Question about D-Link DIR-625 (790069292637) Wireless Router
I am trying to set up my internet when i get to step 3 it is saying that the ethernet cable is not connected i have used two cables but i am still having the same problem helpppppppppppppp.
    President:
  • 1,768 Answers
1. check connection by 1st pinging the network card That is go to the dos window and type " ping 127.0.0.1 you should get 4 replies.
if not then you need to check the driver set for you network card.
2. check the ether net cord with a know good one
3. reset the router by unplugging it and reboot the pc
4.Call your ISP to check for outages
5. check the power adapter it may be faulty.
Posted on Aug 03, 2010
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
Ip address failed
  • In order to connect your console to the internet you will need the following:
  • Laptop with WiFi
  • Ethernet cables
  • USB cable
  • Video capture card
Below are the steps involved includind some additional information:
    File Sharing
  1. Step 1 Go to Settings in the PS3 menu and scroll down to Network Settings. Go to Internet Connectionmag-glass_10x10.gif Settings and select your wireless router from the list of available connections. If the router has security, you must input your password. Internet Connection in the Network Settings list will say "Enabled" once you are connected.
  2. Step 2 Link the laptop and PS3 together through a router if you have one. Connect both the console and computer to the router with Ethernet cables. This is needed for a PS3 with 40 gigabytes of memory and that does not have WiFi.
  3. Step 3 Connect the devices directly with a USB cable. Use one of the USB-style ports the PS3 uses for its game controllers. This requires a USB cable with two thin connector plugs.
    Connecting to a Monitor
  4. Step 1 Purchase an external video capture card for your laptop. This device will connect to the computer through the USB port and will have both composite and S-video connections.
  5. Step 2 Connect the capture card to your laptop. Insert its included CD-ROM into your disc drive and install the software on it that allows the computer to recognize the card's drivers and includes a video viewing/editing application.
  6. Step 3 Attach the PS3 to the capture card using the console's RCA composite cable. Open the video application and turn the console on to view it in the program's screen.
  7. Step 4 Locate and click the application's "full screen" button to enlarge the game screen to your full monitor. THANKS. MIKE
May 04, 2010 | Sony Playstation 3 (PS3) Console
A need help
you can set your playstation 3 online by two ways, 1- by a wired connection, and 2- Wireless,
1-Wired Connection: Plug an ethernet cable from your highspeed modem to the back ethernet input on your ps3 system, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wired Connection. and follow steps
2- Wireless Connection: You must have a Router connecting ethernet cable from your intenet modem to the router, and follow on your ps3: Network Connection > Internet Connection Settings > Easy > Wireless Connection and follow steps,
hope this helped you on setting up your ps3 connection :)
Apr 13, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 does not connect to my motorolla surfboard modem. i connect a ethernet cable from the back of my modem to the back of my ps3 and the ps3 says that there is no ethernet cable connected
hmmmm!!! lsn try to re-Setup the internet connection type all over again ok
main menu->setting->connection settings(internet option)-> here u have to set ur Internet connection up chooz the Wired connection then go with Easy and keep clicking on next till u test the internet connection okkk if it didnt work turn off ur modem for 5 mints ok
Dec 28, 2009 | Video Game Consoles & Games
Zyxel nbg334w router configuration
Hi
To configure the wireless router it is recommended the it is connected directly to router.
Please follow these steps to fix your issue
1. Reset the router using reset button on the back of the NBG334W router
2. Configure or change the laptop ehternet adaptor setting to "Obtain IP address automatically.
3 connect laptop and router using ethernet cable. check the ip address using ipconfig command in DOS prompt. If IP address is 0.0.0.0 or 169.X..X..X run command
ipconfig /release
ipconfig/ renew
best way restart the computer
4. if you still have issue in getting ip address double check ethernet cable and try reseting the router again.
5. Still problem persist install new firmware on the router. you can download router firmware from
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906164737&ModelIndexflags=0,420070320142921
Please vote if this information is helpful in resolving your issue
Dec 27, 2008 | Zyxel Prestige 334 Router
Configuring nbg334w router
ipconfig /release
ipconfig/ renew
Wireless router to modem problems
Since it says network cable unplugged on the computer when wired to the router, you need to check these first:
â Make sure that the Ethernet cable is connected from the modem to the router’s Internet (WAN) port and the computer to the numbered port of the router. The computer should used to be connecting to the Ethernet port of the modem, if not; you should contact your ISP first.
â Make sure that the Ethernet adapter/LAN card on your computer is working properly. You can check that on the device manager of your computer.
â If those are all working fine that would mean the router is not yet configured for Internet access or we can say that the settings for the provider are not synchronized with the router.
To configure the router, you can do these general steps:
1. Connect the computer to the numbered port of the router and the modem to the router’s Internet (WAN) port.
2. Turn off the computer, router and modem.
3. Turn on the modem first, wait for the lights to stabilize then turn on the router. As soon as the lights are stabilized, you can turn on the computer and check for internet connection.
However, if the Internet connection still does not work. That means there are additional settings needed to be done. You can message me about the name of your ISP and I will provide you the specific steps you need.
Sep 23, 2008 | Belkin (F5D7230-4) Router (587009)
Internet connection
It depends... If you use a router for the Internet then you don't need any cable, just turn on the router and then go to the PS3 and configure the PS3 to work with the router. If you have wired internet, then you will need an Ethernet cable, but since the PS3 comes with an Ethernet cable, you don't need to buy one. With the Ethernet cable, you have 2 options. If your modem has an Ethernet port, then just connect the PS3 to the modem directly. If the modem doesn't have an Ethernet port or direct connection won't work, then you can use Internet Connection Sharing to connect your PS3 to the Internet.
Jun 29, 2007 | Sony Playstation 3 (PS3) Console
D-Link DIR-625 (790069292637) Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
