Question about Motorola XU2600 (6 Channels) 2-Way Radio
How to change freguency on motorola - Motorola XU2600 (6 Channels) 2-Way Radio
  • Motorola Master
  • 1,654 Answers
1) Put your radio in programming mode by turning on the radio while holding down the PTT and MON buttons. Continue to hold these buttons until the 'noise' stops.
2) Press the MENU button once. Now, using the + or - buttons choose the frequency number.
3) Press the MENU button to lock in your frequency. This will take you to your CODE. Press the + or - button to choose your CODE.
4) Press your MENU button to lock in your CODE.
5) At this point you can walk through the rest of programming features or simply shut the radio off and begin using it. Note: You will know when you are at the end of the programmable features because it will chirp a different beep than you have been hearing when you've pressed the MENU button to lock in your new setting.
Here's a link to the CP100 (sister radio) manual for more info: http://www.essnashville.com/CP100-operationsmanual-021407.pdf
Best regards.
Posted on Aug 03, 2010
My galaxy sgueals when mic is pressed and while i am talking ,im using a stock mic ,when l talk the freguency counter stop working ,as soon as l release the mic switch it comes back on
bad swr, extreamly high.Re adjust your antenna for the lowest swr and it should go away. If your galaxy has TB turn it off,that could also be the problem.
Jan 10, 2016 | Radio Communications
Low freguency rumble in my behringer 1202fx. problem goes away sometimes when i switch unit of and on but no effects
You are somehow feeding back. Maybe the effects are on with an echo setting. First thing: Make sure ALL interconnected equipment are powered from the same receptacle or source. This includes amps and speakers and any other devices that are powered. Make sure ALL interconnects use BALANCED interconnect cables either TRS or XLR type. First thing is to eliminate ground loops by the above proceedure. Note the pros run power back alongside their snake from teh stage. Using multiple outlets in a building to power equipment puts equipment at risk and picks up noise due to ground bounce.
Apr 02, 2011 | Behringer RX1202FX Ultra Low Noise Design...
Where do i get a list of channels,codes or freguencies from so i can reprogram my scanner
There are several websites and books you can buy. I would try 'radio reference DOT com' for your state. Realize that your scanner CANNOT do DIGITAL, so if there is a digital system in your city/county/parish, your radio will not work. It will however still work on weather, Skywarn, ham radio frequencies and some more rurual police, fire and businesses.
Nov 09, 2010 | Radio Shack Pro-82 Scanner
Can I watch tv in thailand on my Skyworth LCD
Yes,Thailand have PAL signal frequencies.Ur LCD tv work with PAL signal freguencies.
Nov 08, 2010 | Samsung LN32A330 32 in. LCD TV
Motorola gp68 reads error 004 in freguency window
This happens if you leave Dealer Programming Mode without programming any channels or if your programming gets corrupted. To re-enter Dealer Programming Mode hold "PTT" + "MON" + "SCAN" and turn on the radio. Once in DPM your channels can be reprogrammed.
Aug 11, 2010 | Motorola Radio Communications
I want to know what the frequencies are in the digital range what i mean is,like what a digital freguency is
a digital frequency is normally one that is trunked by a digital trunking system. You will need to know what type of trunking system you have, ie: Motorola type I or II, EDACS standard, or SCAT, or EF Johnson. Each one of these uses a different type of tagging to program its frequencies. Some will allow you to just enter the AFS(agency frequency-subfrequency) It looks like this for example: 03-062 Either radioreference.com or your local radio shack should be able to help you in obtaining what you want.
Nov 02, 2009 | Uniden BC72XLT Handheld Scanner
How to change motorola v3i keypad - only the silver thing
you can change the Motorola keypad for that you need to contact the nearest Motorola service center for that
Oct 04, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Ived just purchased a uniden bc 145xl an i would like to program in the police ,fire emerg ect,anyone know what or where to find freguency # for the 34442 area code ///thanks
Not sure where you are so may not be able to help I have had various scanners and the uniden has been one of them You need to find out what frequency they use and you can sometimes tell this from the type of antenna they have You also need to find out if they use VHF or UHF I f you have some idea of these things i may be able to help you more
Jan 25, 2009 | Office Equipment & Supplies
Uniden bc147xlt frequency guides
Go to this site, it has frequencies for cities and counties around the US. This is a link directly for CA. Just click on your area.
http://www.radioreference.com/apps/db/?stid=6
Rollin CBs
Dean
Nov 26, 2008 | Uniden BC244CLT Base Scanner
Kenwood KDV-S22OP
by plugging in an i-trip into the dvd player a rear cigarette lighter, and then playing it over a radio freguency!!
Oct 02, 2008 | Kenwood KDV-S210P Car DVD Player
Motorola XU2600 (6 Channels) 2-Way Radio Logo
409 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
