Question about Acer Aspire L100 PC Desktop
Acer Aspire L100 will turns on but never boots to windows
Hello, I have a Acer Aspire L100. This past week it decide to shut off - no blue screen - just powers down. I can get it to turn on but never boot into Windows. I was able to get into safe mode at one point and back everything up. Now when I turn it on it goes into startup repair mode. Which it told me that it was not able to repair and was most likely a hardware or software issue. I tried using a restore point but no luck. So since I had backed-up my data, I tried using the Acer Recovery CD. Still hangs up and never makes it into windows. Could it be a problem with the power supply? Please, any ideas? Thank you in advance for any quidance.
  • Acer Master
  • 5,660 Answers
Suggest you start with a basic diagnosis first, jrrjma.
1) Is the computer dirty inside? Computer unplugged from power, open the Side Panel.
[Facing the front of the computer the Left Side Panel removes. Facing the back of the computer, you will see a tab formed out of the Side Panel. There is a thumbscrew which is loosened, then the Side Panel is slid back, and up, and out ]
Is the Processor's Heatsink full of dust, etc.?
[CAUTION! Do NOT reach inside until you have followed Anti-Static Precautions!
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short circuit), the delicate hardware components inside a computer. {i.e., Processor, Ram Memory, motherboard chipset, and so on}
Computer Unplugged from power, working on a table, and computer case open; TOUCH the metal frame of the open computer case.
Make sure it is an unpainted surface.
Should you get up in the middle of working on your computer, and walk away, upon your return be SURE to Touch the metal frame again ]
Heatsink: Basic construction is a flat plate of metal, that has tall, thin fins protruding from it.
The flat metal plate absorbs heat from whatever object it is placed against, (In this case a Processor), and the tall fins absorb heat from the metal plate.
The fins radiate the heat away. With a fan used in conjunction with a Heatsink, the air flow carries heat away from the fins.
I don't know if the Acer Aspire L100 series uses a computer case fan, to push air through a plastic tuned port, onto the Processor, or there is an actual fan sitting on top of the Heatsink.
This is a basic example of a fan sitting on top of a Heatsink,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3451342&CatId=493
If the fan, (Computer case fan, OR fan on top of a Heatsink), is clogged with 'gunk', the cooling capacity will drop tremendously.
If the area in-between the fins of the Heatsink, is clogged with 'gunk', (Dirt, dust, hair, etc.), the cooling capacity will drop tremendously.
When a Processor surpasses it's thermal limit, (Becomes too hot), it turns off. (BIOS turns it off)
This is a Fail safe feature, designed to keep the Processor from burning up.
According to specifications listed for the Acer Aspire L100 series, the Processor is an AMD model. AMD's run hot as a rule, and will burn up in seconds without the proper cooling. (Around less than 30 seconds)
If the computer is dirty inside, use a can of compressed air for computers, attach the plastic straw to the nozzle, and clean the computer out.
Also clean out the inside of the Power Supply, the best you can.
[The Power Supply's case has ventilation holes in it. The plastic straw is used. Advise hold onto the plastic straw with one hand, and the can of air with the other hand. The straw can shoot off, and wind up inside the Power Supply]
Your theory of a bad Power Supply, (Weak voltage power rail), does hold some looking into, however.
{Bad Power Supply, could also have been caused by the inside of the computer, and inside of the Power Supply being dirty, too.
The cooling components for an SMPS (Switched-Mode Power Supply), are it's fan, and Heatsink/s used inside.
Once the fan, and Heatsink/s are clogged with gunk, the cooling capacity drops tremendously.
Heat = Wasted Energy
The Power Supply strains to keep up with the call for power, and eventually components inside fail, causing the Power Supply to fail }
You press the Power On button. This in turn presses against a Power On switch.
The Power On switch is connected to the 5 Volt Standby circuit. {When a Power Supply is plugged into power, there is 5 Volts present inside the Power Supply. 5 Volt Standby power}
Pressing the Power On switch closes the switch momentarily.
This directs the 5 Volt Standby power through a circuit, which excites the Power Supply, and turns it on. (No pun intended)
The first chip to receive power is the BIOS chip.
[Chip and Chipset are slang terms for I.C. Integrated Circuit. BIOS stands for Basic Input/Output System]
BIOS looks to see what devices are installed, does a Ram Memory count, Turns the Processor on, and hands the computer over to the Operating System.
{Windows XP is one example of an O/S}
In the meantime other devices are receiving power. The harddrive, optical drive/s, graphics chip on the motherboard, (Integrated Graphics), or a dedicated graphics card, and the Ram Memory modules, ('Sticks')
If the Power Supply has a weak voltage power rail, the other devices draw away the power needed to turn the Processor on.
[1) ALL the LED lights use less than 1 Watt of power
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor can draw 51 to 125 Watts. Depends on what Processor it is ]
Processor draws power. Too much overload for the weak Power Supply, and the Power Supply turns off.
Either test the Power Supply voltages, or replace the Power Supply.
The latter doesn't seem like a good alternative, given the price of replacing, granted. If you wish to know how to test the Power Supply voltages, post in a Comment.
The Voltage going into a Power Supply is enough to give you a bad shock, or a Fatal one. ]
You will not be addressing this part of the Power Supply. You will be addressing the low DC voltages coming out of the Power Supply.
(A Power Supply converts AC electricity, into DC electricity. Depends on what country you are in, as to what the AC voltage coming in is.
120 Volts for the USA, 220 for Europe, 100 for Japan, are a few AC voltages used.
The voltage coming out is DC as stated.
Three main DC voltages.
A) 3.3 Volts (3 point 3)
B) 5 Volts
C) 12 Volts
Two D cell flashlight batteries produce 3 Volts DC.
(EDIT:
Always so much fun when I accidentally post a Solution as a Clarification!)
Posted on Aug 03, 2010
  • 2 more comments
  • jrrjma Aug 03, 2010
    I did clean out a lot of the dust already but I will try getting the air can today and try doing that also to get the hard to reach places.
    There are two fans with the heatsink but nothing with the power supply. This is one of those mini desktops - the plug is like a laptop one that has the big rectangular box - inside the computer behind where it plugs in is a little 1/2 inch box. Can you tell me how to check the power supply?
    The computer just never gets into windows. At one point when it was giving messages about the software I decided to just start from scratch and use the recovery CD. It will run the entire 30 minutes through that CD and never shut off but when it comes time to restart so that it can finish the process in windows it never will go into windows.
    Any suggestions?
    checked power supply with Ohm meter - 27V
  • joecoolvette
    joecoolvette Aug 04, 2010
    Right jrrjma!
    (Asker of problem = 100
    So called expert of Acer computers = minus 0
    Slapping self around right now.
    Ouch, THAT hurts!)
    27 Volts DC, huh?
    Hmmm,
    http://www.mini-laptop-accessories.com/o...
    Okay, (Picking self up from floor), let's go on.
    Recovery Cd disk that came with this Acer?
    Did you do a Repair, (Non-Destructive Recovery), or a Full Install? (Destructive Recovery)
  • jrrjma Aug 04, 2010
    There wasn't an option on the Recovery CD - so Full Install - since it said everything would be wiped out.
  • 34 Answers
Not the power supply...recommend reinstalling windows
    Already tried reinstalling - can never complete install since can't get into windows.
  • Ron Jones
    Ron Jones Aug 03, 2010
    need to boot from CD and use a windows CD disk....
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    Hi...i'm trying to boot my comp however it doesnt seem to want to get past the microsoft corporation loading screen....d2d doesnt seem to work either
    Follow the steps below,
    Step 1: Shut down your PC completely.
    Step 2: Turn on the Power button.
    Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
    Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
    Step 5: Select that and HIT ENTER.
    Step 6: your PC will boot to the windows.
    Dec 20, 2010 | Acer Aspire 6920 Notebook PC
    My aspire L100 will not boot. When on button pressed blue light comes on and then goes off straight away and fan starts Ok but nothing else
    You may need a new power supply....also check your internal fans to make sure they are spinning. Make sure memory is seated properly. Motherboard may also be in question. Try unplugging letting it sit for a few then plugging back in.
    Aug 05, 2010 | Acer Aspire L100 PC Desktop
    My acer aspire l100 keeps shutting off. it sometimes will stay on for like two minutes but most of the time it shuts down after like 30 seconds. it works fine in safe mode. most of the time it shuts off...
    this seems like a software issue . if you can not run your system but ift works fine in safe mode try to run a system restore from factory disks and see where that gets you,
    May 14, 2010 | Acer Aspire L100 PC Desktop
    Black screen after turn on
    That "Blue Screen" is also known as "Blue screen of Death".
    The problem is due driver compatibilty or unstablity.
    Try to boot your system to "Safe Boot" by pressing F8 during startup.
    Select "Last know good Configuration that works"
    Check if it can take you to desktop.
    Unstalled the wi-fi driver and reboot.
    If the above procedure fails, again
    Select "Safe boot"
    Now create a restore point  and download the lastest version of your WI-Fi driver and installed.
    This should work fine.
    Otherwise Backup all your important data from your hard drive (mainly opearting system file installed drive usually C:\) and go for a new Installation.
    Dec 28, 2009 | Acer Aspire One PC Notebook
    Thanks for the response to my Acer L100. have checked the cables and they are fine. have noticed the fan doesn't start up when the computer is switched on....could this be the problem???
    The CPU fan should turn on when the PC is powered on, and then it usually slows down until the workload on the processor causes it to heat up, then the fan spins faster, it might also be a power supply issue, but if your able to boot and its giving you messages and not shutting down then you should re-install the operating system.
    Nov 18, 2009 | Acer Aspire L100 PC Desktop
    Hello I have problem my pc acer aspire l100 i have problem power yes light yes job dvd-rw and fan cooler so no screen display monitor only black please can you help me
    Does your laptop beep at all when you turn it on?
    Try unplugging the laptop and removing the battery for 5 mins, then try again.
    If you have another monitor you can use, plug it in to your laptop and see if you can get a display on it.
    Mar 15, 2009 | Acer Aspire L100 PC Desktop
    Possible overheating problem for Acer Aspire mini L100
    I am not totally sure if this is the problem, but I would suggest that you may have a power supply issue or possibly it going out. If the computer runs fine, and then shuts down, than this can be more symptomatic to a overheating issue.
    In my limited experience with overheat issues, the computer actually smelled like it was getting hot, and then it would slow down and then sometimes stop. Most computers have fail safe settings where they either alarm, or shut down or both when they overheat.
    Sep 26, 2008 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 PC Desktop Logo
    439 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
