Question about Gaggia Espresso De Luxe Espresso Machine
HELLO THERE IN MY MACHINE APPEAR THE FOLLOW MESSAGE CARCAR CIRCUITO (IN SPANISH) WHAT DOES IT MEANS?? THX VERY MUCH
    President:
  • 1,618 Answers
It means clear the water circuit or ventilate. Run the hot water cycle for a fer seconds that should clear it.
Posted on Aug 02, 2010
Hoto change from spanish to english
Since the phone is in Spanish, I guess you need help writing the words in Spanish. There is one small problem, that you didn't post details about your device, but I'll do my best.
Follow these steps:
1. Go to settings, in Spanish it should read "Configuraci?n" or "Administraci?n". Tap it.
2. Look for the word "idioma", which means language. Tap it.
Now just scroll down and change it to English, which it should be in English, if not, then search for the word "Ingl?s".
Best of luck.
Jul 18, 2015 | Cell Phones
I have a Singer 7285Q sewing machine that comes up with a "E-7" message and the machine won't work. It only happens when I use "back stitch" button. My instruction manual has no mention of an
E7 means
The start/stop button, reverse/reinforcement stitch button
or the thread cutter button was pressed while no thread
cassette was installed. If the start/stop button is pressed before the sewing machine is correctly set up or if an operation is performed
incorrectly, an error message appears in the stitch indicator. Follow the instructions that appear.
If you press (Stitch selection key) or do the operation correctly while the error message is displayed, the
message disappears
Oct 30, 2014 | Singer Sewing Machines
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/john-michael_38e8d20d2052609c
Mar 23, 2014 | Singer 7258 Sewing Machine
How to retreive my message from another phone
Follow the remote access instructions on page 18 of this manual. (Careful, there are two page 18s in the manual. The first half is in English and the second half in Spanish.)
Mar 07, 2013 | GE 29871GE3 Digital Answering Machine
Necesito el diagrama electronico del Dictaphone 2750. Tengo una falla del circuito y necesito el diagrama para poder detectarla. No me llega tension al motor. Gracias. Herberth
Sorry, I don't speak spanish, but try replacing Q609 on the main PCB. It's located on the top, towards the front of the machine.
Also make sure that the motor doesn't have a 'flat spot' (that it stalls). This is generally what blows the Q609 transistor. If you have power to the machine and a cassette in, try manually turning the motor to see if it'll start on it's own.
Apr 20, 2010 | Dictaphone 2750 Desktop Cassette...
1738 digital answering machine is only talking in spanish
• Choose ENGLISH to have the system
announce voice prompts in English.
Choose ESPANOL to have the system
announce voice prompts in Spanish.
• During setup the Message Window will
display the current language setting (E for
English or S for Spanish).
Oct 18, 2008 | AT&T 1738 Digital Answering Machine
Need to purchase
yes of course u can change just follow these methods
First, you need to install a Spanish keyboard, and turn on the key combo to
switch.
Go to Control Panel, Clock Language and Region.
Then click on "Change Keyboard or other Input method". The Regional and
Language Options dialogue will appear.
Click on the Keyboards and Languages tab. The Text Services and Input
Languages dialogue will appear.
Under Installed Services, press the Add button, and select an appropriate
Spanish keyboard (eg Spain, Mexico, US etc).
Press Ok to add the selected Keyboard.
Now click the Advanced Key Settings tab, of the Text Services and Input
Languages dialogue. Select a key combination, to alternate between English
and Spanish keyboards (Left-Alt, Shift, by default)
Press Ok to accept changes and dismiss the dialogue.
Your Spanish keyboard should now be ready to use, once you press the
Alt-Shift combo.
this is just the display language settings for full conversion you cannot do u have to buy a spanish version or ask your laptop assembler to put spanish version of vista hope so your problem solves with this solution
May 09, 2008 | Microsoft Windows XP Professional With...
CHANGE LANGUAGE
Press and hold the skip key on the answerig machine for two seconds. You will then hear english selected. It took me 30 mintes, but I finally found my instructions manual in english! lol
Dec 10, 2007 | GE 25951EE2 Phone
Cleaning troubleshoot needed
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model. This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue. 1. Check for foreign objects, such as a clip or ripped paper, inside the machine. Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely. 2. If the error continues to appear, the machine may have a mechanical problem. If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Jul 28, 2007 | Brother MFC-5840CN All-In-One InkJet...
Gaggia Espresso De Luxe Espresso Machine Logo
127 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
