, 2009 | Philips Magnavox 27MS343S 27" TV
RCA TV Model F36650 Verticle
There are defective components in the vertical circuit. If you can solder and are comfortable working inside the set (there are dangerous high voltages present even when unplugged), you can fix this. Let me know and I'll provide additional details and instructions.
Dan
Dec 02, 2008 | Televison & Video
RCA model hd56w58
the part number for the high voltage transformer, according to another post for this tv is 258512. See below:
noavatar_s.gif jdenton77
Rank:nonexpert_s.gif Apprentice
Rating: 85%, 1 votes
Yes, i had the same issue. High voltage trans. and the HV distributor (splitter) goes bad on there tv, they are known for that. I have the part numbers for the HVT p/n 258655 and HV distributor(splitter) p/n 258512. The two p/n are for HD56W58 proj. tv
Jul 08, 2008 | RCA HD56W58 56" TV
Replacing CRT neck socket after arcing problem.
Hi.
Don't know what happened to the last post I sent you its disappeared.
What I think you should do is definately replace the CRT white socket (tube base plug).
You can either take the CRT number from the label on the tube & put it in to google then search for Crt base plug.
Or see if there is A repair shop local to you who can order the tube base for you.
Are you definately sure the arcing is external to tube & not happening in the tube neck ?
Is the CRT made by LG / PHILIPS. These are notorius for for arcing over internally I must write at least 1 A week off for this problem.
If you can still run the set try tapping the neck of tube with screwdriver handle if pic flashes or goes predominately1 colour you are looking at the tube with internal short.
If this is the case there are ways of trying to get rid of the internal short let me know what you find ?
http://dysonmanuals.llc.nu/
Chris...
Jan 08, 2008 | Panasonic CT-32HXC14 32" TV
High Pitched noise returns after new parts installed.
Use first quality OEM or equiv. transistor, RCA 237470 is
least expensive...............T.
Nov 09, 2007 | RCA F36705 36" TV
Question for troylove11
If the set was off, your horizontal output transistor is most likely good. Some sets do not have fusible resistors and the ones that do usually never have problems with those resistors. With the set unplugged, carefully remove the back and follow the power cord to where it attaches to the main board. At that spot there should be a small glass fuse, usually sitting in 2 small fuse holders so that the fuse will pop right out. If that fuse is good and the set will not turn on, it means that there is a serious problem deeper in the set. If the fuse is bad, you can try replacing it with a fuse of the same rating. If the set works, great, but if the new fuse goes bad, there is a serious short somewhere in the power supply and the set should be serviced by a qualified tech.
Sep 06, 2007 | Orion1934 19" TV
Sansui DTV2760 27" TV
Since nothing else has worked, are you sure that the SAP function on the Cable Box is not turned on?
Sep 05, 2007 | Sansui DTV2760 27" TV
Closed caption
Solution #1posted on Jul 23, 2007 By QTV1 Rank: Guru Rating: 93.33%, 6 votes Press menu on the remote. Press the cursor up or down button untill the word CC is highlighted. Press the cursor right button to select Closed Caption 1. You will likely have to do this with the original remote. A universal remote may not allow you to do this.
Jul 22, 2007 | Philips PR1902C TV
Toshiba 32AF43 32" TV Logo
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
