Question about Garden
Chain oiler will not work - Garden
  • 50 Answers
Take off chain and guide bar use an air line blow back the port were oil comes out make sure cap is off oil tank
Posted on Aug 02, 2010
Automatic oiler problem since date of purchase. Remedy?
No found recall for this. link below not your exact model, may help on repair of oiler
Chainsaw chain oiler repair
Jan 16, 2016 | Makita UC3530A 14" Electric Chain Saw
Tip
Checking your chain oiler
Chain oilers are a vital part of keeping your saw running well. No oil can even cause the chain to bind up. Over a period of time it can greatly increase the wear rate of your bar and chain reducing it's life. Chain oilers seldom go bad they just get clogged up with sawdust.
Remove the housing that covers that bar and sprocket. There are two plates on each side of the bar that set over the studs.They may be identical or slightly different depending on the saw but at least one of them will have a hole in it for the oiler. If you remove the bar and both plates you will see the oiler hole on the saw housing. This oiler injects oil through the plate and into a small hole in the bar where the chain picks it up and carries it around the saw. If this hole becomes plugged with sawdust it will keep your saw from oiling the bar proplerly. This hole should be cleaned out periodically. It's not a bad idea to remove the whole chain periodically and clean the chain guide all the way around the bar and get any sawdust buildup out so the oil can flow better.
on Dec 05, 2009 | Garden
Poulan 1950 woodshark
The first thing I would look for are cracks in the oiler lines. If the saw has a manual oiler try to see if that will get oil to the chain. Check to see if the cap on the oil tank has a plugged vent hole.
Aug 30, 2013 | Garden
What kind of oil do I put into my toro expand it chainsaw?
CHAIN OILER See Figure 18. ? Use Premium Bar and Chain Lubricant. It is designed for chains and chain oilers and is formulated to perform over a wide temperature range with no dilution required. ? Remove the cap and carefully pour bar and chain lubricant into the chain oiler tank. ? Replace the cap and tighten securely. ? Check and refill the chain oiler tank every hour when using an electric power head or every time the engine is fueled when using a gas power head. NOTE: Do not use dirty, used, or otherwise contaminated lubricants. Damage may occur to the oil pump, bar, or chain.
Sep 01, 2011 | Toro Garden
The automatic chain oiler does not get oil to the chain. Yes, it has chain oil. The black tube to the top chamber at the bar, seems to be plugged and I cant get it off to clean it out. Thanks, Steve
I have never seen an automatic chain oiler that worked. Even new ones don't seem to work. Just pour a little used engine oil on the bar once in awhile like everyone else does.
In theory there is a small piston that rubs on an eccentric at the chain sprocket, and that sucks in oil and pushes it through a hole, into the center groove of the bar.
But if the piston is dry, it won't pump.
If the holes are clogged with sawdust, it won't work.
Here is a video that may help:
http://www.ehow.com/video_4756894_a-chain-saw-bar-oiler.html
Mar 12, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Hi,i,m prtty sure the oiler for jonsered chainsaw has conked out
remove the chain and bar look twords the oiler and clean out that oiler port it works on gravitation thats all
Apr 24, 2010 | Hammering
Chain binds saw dies saw runs fine with out bar chain on clutch bearing? help poluan 3416 16 inch 34cc
Is your chain oiler working? If you're using saw a lot and the oiler isn't working properly the chain will get hot and bind up especially if the chain is too tight. Tighten the chain so that you can squeeze it in the center of the bar, with your second and third finger on the sides of your fingers (not a very strong grip) and you should be able to almost pull the chain out of the bar guide but not quite. Clean the oiler hole in your bar where the chain oiler injects oil into the bar. You can also run your saw without a bar and chain and see if the oiler is pushing oil out of the injector.
Dec 04, 2009 | Tools & Hardware - Others
I have 3 older Poulan chain saws, XXV, 1800, and 2000, essentially identical saws. They all use a check valve from the crankcase to pressurize the chain oil reservoir. The check valve apparently uses an...
These oilers are called diaphragm oilers and work fairly well when the saw is new with great compression. As the saw wears out, the compression drops and a side effect is less oil pumped. The diaphragm is replaceable and it's not horribly expensive. Most good saws use a gear oiler - and even the newer Poulans use gear oilers. The gear oilers tend to have less problems and don't rely on engine compression.
Oct 09, 2009 | Garden
Poulan oiler don't work
Common problem with Poulan and Craftsman gas saws. Take off the chain and chain guide and clean out all the saw dust etc. Start saw without chain and look for port where there are signs of oil. If port is clear of sawdust, then it is likely the pump which is located behind the chain break assembly. you can get the diagram on Poulan website and the replacement pump will cost about $15 - $20 to replace yours.
May 22, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain oiler replacement
If it is Stihl 025 the chain oiler is on the bottom.First check if the worm gear(under the starter)is in good condition.Replace the starter(blocking the piston in the cilinder with a rope with many nods,that rope entering in the sparkplug hole).On the handle there are 4 screws on the right side (under 4 black plastic plugs,at the bottom 2 screws.)CUnlock them and take off the handle.At the bottom you can see the chain oiler( under the hose) the mark for right possition is there.Take off the oiler using a screw(lock clockwise into the oiler)and then pull it out.Clean with compressed air the oil hole.Put back together .Succes!
mihai71
Nov 21, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
