Question about Recoton Advent Advent DV1418A 14 in. TV/DVD Combo
On every dvd i enter systems say is a bad disc, have 2 headrest units and both are doing it.
A man if u like hearing music ull be fine but that **** happens to my tv to and thats fucken ******** best solution go buy one at bestbuy its a flatscreen with dvd combo no more that 220 ima go buy it and throught the advent peace of junk
Posted on Dec 20, 2010
I can get the home page up on the tv where it says cyberhome. i put disc in and it says loading and then it says bad disc. what does a bad disc mean?
Assuming the player is fine, the 'Bad Disc' display message usually means either a disc which is an incompatible format (for example DVD-ROM) with this player; a disc which is a region that does not match that of the unit; or a defective/damaged disc. Check the discs prior to using them in this player and if they are burned discs, make sure they are a compatible standard format for playback.
This model is not region-free by default unless stated otherwise in the manual.
Apr 16, 2011 | Cyberhome CH-DVD 300 DVD Player
My XO Vision DVD player in my car headrests stopped reading discs. It says no disc even when one is in the unit. Tried to clean it with a cleaning disc and it didn't help.
This sounds like a laser problem. The laser is not recognizing that a disc is in the unit. The cleaner unfortunately is only for the lens
Nov 17, 2010 | XO Vision XOD1735 Car DVD Player
Headrest built-in DVd with disc stuck...help
Look for a small hole under or on the side door assembly, if found use a paper clip or other thin metal straight object and insert into hole this will release the disc clamper and open the door.
Nov 25, 2009 | Televison & Video
Dvd player won't read disc
I believe Vizualogic has serious quality problems. I had RT20 installed and it was defective to start with. The headphones did not work on one unit and the other unit made a loud sound when it was turned on. I had the units replaced. The new units had a new problem - Disc Error. The players were not able to read the discs. The installer tried another unit and it also had the same disc error problem. Interestingly, the word disc was spelled as DSIC - can you believe the quality control on Vizualogic prodict?
The installer then found that a wire had come loose in one of the units. He applied some tape to hold the wire in place. The unit seemed to transmit sound again. Well, a broken connection, disc error in multiple units and incorrect spelling was enough to turn me off. I am now trying to get some other brand installed.
Aug 18, 2009 | TMI Products Vizualogic Headrest Pair...
Dvd screens in headrests are not getting power
The problem seems to be that the video out from the kenwood head unit is either faulty or the leads from the head unit to the monitors are faulty. Have you checked to see that the head unit when playing a DVD is set on ZONE 2 so that it transfers the video signal to the headrest monitors?
Jul 12, 2009 | Kenwood DDX-6019 Car DVD Player
HEADREST dvd player honda odyssey 04 exl
Do the headrests detach?? If they do, you can buy the pair of 7" headrest DVD/Monitors all-in-one from Farenheight (made by Jensen). I have used these several times. Not only do the headrests match,but the product lasts too! The best part is that they are about 1/2 the price of many others.
Larry T
Winona Lake, IN
Jan 28, 2009 | TMI Products Vizualogic Headrest Pair...
Installation of headrest dvd
yes the screen has to sandwich the material from the headrest to hold it in place.....
Oct 10, 2008 | 2006 Audi A8
MP3 CD's Not working Samsung HT-DB120 System ?!!!
Try opening the zoning code. Unit must be switched on with NO disc inside. press enter,then enter the code 84269 and press enter again.unit will switch off. switch on unit and try again.
Feb 12, 2007 | Samsung HT-DB120 System
Recoton Advent Advent DV1418A 14 in. TV/DVD Combo Logo
130 people viewed this question
Top Recoton Advent Televison & Video Experts
Rommel Balcita
Are you a Recoton Advent Televison and Video Expert? Answer questions, earn points and help others
