Question about Samsung ML 2525 BW laser Printer
My ML-2851ND printer has a loud noise while printing. I looked in the back and it appears asmall feed roller has broken off. I think the roller is caught - any ideas how to get it out so I can avoid a repair bill. This printer is only 18 months old. I had to get it fixed once already when it was still under warrantly.
SOURCE: Samsung ML 2510 printer won't feed paper
I have experienced the same problem . . . a little earlier this evening. I took all the inner components out, took apart the toner cartridge, I thought that the gearing was very hard to turn on it and on the inside of printer, paper feeding etc... and that is wear the loud noise is coming from. Out of desparation, I shook it to hear if anything internally was loose and there was and still is, I would not say its the best solution or by any means a permanent but you may be able to dislodge the debris from the gearing and be able to print. After it was dislodged from my printers gearing it has worked again. Though I believe it's temporary. I am looking for a guide or how-to on opening the printer casing to physically remove the debris. If you know of a guide let me know and I am sure it would help you too.
Posted on Nov 30, 2007
SOURCE: Samsung ML 2510 feed problem
I purchased the printer new in a box from ebay. Samsung agreed to repair the printer under guarantee. The repair shop has fixed the printer easily apparently. There was a gear out of line which once readjusted ensured the printer works properly. I have not taken the printer apart myself but this should be straight forward. No need attempt if the printer is still under guarantee.
Posted on Jan 11, 2008
SOURCE: Paper tray feed problem
the shaft the roller is on is bent or the clutch on the left of the shaft iis broken.
Posted on Jan 06, 2009
  • 13 Answers
SOURCE: Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
Posted on Mar 08, 2009
nakshatraipu
  • 241 Answers
SOURCE: Printing via USB cable from
contact service centre in india std code+ 30308282
we have solutions for your printer when it shows toner exhasted
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
vivekryp@yahoo.co.in
Posted on Nov 21, 2009
My Samsung ML2851ND jams on first page of two sided printing as it is being pulled back into the printer. The left side does not grab the paper as well as the right side. After the first page is cle
Dear
While duplex print some times this jam happen. Try on detach a leaver (black in color similar to comb) attached to back door of the printer.
Thanks.
Feb 04, 2015 | Samsung ML-2851ND Laser Printer
ML-2851ND Printing Problem
Dear
You have mentioned its a refurbished unit. If you attach a sample print it will be easier to understand the problem. however my first doubt on toner cart. If you are known the refilling/repair procedure, check and clean all rollers and blades. Also check the electrical contact points and lubricate with silicon oil.
thanks.
Jan 07, 2015 | Samsung ML-2851ND Network-Ready Monochrome...
Hp 2200dtn prints fine but makes loud friction noise
Old age printer, Remove right,left, back & top doors. check fuser assm screws tighten or slacked? if its slacked use more lengthy screws for tighten the fuser.Apply grease for the gears to avoid the friction. Open main motor assembly clean entire gears, lubricate & fix it back..Check any gears are warn out, replace it if possible...Best of luck..
Jan 04, 2012 | HP LaserJet 2200dtn Printer
SAMSUNG ML 2851ND TONER REFILLED BUT, NOT PRINT PROPER. 4-5 DARK VERTICLE LINES COME IN PRINTING.
you are using a mono laser printer
possible problem:
The surface (drum part) of the toner cartridge inside the machine has probably been scratched.
Remove the toner cartridge and install a new one.
Jul 17, 2011 | Samsung ML-2851ND Laser Printer
I have a Samsung ml-2851ND, the middle paper roller is extremely tight so the paper is not able to pass trough, he geas made a unparticulary sound,. I think overheat caused the problem, but Im not...
If overheat has occoured the bottom roller (black) will likely be fused to the heat roller. if you cannot turn the rollers with the two green levers down (let the unit cool it will be hot) that would confirm this prognosis. check smart panel if you have it installed for any errors and contact support as this sounds like it will need a workshop/ field engineer repair.
Jun 28, 2011 | Samsung ML-2851ND Laser Printer
Horrible noise after paper jam, paper has been removed , and it seem the roller i can see on top are moving Very fast if i turn printer on.
Hard to say. If paper was removed incorrectly, you could have dislodged something inside the printer. Try powering the printer off and wait 20 second adn power back on
Jun 17, 2010 | Samsung ML-2851ND Laser Printer
Tried to feed envelope. Jammed. Printed two regular sheets that day after jam. Now, next time I turn on. Makes loud noise during warmup when rollers usually test their rolling. Same noise when I send print...
Beside you is broken drive seizing roller, here fault of the **** of the grapping or gear or electro relay. Persuasively - a repair for service this typical fault. Thank you
Sep 28, 2009 | Samsung ML 2010 Laser Printer
Jan 02, 2009 | Samsung ML 1510 Laser Printer
Nov 25, 2007 | Samsung ML-2510 Laser Printer
Samsung ML 2525   BW  laser Printer Logo
267 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
