Question about NorStar M7324 Telephone
I think my phone needs to be reprogrammed
The first two lines work, we lost the next 4 rollover lines due to a power outage over the weekend
pete 827
please call now 562 947 6622
thx Pete sanchez
  • 677 Answers
Hi, You will need to call customer care line for help.
Take care.
Posted on Aug 02, 2010
Line in use
Hi this problem is more common than you think its caused by the power surge you get when the electric is turned back on you also get this problem due to lightning strike their is absolutely nothing you can do to repair the phone as their are no servicable parts and the chances of getting a new board for the base is going to be nigh on impossible
Feb 12, 2008 | Panasonic KX-TG6073S Trio Cordless Phone
Cannot receive faxes
The storm has likely damaged the phone line, or the ADSL microfilter (if you have one). Which is why it thinks a phone on the fax line is off the hook. Check your line for breaks and your ADSL filters for a blown filter.
Sep 18, 2007 | HP OfficeJet Pro L7580 Color All-in-One...
We seemed to have a power outage over the weekend. We have M7324 system with 6 rollover lines, only the first two work now, the other four are not working. I rebooted the system, no change. Can you help?
You must have an older system. There is a battery built into the control unit (not user replaceable) that stores the system programming in case of a power outage. When the battery is dead, your system will lose all programming and default to assigning the first 2 lines to all phones. The system will have to be completely reprogrammed.
Please Note: Now would be a good time to install a UPS/Battery Backup unit on the phone system. I recommend a large enough unit to keep the phones running for at minimum of 2 hours during a power outage. Install the UPS/BB first, and then reprogram the system (so it won't have to be reprogrammed twice). Good Luck!
Aug 02, 2010 | NorStar M7324 Corded Phone
After a series of power outages and brown outs over the weekend, our system has lost all of the predialed #'s and only one phone in the whole office (10 phone) rings.
Hello. Often the aftermath of a power outage is a power surge. If your phone system is not surge protected, this is the likely culprit. The damage done by a surge or several surges can only be assessed with a thorough diagnostic exploration. This has to be done by a technician with the proper diagnostic equipment and know how. j.
Jun 14, 2010 | Samsung Prostar 816 Phone
Sounds like the system defaulted programming.
Depending on the type of prostar 616 the only ringing station would be 1(or 21) with the porstar or 4(or 24) with the prostar plus.
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
enter in #62 the screen should say day ring assn
press the line you wish to program
press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
press # when finished with the line
repeat steps 2 through 5 for the remainder of the lines you wish to change
press # when finished.
To program system speed dial numbersyou need the customer programming enabled (see the first part of programing ringing)
press the ALM/SD button
dial the 2 digit speed dialcode 10-98
dial the telephone number to be stored in that speed dial bank
press ALM/SD to store the number
Jun 01, 2010 | Samsung Prostar 816 Phone
Since power outage phone lines do not ring - only to receptionist
Your system lost its programming. It will need to be reprogrammed completely. The lines are ringing on the extensions where I voicemail is, unplug voicemail and at least lines will ring in correctly.
Jun 15, 2009 | Avaya Lands Phones
Power outage and lost features
The Privacy is part of FP1. You need to pick a button with a light, put the T/P switch in P, touch the button, dial *72, and put the switch back in the center position.
If that doesn't work, try Auto Ans Intercom or Do Not Disturb under the same button (*70,*71). If you can't get any of the features to work, I'm guessing that the FP cartridge needs to be replaced or power down the system and remove and insert the cartridge again.
Carl
or
Apr 07, 2009 | AT&T ATT / Avaya / Lucent Merlin 820...
Intercom feature not working
Is one of the 2 phones transformer plugged into a power strip? If so, try putting it directly into the wall, most power strips do not pass the signal properly
Mar 22, 2008 | GE RCA 4-Line Speakerphone
Continuous ringing
I found this site because MY phone won't stop ringing. I was so happy to see your problem posted, because I was hoping to coattail for a solution. BUT then I found an old folded printout (2-28-03) of a FAQ from TTSystems (now out of business, I guess) that solved the problem. Here it is: The extensions have to be reprogrammed after a power outage. (My trouble started after a big electrical storm knocked out power to our building.) I guess the same is true of loss of power for any reason, maybe even unplugging them if no batteries, etc. Anyway, each phone's extension defaults to 11 after power is lost. The ringing happens because all the phones have the same extension number--11. So, reprogram them so that they have an extension number from 11 through 22. 1. Press [STORE] 2. Press [1][0] 3. Enter the two digit number you wish to assign to this phone. 4. Press [MUTE] A short ring will be heard to signal successful programming. I am so ridiculously happy that I fixed this. I hope it works for you.
Jun 04, 2007 | IBM Corded Phone IBM412CID
NorStar M7324 Telephone Logo
37 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
